Hey guys
I need to buy some new coilpacks soon but as people know there is a difference between the coilpacks for a Series 1 R33 and a Series 2. Now looking at my engine in the photo attached and other people's Series 1 engines, shouldn't there be a largish ignitor type pack where the red circle is. Where as it looks like I have this plug which I have seen on Series 2 engines.
So as you can see I'm a little confused (that or im just a noob and missing something). The car is a Series 1 1994 model.
Any help will be appreciated
Cheers
https://www.sau.com.au/forums/topic/298730-help-for-decision-on-coilpacks/
you'll require series 2 coilpacks than, why are you replacing them tho? are they missing? if there is nothign wrong with them, dont waste your money on replacing them as the stock ones are by far the best out there when they are in good condition, the only ones that come close to a decent set of stockers are splitfires.
Ye they are missing pretty bad are high rpm and load. Put my mates good ones in there and no problem. Yep am going to buy the splitfires.
Im just curious why would someone replace the ignition system on the car to using series 2 coilpacks? Any advantages with having the ignitors inbuilt?
you sure your cars 94 not 95 or so? i cant remember what year the series 1.5's started which had the s2 coil setup
Ye the series 1.5 started in late 95 I think but mine is registered as 94, plus I don't have ABS which I know Series 2 had. Other than that I don't know how else to distinguish a series 2 engine....
Now Im wondering if you change the coilpacks to series 2, would they have to change the rest of the ignition components or can you easily convert from series 1 coilpacks to series 2 ones?
abs was an option, i had a S2 front cut that didnt have abs a while back, get your vin fasted could tell you a bit more. but i wouldnt worry about it... providing its all working
I should mention before I sound stupid that my mates one I tried is from his Series 1 R33 which has the same plug at the back of the engine as mine, that's why I wasn't sure if both of us have series 2 coilpacks so ye
    • The max they would go for me is 50.
    • That cannot have been a fun set of drilling. The stock "baffle" looks identical to rb26, I just cut fuel cell foam to fit the full length under the baffle.
    • I understand your sarcastic exasperation. But to be fair - the baffles do indeed fit OEM cam covers. They did omit to say that you need to do a bunch of stuff. But they do fit them.
    • Got started on the modification to make these splash plates fit over the long weekend. First the surprisingly time consuming task of swapping all the cam cap bolts to Tomei cam cap studs. I did the method of removing one bolt at a time, applying loctite to the stud, double nutting to torque as the manual described. Then carefully unlocking the nuts without disrupting the torque of the stud (and going back to re-torque a few times when it slipped). Finally applying the nut and torquing to spec. Repeat x28 Next up I went about removing the stock cam cover baffle so I could ensure it was fully clean after drilling for stud clearance.  As the blind rivets holding the baffle on were domed I used a punch to mark the center then used 4mm drill bit to carefully drill out the rivet without going too far part the baffle. As seen in other thread here is what is inside the stock baffles I decided on M4x6mm bolts to bolt the baffle plate back on with. I used a 3.3mm drill bit with some tape to mark the depth at ~8mm. Next was to tap the threads using a cheap bunnings kit M4x0.7. With the baffle removed I also drilled out the spot welds holding in the baffle plate oil returns. Unsure whether this was the best option or if I should have cut holes in the Hypertune splash plates to allow the oil drains to still function... time will tell. I then removed the the Hypertune splash plates so I could rest the cam cover on top and use a dab of grease to mark where the studs impacted the oem cam cover baffle. The most obvious spot was on the hump from the stock mesh is held. Using this hole as an anchor I bolted the oem baffle plate back into the cam cover and lined up the Hypertune splash plate. Marked the rest of the holes for the studs and drill those out too. Total 32 holes drilled and 12 threads tapped on the passenger side cam cover alone for this bolt on part that totally clears all OEM cam covers.. Drivers side next as well as some E85 safe fuel foam to fill the space behind the behind cam cover baffle plates. oh and some lock nuts for the splash plates of course.
