This is my sad little attempt to take a half decent photo and i failed :)
I took a whole bunch out last night just goofing around with my camera
my tripod failed and i dont have a shutter release cord
ps. i dont have photoshop atm...and when i was taking the pics everyone was getting eaten by mosquitoes...so i got hurried up :D
and i managed to photograph a ghost aka my mate blair running around in front of the camera
Edited by Passive
  • Replies 87
Posted Images
snaps with the new 17-85mm lens i got
missed a couple of the noise spots in photoshop in the first one, and saving it to a lower quality jpeg f**ked with it a little
First time ive ever attempted taking and/or editing these types of photos so throw me some tips if you have any :D
Edited by stenve
Nice work Tabby! I took some shots from Kings Park as well, but without a tripod not one turned out good :) In the 2nd one (looks kinda trippy :D) the lights in the shadow looks a better and less over exposed. I had the same issue, the street lights look awesome, but the bigger signs are unable to be read.
Constructive criticism: there's no real focus point in the photos (which is, admittedly, pretty hard to set at night). That and the camera shake wouldn't have helped. Also, the trees on the bottom-left of the photos take up too much of the shot.
If you do have a tripod but not a cable release, the next best thing to use when you've composed your shot is the self-timer on the camera itself. Put your camera on the tripod, set the timer to 10sec, compose the photo, and then trigger it to shoot. The 10sec margin should give the tripod and camera plenty of time to settle any movement before the actual shot is taken.
Hey thanks for the advice!!! (camera timer)
never thought of that
yeah the photos are crap IMHO :)
but i had my bf, mate and his 'gf' there and they were whining about mosquitoes, so i didnt get much of a chance to screw around
also the crappy tripod wouldnt tilt any higher
i'll try the timer thing next time
yeah the photos are crap IMHO :D
Instead of tilting the tripod higher I would probably zoom in a bit instead if you can.
Try cropping the top and bottom of the picture a bit (prob a bit more at the bottom)
thats what i was going to leave mine as but those damn sulpher lights are too bright. so did in-camera conversion and looked heaps better so left it like that!
and i saw it earlier in the night heading nth, so coming back i had to stop off and take it!
    • I'll just leave this with, holy shit, those cars at work are awesome, and this will look wicked!
    • Could you modify this duct so instead it pushes the extra air through the radiator too and not down and out? For temps, I know it's not the greatest idea, but as a bit of a last resort, you could use a very intermittent misting spray onto the front of the coolers/rad. You don't want to be soaking them such that water is dripping off, but a small most on/off so that the water evaporates. That point of it constantly evaporating, rather than being soaked in water, will pull a LOT of heat out of the cooler. I'm literally thinking just the little mist sprayers for a garden from Bunnings. Being in a low humidity climate it will help even more! The other trick if you want to be ghetto is some shade cloth hung in the opening, and keep it wet. Pretty much now it's acting like an evap cooler on a house, but cooling the air you need to use to cool the radiator...   On a topic to think about too though, when air enters through the bumper, is it all nicely ducted from the edges of that opening back at a nice angle, or is it like most cars, and the edge of the opening just stops, and suddenly it's wayyy wider behind that? If it does the later, get it shrouded out at nice angles. When that opening changes too rapidly, it can actually cause a high pressure zone between the front bar and radiator, and limit air flow into that area, which means less air for cooling, as it effectively stalls the air, AND adds to drag...
    • Do you have any before and after photos? That's $200 just for the hydro blasting?
    • It doesn't look like there's a lot of options out there these days, and what's out there is performance oriented aftermarket stuff (with the GTR markup) I wonder if there are other cars with similar springs, after all its just a matter of length, diameter and stiffness. Alternatively, I did see coil spacers. Probably not the best option, but could be serviceable too.
