Ok just put a 2nd hand RB20 from a ceffy into my silvia (previously had an R32 RB20) and after the joys of having to swap every fking sensor over so I could use my old 32 engine loom, I've started it up and seen that the harmonic balancer is shaking like an epileptic with parkinsons :D
I've checked the main bolt on the end of the crank and thats tight. Theres 2 snapped bolts out of the 6 or so smaller ones (the ones that are left are tight) but I wouldn't think that would cause the good 10mm of play that the harmonic balancer has. It's wobbling so much it's taking chunks out of the timing belt cover behind it :D
I've been told a possible cause is the end of the crank is bent. I want to believe there is possibly another, not so expensive to fix, reason why the HB would be wobbling so much, can anyone enlighten me to any or am I going to have to rip the f*cking engine out and spend more money fixing the heap of shit :)
Edited by AndrewJZX100
https://www.sau.com.au/forums/topic/298789-hamonic-balacer-shaking/
Has the outer ring separated from the inner ring (wobble will be radial only)? I'm no expert but you'd probably be able to see this if you looked at the balancer end on and see any cracks/rips in the rubber. Try a small mirror.
If thats the problem then you just need to replace the balancer.
    • It is possibly 55 degrees for the Nismo version. I had a look through the manual and the stocker has a breakaway torque of 2.5 to 3.5kgm. Supposedly the Nismo LSD goes down to 5kgm when worn in but it is pretty grabby even with very little throttle. Worse when cold. So I guess you have three things. 1. Shims. 2 Friction plates 3. Cams Would think shims would be the easiest but Ive no clue how many tenths of a mm shim thickness change equals how many kgm torque. Also not sure if the Nismo friction plates are similar/different to stock or if they are the most of the source of the diff being angry. Think I can write off the Nismo rebuild kit for the standard diff as not being what I want.
    • Yeah, it was a bit of confusion with me, I rang and asked if they had a boot for a soft top, and then the paint shop when they rang and were asked if it had a hard top on it, which it does, just not a PRHT....LOL Meh, whilst frustrating for all concerned it isn't a war stopper and should be a thing of the past in a week or two In other N/A related news, car is booked in at the end of the month for the cams, springs, retainers, harmonic balancer and retune  I might even pull the lazy arse card and get them to do a full service on it whilst it is there
    • Factory LSD is supposedly a 2 way with a very conservative cam. If you've already tried adding friction modifier to the diff oil and it still locks up too much for your liking you might want to adjust the ramp rate on the cam to be more like OEM instead of reducing initial torque even further. People claim the 8 kgf-m disc kit for the OEM LSD is still very streetable but I've never been able to compare everything side by side on my own.
    • Oh man, at least it sounds they've accepted they stuffed up and not put it back on you...could see some confusion if they asked if it had a hardtop or not, and you've answered truthfully but maybe not answering their real question which is what roof did it have from the factory! Glad your keeping it N/A 2.5
    • Nah, I much prefer colour matched Talking about colour matching stuff, the new/used boot lid turned up, all painted up perfectly......aaaannnndddd, it's for a power retractable hard top, not a soft top.....LOL They are now sending a boot to fit a soft top.....,  whilst frustrating, life is like that sometimes, sometimes you just need to dodge, duck, dip, dive and, ummm, dodge.
