also you can test the os sensor. with a multi meter. i cant rememer exactly how thou. if you get stuck and cant find out to pm me. with the afm. get a multi meter, find the signal out wire and check the voltage. on idle or off it should be arround .5 volt i think. but not totally sure. when mine was running shit the afm was reading 2.5 volts.
