Stagea Shell And Your Busted Bits Wanted
Kierin
 Share
G'day
I'm looking for some parts for a project I had in mind, they do not have to be in good condition, nor in a working condition. The purpose of these items is just to trial fit an engine in a C34 Stagea to see how or if it will fit. If I have left any parts out that anyone thinks could be handy please let me know. A left over half cut would be near perfect if anyone has one lying around instead of taking it to wrecker.
Looking for the following items:
1) Front half of a C34 Stagea shell going as far back as possible but no shorter than the transmission mount, no need for panels - needs to be fairly straight.
2) Cross member from a 4WD model
3) Steering rack
4) The steering shaft between the steering wheel and steering rack
5) Front sump including diff, presumably from an RB25 motor
6) Front Drive shafts - can be twisted, snapped or other
7) Sway bar
I live West of Brisbane, so I can pick up items if they are within a couple of hours from Bris, otherwise a transport company will be needed to get em.
Regards
Kierin
G'day
3) Steering rack
7) Sway bar
Regards
Kierin
Hi
I have items (3) & (7) if they are any good to you. The sway bar is free (standard) but I would want some $$$$ for the steering rack.
Long story short I replaced it but as it turned out it was not the problem.
I live just west of Ipswich.
Phil
Hi
Phil
If you're available over the weekend i'll definately grab the sway bar off you. Cheers mate.
How much you chasing for the rack?
I can on reply since I haven't reached 10 posts
 Share
    • From what I've seen and experienced first hand with those powder extinguishers, they're good to use to break a window and escape the car, and half the time then do f**k all to stop a fire. You just need much more than 1KG worth of powder. Not to mention, half the time it's an engine bay fire, and you can't easily, and do not want to completely open the bonnet, so you're left pretending to be an American Infantry... Spray and Pray baby!   And then 100% that shit is really destructive afterwards!   Realistically, those little ones at a race track might help you keep the fire from growing and give the fire marshal / truck a chance to actually get to you with their multiple large bottles.   For a road car, these days, prepare to deboard as quickly as humanly possible, and move to safety. Allow insurance to fix replace it (unless it's like a rare classic etc, then do nearly everything possible to save it!) Keep the little extinguisher with you to help protect other things around you from burning while you stand there singing "How can we sleep while our beds are burning?"   Secondly, powder extinguishers I freaking hate for indoor use, (this isn't really relevant to a car) as you will get a powder fog around you, and it can be disorientating.   When I did fire training when at BlueScope Steel, they have (had?) their own fire brigade on site. We did all the training, and at the end we were told, "If it's an indoor fire, and you need to use a powder extinguisher, we as the fire brigade would rather you just exit the building, you're more likely to get lost in the smoke and powder fog than do much help, so just GTFO" And pretty much that was what they said for most other fires too, grab extinguisher, if it's much more than paper in a bin fire, use extinguisher to get you and others out of the building to safety...   Part of me wishes when my Skyline caught alight many moons ago, I let insurance sort it out, instead of putting the fire out... part of me now says "But I've saved a classic before it was a classic!"
    • Hi all,  I have a older model of the Greddy Front facing intake on an RB25DET NEO Head. I've bought aeroflows fuel rail and injector kit (1000cc Bosche injectors) and I'm unsure if the fitment is correct. The injector o-rings fit in the intake hole but it's not snug. I can very easily rotate the injectors even when the fuel rail is mounted. The kit also came with multiple adaptors, they dont make it any more snug and using them raises the injectors up and i cant mount the fuel rail. I hope this makes sense I've asses a few photos.    Thanks so much guys.
    • So, to run the 4g aerials to the booster, I had to get access to the rear bulkhead....bit of a mission. Hot tip, don't offer to help change the rear shocks for a mate with a v37.... Remove seat base, 2 clips that slide forward to release it the it lifts straight out Fold down rear seat (pull in from boot) The side bolster of the rear seat is not connected to the middle parts that fold. To remove unbolt at the bottom bolt then push it up off the top hook Then there is a plastic surround behind the seat back, 2 pop out clips, 2 bastard clips, some swearing at it is out Pop the rear seat latch surround off Remove door surround lower trim then side trim  Remove c pillar trim - 4 clips, pull inwards not forwards Remove metal brace - 5 bolts 1 nut Then you have got to the rear strut top...what a pain!
    • If you really want squish back, you can have it put on the piston (at least to some extent).
    • Impressive. He's very very smooth.
