hi guys, been having this on going issue on my R34 RB25DE+T ever since the turbo conversion.
when cold (left overnight for example) i start it the next day and the idle is very rough and lumpy and the car full shakes/rumbles etc but give it 2-5minutes then it will just idle normally.
any idea what causes this and how i can fix it?
i took apart the AAC on the weekend and gave that a clean with TB cleaner but no luck.
however i believe the plug connecting to the AAC wasnt properly connected and it was tuned like that.
when i got the car back i thought the rough idle was caused by o2 sensor not being connected (thats what the tuner also told me) so i connected it up and it still happened.
2 months later, i serviced the car and i plugged it all back in after putting the sparkies in then it idled like sh*t (stage 3 cams like) even when warm so i disconnected the plug to the AAC played around with the idle adjuster screw a bit and manage to get it idling okay but till this day, as mentioned above, it still idles sh*t when cold.
any help much appreciated as it is quiet frustrating not knowing why its doing it.
Cheers :blink:
https://www.sau.com.au/forums/topic/298847-rough-idle-when-cold/
emanage ultimate
apparently the first guy said he tuned it for cold start
which i dont think he did as i found alot of short cuts in the tune since taking it elsewhere.
fmic,
turboback exhaust
spark plugs
oil + oil filter
gtt injectors
33 gtr fuel pump
turbonetics turbo + ext gate
stock manifold
intake pipe
moodles; no i did not. but it never happened previously when it was NA.
so wat im thinking is the tuner tuned it with the AAC disconnected.
i think MBS206 is spot on here. will have to speak to my new tuner to see if it can be fixed easily.
    • Add to this... What blew the fuse too? If a circuit feeding power to the coils was blown, how were the coils even functioning to let the car start?   There is some seriously wrong wiring in that car for certain, and I'm betting there is some melted cables somewhere, but I can't explain the 30v either, unless there is something back feeding on that power line that has a dodgy power system and the electronics are giving it hell.
    • This is typically the case with such threads. What I cannot quite get my head around is where a reading above 12V (or 13.8 or 14.x or whatever the maximum achievable voltage might actually be in that specific car) comes from. 25V or 30V should be completely impossible. There's no way to create it. Hard to answer that question. It will literally depend on whether the current tune relies on the values as set. I'd guess it probably does. ie, the real base pressure being 49 means that the flowrate through the injectors will be higher than if it was 43.5. The Haltech's modelling should be handling that, but because it thinks the pressure is only 43.5, then..... I dunno. It should be thinking that it will be injecting less fuel with each pulse duration than is actually happening. So, something is definitely not-as-it-should-be, but specifically what that is is beyond my abilities to imagine. Someone like Dose who spends more time with Haltechs might have a better thought.
    • Bit of a late reply here as me and my wife have been really busy with new born twins. I finally got these issues fixed and it was something really stupid that caused all of this 🤦‍♂️... After alot of mucking around with trying to figure out what is causing these issues, I back probed one of the R35 coils on the power 12v supply, with the engine running it got 25v! And I thought, hang on..., this isn't normal. Measured my battery with the engine running to check for over charge from the alternator and it wasn't that. So then I dissconnected the R35 PRP coil harness and backprobed the power supply on the engine loom where the ignition coil harness connects, with the key on ignition (engine off) it measured 30v! So then I had to trace where that high voltage was coming from and it lead me to the brown relay "ECM & IGN coil relay" inside the cabin next to the ECU on the passanger wall. This relay feeds power to the ECM and ignition coils. Tried swapping it with another same relay. nah still 30v.. coming from the 2 green/white wires in the brown relay. So then I set my multi meter to the beep continuity mode and probed every fuse on the fuse box inside the cabin to try and find this high voltage power source. Wasn't any of the fuses inside the cabin. Then probed all the fuses in the engine bay and BAM, got my power source that was a 10AMP fuse called "ENG CONT". Pulled the fuse out, and what do you know... it was blown. 🤦‍♂️  So then I quickly replaced it with a new 10AMP fuse, started the car and yeah haha [insert extreme face palm]... The RPM blimping thing went away, car idles smoothly now like what it was before. I swear! I checked all my fuses with my test light twice before I created this forum thread. I think, maybe because one side of that faulty 10A fuse lit up on my test light, I must have thought it was still ok and not blown. But now I know to have both sides light up on the test light when checking fuses... I hate diagnosing electricals.... I'd take mechanical problems over electrical problems any day🤣. Drove the car around my suburb with the engine up to operating temp and it runs fine like before. However, I notice that my fuel pressure is still at 49psi. So I'm thinking this must be normal for my system as I've upgraded the stock fuel pump to a Walbro 255L/h with a constant 12v mod.  But anyway, I'm just glad to have my daily back on the road! Thanks everyone for the replies on this thread, all sorted now! One thing I want to ask you tuner guys, my base fuel pressure on the haltech main settings are set to 43.5psi from default (my tuner must have not checked the fuel pressure maybe when tuning my car?). Do I set it to what it actually is idling on at 49psi? Or just leave it ("if it aint broke, don't fix it/leave it")?
    • The max they would go for me is 50.
    • That cannot have been a fun set of drilling. The stock "baffle" looks identical to rb26, I just cut fuel cell foam to fit the full length under the baffle.
