Folks.
I unplugged my battery while working on the car, and now it does not start properly when the motor is warm. I have to blip the throttle otherwise it stalls.
Otherwise the car is fine, running better than ever.
I tried the ECU rest, idle resets, etc, but its hard to tell if i was successful.
Any ideas on solutions? Or is it just a matter of time while the ECU relearns?
Cheers
You need a new PCV valve methinks..
As an interim solution, remove the PCV valve, thoroughly clean with carby cleaner, reinstall, start and warm up car, then off-start (it may still stall), off, start, off start a few times. Soon after it won't stall anymore.
I did the above process and while straight after cleaning, it stalled after i started it about 3-4 times.. the next time i drove the car a few days later it didn't happen again. Getting a new PCV valve myself..ebay USA have 'em.
GL.
Folks.
Cheers
i had the same problem a while back when the battery died. it took a while but it looks like the ecu was able to make the adjustment. i was thinking of bringing it in for service because it was annoying (being a manual) but it eventually fixed itself. but like i said, it took a few weeks. have not had the problem since.
After your cars fixed itself..do your revs drop below normal idle setting (550rpm) when you clutch in to goto neautral, or also when you goto neautral and brake hard/semi hard ?
Interesting!
Good to know thankyou :blink:.
Almost certain a couple of NM35 stagea owners also had problems with hot start stalling, but like me they also suffered from revs dropping below idle on clutch in sometimes, especially under semi hard to hard braking. I've got the thread bookmarked but too lazy to open lol. Anyways, when one of them replaced their PCV valve, problem solved. I cleaned mine and the car is definitely running smoother.
I must say sounds like Xscape is having issues with the battery d/c then, not the valve.
Thanks guys. I will see how it goes over the next couple of weeks then.
Rianto, Saturday is doubtful for me at this stage as I have a date with a dyno. If anything I will make it to the car wash very briefly - it is filthy as hell afterall.
Anyway. The problem occurred after 30 minutes of having the battery disconnected. I was waiting for the motor to cool down before attempting to install my plenum spacer, but got impatient and decided it would be best to tackle it the next day. Hooked up the battery again and it wouldnt start properly.
On that note, I've since installed the spacer (motordyne iso thermal kit) and my review is that yes there appears to be a very slight increase in power. I got the kit with the additional gasket (b/w lower plenum and heads) and the coolant bypass valve - both of which seem to be working as the plenum is much cooler to touch after going for a spirited drive. Worth the money? provided you dont pay for installation - definitely.
Cracked open the plenum, wasnt too surprised to see 70,000 kms worth of caked on oil and carbon.
Carby cleaner FTW
Thats correct.
It was unplugged for about 30 minutes, maybe a bit longer.. Was getting too late in the afternoon and the motor was still hot so i plugged it back in to move the car.. and it kept stalling on start up unless i blipped the throttle.
I did the plenum install the next morning.
The car starts normallly when cold and drives perfectly fine all the time. Its just hot starts that are giving me trouble.
  • 3 months later...
its not abnormal
it happens to alot of peoples cars
and yes it only happens on hot starts. cold starts are fine.
dont worry about it, will go away.
EXACT SAME issue here....discon batt (as not using car for a while and GPS sucks power, flattens battery when parked).
PROBLEM IS that that was 3 weeks ago...after some driving, hot starts STILL require acc pedal depress to keep idling, then all's fine.
BUMMMMMMMER!
I need to find the PCV on this car!...anyone got a pic with an arrow pointing to it?...lol.
OR...bring up the idle (how to do how to do?) by 150 rpm and that seems to solve it (simulated by slight pedal depress mimicking 150 rpm increase seems to work).
Cheers.
  • 2 months later...
- Nope didn't fix it, going to try PCV and inspect throttle body next...
Got mine fixed a few weeks back, during a major service.....(46000 km)
Throttle body had to be removed and cleaned, (it was filthy) some sort of callibration of the throttle had to take place....now all ok. (idles nice and won't stall on warm start!)
I try really hard now not to let the battery go flat!!...(could be just coincidental, but I ain't taking any risks).
Oh, as for PCV valve?,,,,,I couldn't find mine!!!....(nor could the mechanic!)...anyways, car is great now.
    • Lucky man, who owns it in the family? Any pics?
    • The engine stuff is Greg Autism to the Max. I contacted Tony Mamo previously from AFR who went off to make his own company to further refine AFR heads. He is a wizard in US LS world. Pretty much the best person on earth who will sell you things he's done weird wizard magic to. The cam spec is not too different. I have a 232/234 .600/603 lift, 114LSA cam currently. The new one is 227/233 .638 .634. The 1.8 ratio roller rockers will effectively push this cam into the ~.670 range. These also get Mamo'ified to be drilled out and tapped to use a 10mm bolt over an 8mm for better stability. This is what lead to the cam being specced. The plan is to run it to 6800. (6600 currently). The Johnson lifters are to maintain proper lift at heavy use which is something the LS7's supposedly fail at and lose a bit of pressure, robbing you of lift at higher RPM. Hollow stem valves for better, well everything, Valve train control. I dunno. Hollow is better. The valves are also not on a standard valve angle. Compression ratio is going from 10.6 to 11.3. The cam is smaller, but also not really... The cam was specced when I generated a chart where I counted the frames of a lap video I had and noted how much of the time in % I spent at what RPM while on track at Sandown. The current cam/heads are a bit mismatched, the standard LS1 heads are the restriction to power, which is why everyone CNC's them to get a pretty solid improvement. Most of the difference between LS1->LS2->LS3 is really just better stock heads. The current cam is falling over about 600rpm earlier than it 'should' given the rest of my current setup. CNC'ing heads closes the gap with regards to heads. Aftermarket heads eliminate the gap and go further. The MMS heads go even further than that, and the heads I have in the box could quite easily be bolted to a 7.0 427ci or 454 and not be any restriction at all. Tony Mamo previously worked with AFR, designed new heads from scratch then eventually founded his own business. There he takes the AFR items and performs further wizardry, CNC'ing them and then manually porting the result. He also ports the FAST102 composite manifold: Before and after There's also an improved racing crank scraper and windage tray. Helps to keep oil in the pan. Supposedly gains 2% power. Tony also ports Melling oil pumps, so you get more oil pressure down low at idle, and the same as what you want up top thanks to a suitable relief spring. There's also the timing chain kit with a Torrington bearing to make sure the cam doesn't have any thrust. Yes I'll post a before and after when it all eventually goes together. It'll probably make 2kw more than a setup that would be $15,000 cheaper :p
    • Because the cars wheels are on blocks, you slide under the car.   Pretty much all the bolts you touched should have been put in, but not fully torque up.   Back them off a turn or two, and then tighten them up from under the car with the wheels sitting on the blocks holding car up in the air.
    • Yes. Imagine you have the car on the ground, and you mine away all the ground under and around it, except for the area directly under each individual wheel. That's exactly how it'd look, except the ground will be what ever you make the bit under each wheel from
    • Yes, if you set the "height" right so that it's basically where it would be when sitting on the wheel. It's actually exactly how I tighten bolts that need to be done that way. However....urethane bushes do NOT need to be done that way. The bush slides on both the inner and outer. It's only rubber bushes that are bonded to the outer that need to be clamped to the crush tube in the "home" position. And my car is so full of sphericals now that I have very few that I need to do properly and I sometimes forget and have to go back and fix it afterwards!
