  • Replies 102
Posted Images
Hi mate, I sent a PM a week ago asking about some interior trim parts...
Anyway, I want the Centre dash trim please, send me a msg on 0411 544 307 to say when I can pick it up. Need it before Christmas.
And if you've got the shifter boot square in good condition, I'd like that too please (that the boot clips into).
  • 3 weeks later...
New update... May parts up for grabs again due to deals falling through
Engine/Mechanical
Plenum & Throttle Bodies $300.00
Standard Block $700.00
HKS 2530 Turbos approx 10,000k's old $2,500.00 including HKS actuators and HKS dumps SOLD PENDING PAYMENT
Exhaust Manifolds $50.00
AC Compressor $120.00
Power Steering Pump $100.00
Alternator $50.00 SOLD
AAC $50.00
Coil Packs x6 $100.00
Ignitor $50.00 SOLD
Crank Pulley $100.00
Turbo Oil Water Lines $50.00 SOLD
CAS $120.00 SOLD
Windscreen Wiper Motor $40.00
Brake Master Cylinder $50.00 SOLD
Clutch Master $50.00
Boost Sensor $30.00 SOLD
FMIC Piping x2 $40
BOV x1 and adaptor plate $50.00
Cross Over Pipe $50.00
AFM's x2 $140.00 (2 Sets) 1 set left
Gearbox $500.00
Front Diff/Sump $300.00 SOLD
Power Steering Reservoir $30.00
O2 Sensors x2 $50.00
Engine Wiring Loom $180.00
Injector Resistor Pack $50.00 SOLD
Fuel Rail $40.00
Clutch and Brake Pedal $30.00 each
Accelerator Cable and Pedal $50.00
Windscreen Washer Bottle $30.00
Front Driveshaft $40.00
AC Condensor Fan $20.00
Standard Clutch Fan $40.00
Starter Motor $100.00
Interior
Dash Cluster 280kph (No Brand) $150.00
Front Seats (wear on driver side seat) $500.00 (pair) SOLD
Rear Seat $100.00 SOLD
Momo Steering Wheel & Boss $50.00 SOLD
Instrument Cluster Surround $30.00 SOLD
Door Cards $60.00 SOLD drivers Passenger side left
Dash Loom $100.00
Carpet $80.00
Roof Trim $80.00
Center DIN Guages $80.00
DS Window Control $60.00
Sun Visors $30.00 Pending
Boot Trim $50.00
KickPanels $30.00
HICAS Computer $50.00
Gearshift Surround $40.00 SOLD
Center Dash Trim $40.00
Rear 1/4 Trim $40.00 SOLD
A Pillar Trims $30.00
Center Console $60.00
Door Garnishes $50.00
Interior Lights $30.00 SOLD
Dash Windscreen Demister Vents $20.00
Glove Box $30.00
Fuse Box Cover and surround Interior $30.00
Drivers Footrest $20.00
Heater Unit $40.00
Climate Control unit $80
Suspension & Brakes
Brakes & Rotors $500
Front Driveshaft $100.00
Brake Booster $30.00
ABS unit $180.00
Tailshaft $150.00
Steering Column $150.00
Steering Rack $150.00
Exterior
Passenger Side Headlight $120.00 SOLD
Boot $100.00
Passenger Guard $100.00
LHS Door $130.00
RHS Door $130.00
Windscreen with RVM and in built antenna $200.00
Rear Window $150.00 Hold
Sideskirts $50.00
Wiper Arms $30.00
Fuel Tank $150.00
Tail Lights $50.00 each
Genuine GTR Rear Wing $100.00
Passenger Indicator $20.00
Rear Bar reo $50.00
Cowl Pane l $40.00
Reverse lights $30
Clutch lines $40
Side mirrors $50 each
Rear Bumper $80
Was that the bar that secures the battery in one of the pictures? How much :huh:
Haha, sorry mate, i think that is the gearobx sub-frame u might be looking at. The battery tie down got a bit bent in the accident.
    • And if you want more power, more reliably, and cheaper, go get the Aussie RB... The 4L Barra and put that in instead.
    • No cats will keep discolouring the rear bar. Sends white paint a weird yellow stain. Cut and polish normally gets it out, but you'll be doing that every fortnight I found.
    • Both heads will be equally reliable or unreliable depending on what you do to them.  Stock the RB26 head will flow more. You have access to the stock intake ITB manifold on the RB26 cheaply which flows really well(1000hp+).   Arguably more aftermarket support for RB26, though in Aus we love our RB30 SOHC heads too.    The only downsides to the RB26 head is if you have a VL commodore and want to keep the SOHC look.  Where you may have an issue is drilling out the rb30 block for the bigger head studs but if you are building a big power motor you'd probably put bigger studs on the SOHC head too.  This is just about finding a good machine shop, sometimes easier said than done.  RB30 head worked can make big power just like a Rb26 head, so really it actually more comes down to what your preference is for your car.  People now even making billet versions of both.
    • 2630s work perfectly well. There is something to be said for just using the 30 head, as it saves all the pain of the conversion, still makes tons of power, still sounds cool, etc etc. 2630 will obviously make more power again, but the differences are not stupidly big. It really depends on whether you're racing for sheep stations or not. If it's dead serious, then it's a 26 head. If it's just for fun, it could go either way. But the 26 head and the effort to get it set up, etc etc, is part of the fun.
    • I've been building a 26/30 for a few years now. I've had the head built with all the good stuff. I had a 32 gtr but blew it up and yes its all going into a vl but im looking for some advice from some RB nuts on pros and cons on putting a 26 head on a 30 bottom end is it worth it Works are as follows Head -Extensive porting 1mm oversized supertech valves Supertech double springs Supertech valve guides Supertech titanium retainers Tomei solid lifters Tomei 270 x 10.25 cams Head drain Bottom end series 2 rb30 block Cp ceramic coated pistons Eagle rods Romac balancer Oil restrictions  O ringed blah blah spent a fortune And will get a girdle because the 30s arent used to handling that much rpm Nitto billet oil pump Hypertune plenum 6boost mani Refurbed astra pump thats the cover for it in the boot I did have a precision 6262 but sold it because drag car life. Currently building the ass end full 4 link floater rear end with a 2 speed  But the dilemma i have is my mate rekens I should just stick with the 30 head for reliability. Has any one had any issues with mounting the 26 head ie compression blowing gaskets etc. Just looking for some advice from people who have gone down this route. Here's some photos. Blew the oil pump in the gtr and decided to rip the motor out at the time and do a full build only to find it had been a repairable write off so went down this path.
