anyone can feel free to correct me if im wrong but..
my understanding is that speed graphs mean you cannot really disguise a laggy setup,whereas displaying vs. rpm you can. if for instance the dyno run was done in 5th, you could have the car very very slowly pulling from 2000rpm all the way to redline, and this slow climb in revs would give a massive turbo time to spool by say 3-3500 rpm and by looking at the printout you wouldnt know. This same setup displayed as speed instead of rpm you would see that it was still only making massive boost because it was in 5th up round 200kph, not a useful track/street setup neccesarily.
By displaying in speed this fudge factor is taken out as the dyno tuners are forced to make runs in 3rd or 4th which shows us actual meaningful response times for the power delivery. By knowing roughly your gear ratios and comparing this to the speeds on the dyno chart you can tell what gear the run was done in and thus whether or not to take the responsiveness (or lack of) of the engine with a grain of salt....
Hope this helps
Sean
https://www.sau.com.au/forums/topic/298894-dyno-sheets/#findComment-4970587
a lot of the time, the car's is calibraded against the dyno speedo. this will tell you the multiplier (diff) datio. if the car is in 4th (1:1 ratio)
if this is done correctly its a good indication on your actual speed. RPM is based off the same calculation of dyno to tacho and is quite often off by a few 100 rpm. that is why most operators leave speed as the reference.
its pretty easy to work out rpm from speed. all you need to know is the diff ratio. and as long as the tyres used are close to the correct rolling diameter you will be right.
sorry I hope some of this makes sense, my head is all over the place., might read it later and see WTF i ment...
https://www.sau.com.au/forums/topic/298894-dyno-sheets/#findComment-4970602
They don't do it because it takes longer to set them up....that is all.
And it's not / 28 for all cars either. All of our cars run ratios from 3.9 to 4.11 to 4.375 and a few others as well. It gives you an idea but still not 100%.
If you ask your dyno op to hook it up vs rpm then they will. It will just cost you a little more.
https://www.sau.com.au/forums/topic/298894-dyno-sheets/#findComment-4970723
TBH most of the guys ive talked to cbf'd doing the setup for each car, i don't have a choice with the dynapack as everything has to be calibrated (rpm matched to within about 5-10rpm) before commencing any runs, its easy and takes about 1min to do.
https://www.sau.com.au/forums/topic/298894-dyno-sheets/#findComment-4970750
Not true, the dyno controls the speed the car revs out... so it doesn't really matter which gear it is in, in that respect.
https://www.sau.com.au/forums/topic/298894-dyno-sheets/#findComment-4970752
Not sure about the other dynos but i know on the dynojet it's just a matter of hooking up the pick up around the loop on the back of the engine for the rpm.
For example, it would just make life sooo much easier to see at what rpm the turbo is on full boost without having to do calculations if u know what i mean!!!
https://www.sau.com.au/forums/topic/298894-dyno-sheets/#findComment-4972796
I don't see the point of comparing to RPM...
Torque VS Speed is going to be the real winner in a race.
Seeing that a car makes say an average of 500nm of torque across a 70KM range, is much more beneficial then seeing it makes 500nm across a 2000RPM range when you're comparing a vehicle on the track...
https://www.sau.com.au/forums/topic/298894-dyno-sheets/#findComment-4972995
they are directly related so its a moot point.
https://www.sau.com.au/forums/topic/298894-dyno-sheets/#findComment-4973243
Possibly be better if, say, comparing quite a few vehicles on one day.. Lots of different final drive ratios, if you kept the charts all referenced to rpm it would be easier to make a comparison?
btw, thats a question not a statement..
Edited by heller44
https://www.sau.com.au/forums/topic/298894-dyno-sheets/#findComment-4973345
Because you are trying to see what your ENGINE is doing when you put it on a dyno, not how the car will perform. You have the track for that--and don't say suspension/tires don't allow for that, because you can look at mph and just how fast you went down the last half of the 1/4. The power vs. RPM dyno sheets look useless IMHO, and I think it's just the operator not feeling like setting everything up for an RPM reading. Just my opinion though.
https://www.sau.com.au/forums/topic/298894-dyno-sheets/#findComment-4973983
Did you mean Speed vs Power is useless. Or RPM Vs Power is useless. Coz you sound like you are disagreeing and then you agree? Im so lost
https://www.sau.com.au/forums/topic/298894-dyno-sheets/#findComment-4974037
Or if you actually do a full gearbox dyno pull you can see exactly where the perfect shift points are.
Can't do that with RPM... :D
https://www.sau.com.au/forums/topic/298894-dyno-sheets/#findComment-4974122
    • Yeah, so widen your search to any Nissan speedo first, then go wider if needed. I will say though, that there is a better than even chance that what I said first will likely come into play. They quite possibly won't come apart without damage. I tried to disassemble a stepper gauge that I wanted to repair. There was no way that needle was coming off the spindle, and I could not see how the spindle would come out of the mechanism behind. Assembled once, never to be disassembled, was my conclusion. Could be the same on the R34 cluster. Failing that - take the cluster to a workshop that specialises in automotive instrument work. There's usually at least one in every Australian city. They'll either be able to do it for you for small cost, or tell you it can't be done. It might be that "it can't be done" unless you follow some arcane procedure, including trickiness to glue it back together or something, that only experienced techs know.
    • Well, given that I, an engineer, almost never bring out the torque wrench to tighten up chassis bolts, despite fully knowing the theory, and instead rely on feel, which I happen to know is exactly how the majority of mechanics do things, should tell you the level of actual peril that exists from not achieving exactly 88 Nm of torque. How about if I just say then that 88Nm is at the lower end of the correct wheel nut torque range? Everyone knows how to tighten a wheel nut, right? And almost no-one ever brings out the torque wrench for that task
    • Don't be ridiculous. "2-3 ugga duggas or one Oof. You have to use Oof on tie rods because you can't get an ugga dugga on there." Is not helping the guy at all.
    • I have done a lot of research before posting here and on gtruk forum. couldn't find anything. I have my gauges all part except the needle itself. the needle has a extremely small hole in the center, but the shaft going to the needle is extremely small and appears to have nothing to index it either. doesn't seem strong enough to simple pry or pull without damaging something. Already tried the old spoon trick on a extra triple meter I have from a gtt, but no luck. the center cap comes off easily but the hole in the meter face plate aren't big enough to get over the needle itself. figured this would be my best place to find someone who might have actually removed theirs. wonder if there is some type of small pin press tool to push the pin in while pulling the needle base off.
    • Ok...its taking me long enough to finally do this.  Feck financial security...heart disease will get me soon enough anyway So welcome to the garage..."Clem" Belsil80 has been running a 370Z in Super TT series. So after entering with him in last years Winton 300 i figured I  need my own car. Seems SAU Vic race cars need to be yellow....{tick} Reckon with enough motor i will be able to make up for the lack of talent and stay ahead of the 370Z... but the LS powered S13 and E36s are a ways up the road Aim is to have a car that doesnt stop or turn but has a bit of shed built motor with jam...maybe some cream  First step is getting this ex drift car log booked I am keeping faithful silver car. As the road-club car gets upgrades the race car wil get the sloppy seconds
