Hey guys,
Now I've heard previously there was a fair bit of interest in people getting c/f door cards when I last posted about them.
Have spoken to Shane at PSI Parts and he would be able to get these made, we'd just need to get 10 people down to get these to make it feasible.
Price would be $600 for the pair, don't try and tell me thats not a bargain as F1 in the UK are selling them for 700 pounds.
Please post your interest below
Cheers
Accessories are not included on the door cards
Not sure if we could get the GTS/T/R written on like this will have to confirm
Fitted:
https://www.sau.com.au/forums/topic/298898-carbon-fibre-door-cards/
It's only going to be for 33's atm, depending on the success of this they may start to provide for 32's and 34's, unsure
As I know alot of people are after them, cause generally they are only made for silvias and 180s at most places from what I know so far.
Only door inserts atm, I know the c/f doors can be purchased in Aus, but not the door cards though.
The GTR wont be on these doors, its just an example as Knight Racer in UK do have it on theirs.
I can definately say the c/f is top quality, have had my bonnet, duckwing and diffuser all from them, PM-R33 also has gear from there so will be able to agree as will anyone else who has purchased from PSI Parts.
I dont personally know F1s gear so wouldnt be able to compare it.
I can get you photos of the weave on my gear if you want to check it out
    • While it is a very nice idea to put card style AFMs into the charge pipe (post intercooler, obviously), the position of the AFM and the recirc valve relative to each other starts to become something that you really have to consider. The situation: The stock AFM is located upstream the turbo, and the recirc valve return is located between the AFM and the turbo inlet, aimed at the turbo inlet, so that it flows away from and not through the AFM. Thus, once metered air is not metered again, neither flowing forwards, or backwards, when vented out of the charge pipe. When you put the AFM between the turbo outlet and the TB, there is a volume of pressurised charge pipe upstream of the AFM and there is a volume of pressurised pipe downstream of the AFM. When the recirc valve opens and vents the charge pipe, air is going to flow from both ends of the charge pipe towards the recirc valve. If the recirc valve is in the stock location, then the section between it and the TB doesn't really matter here - you're not going to try to put the AFM in that piece of pipe. But the AFM will likely be somewhere between the intercooler and the recirc valve, So the entire charge pipe volume from that position (upstream of the AFM, back through the intercooler, to the turbo outlet) is going to flow through the AFM, get registered as combustion air, cause the ECU to fuel for it, but get dumped out of the recirc valve and you will end up with a typical BOV related rich spike. So ideally you want to put the AFM as close to the TB as possible (so, just upstream of the crossover pipe, assuming that the stock crossover is still in use, or, just before the TB if an FFP is being used) and locate the recirc valve at the turbo outlet. Recirc valve at the turbo outlet is the new normal for things like EFRs anyway. In the even of a recirc valve opening dumping all the air in the charge pipe, pretty much all of it is going to go backwards, from the TB to the recirc valve near the turbo outlet. But only a small portion of it (that between the TB and the AFM) will pass through the AFM, and it will pass through going backwards. The card style AFMs are somewhat more immune to reading flow that passes through them in reverse than older AFMs are, so you should absolutely minimise the rich pulse behaviour associated with the unavoidable outcome of having both a recirc valve and an AFM in the charge pipe.
    • Yep, in my case as soon as I started hearing weird noises I backed off the tension until it sounded normal again. Delicate balance between enough tension to avoid that cold start slip and too much damaging things.
    • I'm almost at a point where I feel like changing the alternator. Need to check the stuff you mentioned first though.
    • @Dose Pipe Sutututu I read your replies RE: R35 GTR MAFs, any ideal spots to put on? Obviously will need the adapter plate. Will be having a cross over intercooler fitted shortly, would putting it a bit before the TB be okay?
