Mail order R33 (R33 ecu use) factory ecu custom remap also R32 R34 Available
I will remap chips according to your car modifications
price
Std turbo , std AFM , Hiflow fuel pump , std injector R33 $400 ,R34 $500 (R34 will install daughter board. This daughter is able to use nistune and emulator) plus post $20 ecu exchange
Hiflow turbo , Z32 AFM , Hiflow fuel pump , std injector R33 $500 , R34 $600 (R34 will install daughter board. This daughter is able to use nistune and emulator) plus post $20 ecu exchange
Please send your car modifications to me. I will remap chips according to your car modifications
and send it to you. Original chip will be replaced with remapped chip on ECU.
R34 will install daughter board. This daughter is able to use nistune and emulator.
When you get remapped ecu , please check Air/Fuel ratio and pinging on dyno for safety.
Please change colder spark plugs and please check and adjust ignition timing to factory timing before dyno.
If fuel is too rich or lean ,engine knock etc I will send another chip.
We have 2 types chip.
[street chip] Power will be around 195kw.(with FMIC) Same fuel consumption or better fuel than stock ecu.
[Power chip] More power than street chip around 5-10kw.Fuel consumption is bit less than stock ECU.
If you are not happy I will money back
If you are not happy please send back in two weeks.
Otherwise I can not refund money.
DYNO sheet of series 1 R33 GTS-T std ecu and remaped ECU will be compared
The graph below represents Std ecu 143.7kw and remaped ecu 185kw at 10psi for same car but not same dyno
R32 R33 R34 power fc and Real time ECU tune (R33 ECU use) in Sydney , please check this thread
http://www.skylinesaustralia.com/forums/Po...ml&hl=toshi
  • Like 1
DYNO sheet of R33 GTS-T haltech piggy back ecu and remaped ECU will be compared
FMIC , bigger fuel pump , Z32 AFM , hiflow turbo
266hp is piggy back ecu tune.(Xspeed do not tune piggy back ecu)
305hp is mail order custum remaped ECU .
R33%20biggyback%20ecu%20Z32%20AFM%20hiflow%20turbo%20fuel%20pump%20befor%20gif.gif_______ R33%20biggyback%20ecu%20Z32%20AFM%20hiflow%20turbo%20fuel%20pump%20after%20gif-1.gif
Mail order price
Std turbo , std AFM , Hiflow fuel pump , std injector $400 plus post $20 ecu exchange
Hiflow turbo , Z32 AFM , Hiflow fuel pump , std injector $500 plus post $20 ecu exchange
All R33 GTS-T mail order custum remaped ECU DYNO sheet
FMIC (some side mount cooler) , boost controller , turbo back , only.
Boost is 10-13psi.
Some auto mission skyline.
auto%20R33%20dyno%20gif.gifR33%20auto%20DYNO%202%20gif.gifR33%20auto%20DYNO%20gif.gif
Mail order price
FMIC , Z32 AFM , Hiflow turbo , hiflow fuel pump.
DYNO%20WA%20hiflow%20gif.gifR33%20biggyback%20ecu%20Z32%20AFM%20hiflow%20turbo%20fuel%20pump%20after%20gif-1.gif
Mail order ecu feedback in skylines forum
Yep he was good to me too. I got 190rwkw on 11psi R33 with std turbo but full exhaust etc.
Mine even was a bit strange with s1 ECU but s2 car and we did it via mail but he was very good, answered a lot of questions from me too. Definitely one of the best guys I've dealt with about Skylines.
If I lived in Sydney I'd just see him for servicing and everything.
yeah great guy, had my s2 ecu remapped by him through mail also.
had a few hiccups but was more than helpful everytime i called him and everything was perfect in the end.
same - but for a series 1 Stagea, works a charm
240kw from the auto
How does the car feel?
BLODDY QUICK!!
A lot of power from 4000rpm. 2nd and 3rd gear pulls so much harder than ever before.
1st gear is just crazy as it revs out so much quicker.
Im not experiencing any flat spots anymore either..
More feed back in Skylines Australia forum.
  • 1 month later...
240kw from the auto
BLODDY QUICK!!
how much for r33 gtst nistune ecu? do you sell the software too, I live in germany so I would need the software to tune it
+ 1 for toshi. Good to see you are still tuning cars. I got my tune done years back by toshi and i highly recommend him.
Have you heard of Link ECU's Toshi? If so do you tune them?
+2 - stagea auto 240rwkw
Thank you siddr20.
Please tell me what type of car?
If its skyline or silvia I am able to tune.
Toshi - can you do remaps for cars with big injectors? i.e i have 740cc jobbies and a big turbo, z32 ect.
Are you able to do anything for that?
Thanks
ANdrew
Thanks
ANdrew
I do not have 740cc data.
I have 480cc and 550cc (nissan or nismo only)
If you in sydney I am able to remap for 740cc.
Toshi
  • 1 month later...
I have beem looking at getting a tune for a while now and have been looking at what you are able to do.
the car is r33 s2 manual
mods to the car are
FMIC
Splitfire coils
Hyflowed turbo (hypergear)
Turbo back exhaust (xforce 3")
Bosch fuel pump (040 internal)
Turbo smart boost tee
AFM std
injectors std
I do have a a Q45 AFM that is not being used at the moment if needed for a better tune.
how much for a remap to suit these mods with freight. What is the time involved in doing this.
regards
Rob Ballard
20 Esmond Street
Wangaratta Vic 3677
0409942069
mods to the car are
FMIC
Splitfire coils
AFM std
injectors std
regards
Rob Ballard
20 Esmond Street
Wangaratta Vic 3677
0409942069
I sent PM.
Thank you
+ another 1 for Toshi.
MODS:
-Hi-flow turbo by GCG @ 16psi
-Walbro Fuel Pump @ full voltage
-3 1/2" Exhaust Turbo Back w/ Hi-flow cat
-Apexi Pod Filter w/ Cold Air Intake (Great in Summer, even better in Winter)
-Standard Injectors
-BP 98
-242rwkw.
RJ.
p.s. Toshi, can you tune with E85 fuel when I get Z32 AFM and 550cc Nismo Injectors?
Please let me know.
Cheers.
MODS:
-Standard Injectors
-BP 98
-242rwkw.
RJ.
Please let me know.
Cheers.
Thank you RJ.
Yes, I can.
  • 1 month later...
Hi Toshi
I am very interested in one of your remaps. So how does this work and how can you make guarantees about performance and safety when doing this by mail order?
Do I install it and then get it dyno'd to check AFRs etc?
I have an R33 GTS-T S2 with the following mods:
-Full turbo back 3inch exhaust
-Pod and cold air intake
-Large FMIC
-EBC currently set to 10psi
Is this the Nistune daughterboard and maps you are installing? Do you retain the R33 ECU?
Cashed up and ready to go :(
Hope to hear from you soon
Hi Toshi
-Large FMIC
Yes, you install it and then go to dyno to check AFRs for safe
This is not nistune board (nistune do not sale board for R33.only softwear)
Im using same R33 ECU chip (same genuine ecu chip).
I have spare R33 ECU.
If you in Sydny Im able to real time ecu tune.
Thank you
  • 1 month later...
hi there Toshi ,
I live in Qld and own a r33 gtst series 2 skyline with standard turbo and would like to know about the remapping chip. I have a blitz cs fmic , 3inch exhaust except the factory cat conv ( apexi front and dump & kakimoto 3inch regu cat back ) turbo tech running 10 pound but would occasionly run 12 pound using a manual turbotech boost controller ,kn air filter, gen walbro fuel pump GSS342, new plugs etc in an automatic transmission with after market tranny cooler and always running 98 octane fuel
cheers Ken
Edited by Kenna802
