Hey guys,
Some of you might know me, im Luke from Drift Documentary : wearedrift.com and to continue making my drift documentary im going to be selling my personal drift car and getting something cheaper to drift and using funds from the sale to put towards the making of my documentary. First off my car is still located in Japan, and will be shipped anywhere around the world to the new buyer. Moving the car is no issues.
The car has been used for track work and has been driven two or three times this year, only ever had Trust oils put into her and everything is in perfect running order. There is no rust on the car but it has the usual drift wear and tear, contact me for more info. If i cant sell for my asking price will just keep it.
* i have full boot trim and rear seat trim, boot shown without trim in pictures *
Contact Address : [email protected]
Contact Phone : +81 90 6129 3399 - Phone me any time if your serious, im more then happy to answer any questions
Price : $8600ish
Shipping : $2500ish AUD
NO SWAPS FOR CARS, THIS IS A CASH SALE WHICH WILL BE SENT TO AUSTRALIA NO TIME WASTERS.
1993
Toyota Chaser
Original Color Maroon
Currently Custom Orange
Clock At 100,XXX KM
Engine changed roughly at 89,XXX KM
CST Wheels 17x9.5 +15
Real Dream Aero
D-Max bonnet vent
Various Graphics. Geki Style, Hoshino Car Style, can be removed
Front LED strobes
HPI FMIC Kit
Apexi Filter
Straight through exhaust system from cat back
Koyo 3 row alloy radiator
ECU Remap
Bride Bucket Seat
A/M Steering wheel
5 x Defi gauges, water, oil temp, oil pressure, boost, tacho with controller
Drift button
Greddy boost controller
Bloom Japan coilovers
Swift Springs - 14kg front, 12kg rear
Unknown 2 Way LSD
URAS tie rod spacers - extra steering lock
Ikeya Formula solid mount rear end
Adjustable rear camber arms
Rear floor brace
Rear Cusco aftermarket sway bar
Project Mu brake pads
Slotted front rotors
After market clutch
https://www.sau.com.au/forums/topic/298929-jzx90-drift-car/
    • Because people who want that are buying euros. The people with the money to buy the aftermarket heads and blocks aren’t interested in efficiency or making -7 power, they’re making well over 1,000hp and pretty much only drive them at full throttle  best way to way make money is know your customer base and what they want and don’t spend money making things they don’t want.
    • It's not, but it does feel like a bit of a missed opportunity regardless. For example, what if the cylinder head was redesigned to fit a GDI fuel system? It's worth like two full points of compression ratio when looking at modern GDI turbo vs PFI turbo. I'm pretty reliably surprised at how much less turbo it takes to make similar power out of a modern engine vs something like an RB26. Something with roughly the same dimensions as a -7 on an S55 is making absolutely silly power numbers compared to an RB26. I know there's a ton of power loss from things like high tension rings, high viscosity oil, clutch fan, AWD standby loss, etc but it's something like 700 whp in an F80 M3 vs 400 whp in an R33 GTR. The stock TF035HL4W turbos in an F80 M3 are really rather dinky little things and that's enough to get 400 whp at 18 psi. This just seems unwise no? I thought the general approach is if you aren't knock limited the MFB50 should be held constant through the RPM range. So more timing with RPM, but less timing with more cylinder filling. A VE-based table should accordingly inverse the VE curve of the engine.
    • I've seen tunes from big name workshops with cars making in excess of 700kW and one thing that stood out to me, is that noone is bothering with torque management. Everyone is throwing in as much timing as the motor can take for a pull. Sure that yields pretty numbers on a dyno, but it's not keeping these motors together for more than a few squirts down the straight without blowing coolant or head gaskets. If tuners, paid a bit more attention and took timing out in the mid range, managed boost a bit better, you'll probably see less motors grenading. Not to name names, or anything like that, but I've seen a tune, from a pretty wild GT-R from a big name tuner and I was but perplexed on the amount of timing jammed into it. You would have expected a quite a bit less timing at peak torque versus near the limiter, but there was literally 3 degrees of difference. Sure you want to make as much as possible throughout the RPM range, but why? At the expense of blowing motors? Anyhow I think we've gone off topic enough once again lol.
    • Because that’s not what any of them are building these heads or blocks for. It’s to hold over over 1000hp at the wheels without breaking and none of that stuff is required to make power
    • Dort sounds above 3k rpm are dorty 🤣 I might krinkle black the alloy 🤔
