Hey Guys
I have my SARD 850cc injectors up for sale which are in the stock fuel rail. They have had VERY minimal usage. These injectors are for RB25DET. The reason I am selling it because I would like a bigger fuel system. I am looking for $700
Contact me via PM or sms on 0406895948. Cheers
https://www.sau.com.au/forums/topic/298942-sard-850cc-injectors/
