Yew, i asked the misses for than xmas..
"Keep thinking tho!! At least your prices are coming down, first $700 pressies now $400, only one more try to get it right it seems :ninja:"
first one was a new snowboard.. second was the sways.. maybe i'll just get the rear sway?
"Keep thinking tho!! At least your prices are coming down, first $700 pressies now $400, only one more try to get it right it seems :ninja: "
what sort of snow board are you after Andrew? Remember what I sell.
Lib tech trs btx 159 2010 model
wasnt sure you did libtech tho. and 550usd or so when i go there..
No we do APO... sorry
see link http://www.apo-snow.com/site/index.php
Edited by andy65b
  • 1 month later...
I thought I'd dig this thread up a little as its somewhat relevant to what I need at the moment.
Is this the BC kit that was mentioned earlier? http://justjap.com/store/product.php?produ...at=0&page=1 Im looking to get either new springs or a coilover setup for my recently purchased baby M35, however Im doing it for the opposite reason to most; my car is sitting too low for me ! Id say the front lip is about 8cm off the ground and Im making far too much contact with every day obstacles, add in to the equation that I cant even get it up my drive way and it starts to make a little sense.
Ive got a few guys here in Adelaide chasing up parts for me, but I figured some of you might have suggestions as to an easy way to get my ride height up to something closer to standard. Is a new set of coilovers going to be the easiest way to get it done or are there some 'standard' springs out there which will actually fit properly and raise it up a little?
Hi Dunc, I recently fitted a set of BC BR coilovers to my Stagea, these were updated to correct some issues with the earlier designs. Most of the issues have been sorted, leaving you only having to re-use your original rear shock top mount. If you do buy, ensure that what you're buying is updated, not old stock, otherwise you'll have issues. The update is from September 09 onwards.
Regarding ride height, the BR coilovers that I bought could easily be set at factory height, as the rear springs are now longer; there were no issues fitting the fronts originally. The ride is quite nice and the finish is quite neat for the dollars you pay.
Hope this helps, Dale.
Hey Dale, Thats fantastic news - thankyou! If my mechanics aren't able to find anything I'll let the know about the BC BR's and go from there. Fingers crossed they do source something locally so I can get it done asap though ;)
  • 2 months later...
Hey Dale, Thats fantastic news - thankyou! If my mechanics aren't able to find anything I'll let the know about the BC BR's and go from there. Fingers crossed they do source something locally so I can get it done asap though :)
Did you source anything locally? I am wanting to upgrade the suspension too and Iam in Adelaide. Who is fitting the suspension for you?
Cheers
Also, which ones from JustJap to buy?
BR Type RS Series or V1 Design VS Series ?
  • 5 weeks later...
Cheers
I ended up puttin in V35 springs (These are the same as 350z springs), but Im still trying to work out how to get more height - my body kit just sits damn low. front and back is at ~12cm or so now, and whilst it makes a huge difference theres still a lot of stuff I cant negotiate without scraping. The BR's are the ones to go with if you're buying from teh BC range, however they wont get me any higher than stock.
I just had my local mechanics fit the suspension, its all pretty straightforward / standard :cool:
I just had my local mechanics fit the suspension, its all pretty straightforward / standard :ermm:
I have some standard AR-X springs if you need em....lol
The AR-X springs should sit me up ~40mm compared to stock, yeah? If so - definitely keen to give them a whirl! :down: I'll shoot you a PM.
Edited by Dunc
The AR-X springs should sit me up ~40mm compared to stock, yeah? If so - definitely keen to give them a whirl! :P I'll shoot you a PM.
please tell me you are kidding? do you want to drive a boat?
    • NoS, 2 of the big ones.
    • Oh, that's grim. Something bad has been happening there.
    • Put an endoscope down the hole and saw this. Not quite all around the bore but a good 60% at least. Chin to the chest and towards further disappointments I guess.
    • 2 does "sort of" applies, maybe......but looking at what parts would be needed for the swap to get engineered, registered, and insured, and basically that's everything under the car, the modifications the make it legal would be problematic and horrendously expensive, all for a street car that just cruises around and hits a few twisty roads on the weekends Also, from looking at the NSW rules and Regs, with all modifications that is required just to make the car safe and not twist itself to pieces, and then actually get registered for street use, may still be impossible nowadays As for 1, when you add in a fresh engine, fresh transmission, rear cradle and diff, tailshaft, suspension, brakes, cooling, and all the other fabrication required, your probably looking at up to $100k to do it right, all for a 20 year old MX5 that is over engineered and you would never be able to actually use the power it has on the street, much like your beastie, which I love, but you actually track that thing and can use all of its powers in anger, in a safe environment  Hell, the old Bogan Cruise Ship had more power than I could use on the street, and in hindsight, I went a bit silly on that thing, it didn't really need the 500hp it had for what I actually used the car for, it was fun, but basically unusable on the street if you value your licence  As for cams, yeah, I'll probably book it in for them to get installed and tuned soonish, like next month after MX5 Mania are back at work....... and yes, I've already sent a email to bin the turbo quote and quote instead to install cams and a new Fluidampr balancer that will suit the 2.5 better than the OEM 2.0 balancer that is swapped over for the 2.5 install, as the balancer needs to get pulled to time the cams it's a while your in there sort of thing I did think a bit about flex fuel for a laugh, but being na, and no where really around locally anymore to get E85, I've binned that idea, so no sweet sweet corn smells are set for the car I wish E85 was more of a standard fuel, it's better for the environment, better for tuning, plus that sweet sweet smell we all love As for fitting in the family, that's not needed, as everyone in the family already owns a car that can seat 5 humans comfortably enough, the MX5 is "my toy" As for buying a car that is already built, nah, I would rather pick and choose my parts, I enjoy the process, and in the big picture, the additional cost is well worth the enjoyment, and the occasional frustration, I get out of doing it, albeit with other people spinning the spanners, and me, just paying the invoice 🤣
    • Excuse me, but 2) does apply 1) Would also apply if you consider how much is spent in the alternatives. Also there's the option of 3), buy one pre-built that you can put your family in (it's me, it's my car)   That said, I went on a ~500km drive the other day. I didn't use anything more adventurous than 3rd/4th gear at about ~3000RPM and 50% throttle and I was going as fast as anyone has any sense doing on a public road, with enough grip to the point where I didn't want to go any faster. I was obviously under the limit of the current car etc etc. MX5 with 2.5 N/A to achieve the same speed would be more fun for any road scenario. Maybe consider cams. I wouldn't boost it. The use case is just not there and it won't actually make the car more enjoyable unless you really do plan on wringing gears from 1st to 3rd (at least) at 100% WOT on a public road to 150+kmh.
