Yew, i asked the misses for than xmas..
"Keep thinking tho!! At least your prices are coming down, first $700 pressies now $400, only one more try to get it right it seems :ninja:"
first one was a new snowboard.. second was the sways.. maybe i'll just get the rear sway?
"Keep thinking tho!! At least your prices are coming down, first $700 pressies now $400, only one more try to get it right it seems :ninja: "
what sort of snow board are you after Andrew? Remember what I sell.
Lib tech trs btx 159 2010 model
wasnt sure you did libtech tho. and 550usd or so when i go there..
No we do APO... sorry
see link http://www.apo-snow.com/site/index.php
Edited by andy65b
  • 1 month later...
I thought I'd dig this thread up a little as its somewhat relevant to what I need at the moment.
Is this the BC kit that was mentioned earlier? http://justjap.com/store/product.php?produ...at=0&page=1 Im looking to get either new springs or a coilover setup for my recently purchased baby M35, however Im doing it for the opposite reason to most; my car is sitting too low for me ! Id say the front lip is about 8cm off the ground and Im making far too much contact with every day obstacles, add in to the equation that I cant even get it up my drive way and it starts to make a little sense.
Ive got a few guys here in Adelaide chasing up parts for me, but I figured some of you might have suggestions as to an easy way to get my ride height up to something closer to standard. Is a new set of coilovers going to be the easiest way to get it done or are there some 'standard' springs out there which will actually fit properly and raise it up a little?
Hi Dunc, I recently fitted a set of BC BR coilovers to my Stagea, these were updated to correct some issues with the earlier designs. Most of the issues have been sorted, leaving you only having to re-use your original rear shock top mount. If you do buy, ensure that what you're buying is updated, not old stock, otherwise you'll have issues. The update is from September 09 onwards.
Regarding ride height, the BR coilovers that I bought could easily be set at factory height, as the rear springs are now longer; there were no issues fitting the fronts originally. The ride is quite nice and the finish is quite neat for the dollars you pay.
Hope this helps, Dale.
Hey Dale, Thats fantastic news - thankyou! If my mechanics aren't able to find anything I'll let the know about the BC BR's and go from there. Fingers crossed they do source something locally so I can get it done asap though ;)
  • 2 months later...
Hey Dale, Thats fantastic news - thankyou! If my mechanics aren't able to find anything I'll let the know about the BC BR's and go from there. Fingers crossed they do source something locally so I can get it done asap though :)
Did you source anything locally? I am wanting to upgrade the suspension too and Iam in Adelaide. Who is fitting the suspension for you?
Cheers
Also, which ones from JustJap to buy?
BR Type RS Series or V1 Design VS Series ?
  • 5 weeks later...
Cheers
I ended up puttin in V35 springs (These are the same as 350z springs), but Im still trying to work out how to get more height - my body kit just sits damn low. front and back is at ~12cm or so now, and whilst it makes a huge difference theres still a lot of stuff I cant negotiate without scraping. The BR's are the ones to go with if you're buying from teh BC range, however they wont get me any higher than stock.
I just had my local mechanics fit the suspension, its all pretty straightforward / standard :cool:
I just had my local mechanics fit the suspension, its all pretty straightforward / standard :ermm:
I have some standard AR-X springs if you need em....lol
The AR-X springs should sit me up ~40mm compared to stock, yeah? If so - definitely keen to give them a whirl! :down: I'll shoot you a PM.
Edited by Dunc
The AR-X springs should sit me up ~40mm compared to stock, yeah? If so - definitely keen to give them a whirl! :P I'll shoot you a PM.
please tell me you are kidding? do you want to drive a boat?
    • Don't "upload" the pictures. Just copy the picture direct from somewhere (I usually am pasting screenshots or something else that I have on the clipboard as an image, not as a file" and just paste it direct into the post editor. Just like you were pasting it into a Word doc or something. You can't damage something if you lift it where you are supposed to. If you look carefully at the correct jacking points, you will see that they are reinforced right there. And nowhere else. That is where the "foot" of the factory jack is supposed to sit. That's why you need rubber pads with slots. 10mm might not be deep enough. Note also that the slots are not required if the pinchweld has already been slammed flat. You could just lift it at the correct spot with a flat pad, because the damage is already done. No point in making worse though, if it is recoverable. IF. Yes, that's called a chassis rail. You can lift carefully on these, if you spread the load. A decent block of wood is good. But keep in mind what I said before. Any time you start doing this sort of thing, you are off the normal path and into "be bloody careful", because it is obviously not stable. Dumb. The refinforcement is already there. See above.
    • yeah looks like they've been lifted there previously but with solid not slitted rubber blocks. I'd just bend them back (combination of vice grips or hammer with some sort of drift, then hit the area with underbody protection paint. As for the siderails, I'd call those chassis rails and that is exactly what I meant about being careful with the balance point. You can probably lift off them at the point where the 2 pieces overlap, but you need to be careful with the forward balance of the car if you do when the engine is in....sills are a better choice. I guess you could weld some reinforcement in the sill area near the jacking points but it shouldn't be necessary if you use blocks with a slit. If you do want to reinforce it I'd use square section equal or taller than the seam and then just use flat rubber blocks for lifting
    • driver side sidemember and jacking point (looks the worst by far) driver side rear jack point passenger side sidemember and jack point passenger side rear jack point   Ignore my mug on the last photo. Turns out I was just too stupid to properly use the forum's attachment feature previously
    • Fk me, I guess next time I will try to use the onsite attachments feature. I find it hard to work with so far though because I can't move the images to where I want them to be. I will try to make a separate post with just images. As for lifting. The work I need to do for now involves the exhaust and engine mainly, so the arm covering the jacking points is not a problem. But I don't want to bend in the whole sill or underfloor by lifting the car at the original jack points. I found some rubber blocks, 125 by 125 with a 10mm wide and 10mm deep cutout, which I'm hoping will work for not hitting the jacking rail. The sidemember, as seen in the service manual, are the rectangular frame rails that come from the front of the car and go alongside the gearbox and downpipe. Those that get crushed inwards if you use them for a floorjack. They are already slightly bent in from being used to hoist by other people. I think cutting off the jacking points and welding or bolting on a reinforcement plate along the sill might not be a dumb idea. Or is it dumb?     A 2 post hoist is what I'm gonna work with, but not for any underbody work, just leaky engine and exhaust work so far. Depends on what else I find that might need immediate attention. For metalwork on the sills I think I'd just bring the car to a panel beater. What's your take on getting rid of the original jacking rails and putting reinforcement plates along the sills?
    • Yeah titanium always looks cool but I don't need that, just regular pipes would be fine. But I am really struggling to find any full hardpipe kit that is still for sale.
