I am still having problems with the front left wheel brake activating when cornering hard around right corners. As I mentioned before, it started after a wheel alignment but the front suspension was only checked and didn't need adjusting; only the rear was adjusted.
The VDC light flashes when the brake activates. The wheel doesn't skid during this but the brake comes on lightly from 1 to 3 times during the event. I has me stuffed as I thought the VDC only operates on the driving wheels; that's what makes me think it is a problem with the abs and why would it be affected if the front suspension was not touched!
Nissan service can't help as they have nothing to check VDC as the 350z doesn't have it so they say.
Any help would be appreciated. Thanks
https://www.sau.com.au/forums/topic/298980-problems-with-abs-or-vdc-activating/
Not sure what the dealership is talking about, 350Z track-specs came with VDC standard, If it thinks you are understeering, the system will actuate brakes on the front outside wheel in an attempt to regain front-end grip.
Thanks for that and will follow it up with the dealer as it seems that the dealers should have software to reset the VDC
Sounds right, if the system thinks that you're understeering. It'll try and brake the inside front to pull you back into the corner.
The Traction Control System only works on the driven wheels.
The Vehicle Dynamic Control system works on all four brake calipers.
ABS can only release brake pedal pressure. If your foot is not on the brake, the ABS could do anything it wants and nothing would happen at the caliper.
The TCS cuts power by closing the electronic throttle. The VDC can compress any of the 4 calipers independently, and does not require brake pedal inputs.
When you're "cornering hard and the inside front caliper grabs the rotor", are you on the brake? If not, its not a pure ABS issue.
Bear in mind that the TCS asnd VDC both rely on the ABS wheel sensors to tell their processors how fast each wheel is spinning. The VDC unit, aside from the ABS sensors, also has a yaw sensor to tell the processor how fast the body itself is turning.
If any sensor is sending erroneous data, it'll take erroneous actions.
If you drive in a straight line and just jump on the brakes, what happens? Does the ABS perform normally, or does your left side front caliper trigger ABS faster than the other wheels? If the car behaves normally when you're going straight, then I'd be more concerned about a yaw sensor or VDC processor issue.
Take your car to a Nissan dealership that's populated with less retarded service technicians. If you're in an especially bad mood call up head office to complain about their gross lack of product knowledge.
The 350Z Track has always come with VDC. I've still got my brochure from back in 03, if you want to make a photocopy to shove up their arses.
Thanks for the comprehensive answer - I really appreciate it and will try the Nissan dealer again and hopefully will talk to someone who has a brain!!!!
    • It only looks tidy, as most of the stuff that was on the whole back wall, is now in the trailer to go to the tip, or has been shoved in my 2.2x2.4m "Spare parts room", and now I can't get to anything in there Ha ha ha I could definitely do with a bit more space, but I'd just end up with your problems I'm going to enclose the car port beside the garage, and move a lot of stuff into it I think. OR... It will be setup as a fabrication area, and the main garage will have parts storage in it. I'm not sure yet... Need some pictures of that big shed you've got with the bikes and Skyline in
    • No. I think it's gone. 😭 I think you can get body coloured ones on eBay so I think I'll get one of those... Or just hang a red ribbon from the hole and whack a TOW sticker next to it.
    • Can't say I've had a bad experience with one on my car, then again it only gets washed once or twice a year... The wheels on the other hand, get a good spray often due to my shitty dusty pads.
    • @MBS206 thats pretty neat and tidy to me!  I'll get a photo of mine when I'm out there next. It might require multiple photos to understand the scale of the atrocities though... In total I have 4 sheds of varying sizes and layouts. Main shed is 14x8, second shed is 3x8, third shed is 11x2.5, fourth shed is around 6x4.  All are pretty much full.   The main goal of my cleaning tsunami is to make the main shed predominantly car and motorbikes only. Second shed is my metal fab room (2 x bench grinders, drill press, bench belt sander, metal band saw, scrap metal storage and some of my garden tools.  3rd shed is more bigger garden stuff, storage for engine crane, jack stands, concrete grinder, concrete mixer, air compressor lives there, and it now has two 2mx2m pallet racking shelves with itemised boxes holding building stuff, electrical stuff, plumbing stuff, etc, etc.  The 4th shed is Ryobi electric ride on mower, mini boom sprayer, ancient Kubota tractor, more garden stuff!  I have got a lot of shit....  Then there's the pool house (8mx4m) and the pool pump shed (4mx4m).  I built all of the sheds over the 11 years we've been here.  The main shed was a Ranbuild kit, the rest are all custom made to fit the areas available. Building the main shed taught me a LOT as I had no idea about building anything prior to that!  I've still got one more in me. It will be my man cave which I poured the extra concrete for way back when I poured the concrete for the main shed. The idea is the Skyline will be a centre piece of the main cave once (if...) it's finished.  I told my now 14 year old son yesterday that I will 100% drive him to his year 10 formal in 2 years. Still a long way off but at least I now have a date to work towards! 🤣
    • Modern oils are amazing. Add tyres to that as well.
