sturb25 Posted December 5, 2009 Share Posted December 5, 2009 Im finding that my stagea is to far between gears and i cant get quick gear changes. Is anything available to make my gear changes quicker. ie short shift kit. If so where do i find? Link to comment https://www.sau.com.au/forums/topic/299056-are-short-shifters-available-for-series-2-rs4-s/ Share on other sites More sharing options...
lilcrash Posted December 5, 2009 Share Posted December 5, 2009 i think that c's makes one WGNC34 Nissan - Stagea - RB26DETT - WGNC34 AU $ 301.47 thats from nengun Link to comment https://www.sau.com.au/forums/topic/299056-are-short-shifters-available-for-series-2-rs4-s/#findComment-4972828 Share on other sites More sharing options...
pipster11 Posted December 6, 2009 Share Posted December 6, 2009 my rs4s came with one in it and the prev owner said nothing about haveing a short shifter i'd be looking at ones for 33gtr's cos thats the gearbox thatsa in it apparently (not sure what the 260rs's run tho) maybe just get a stock one out of a gtr and see if its got a shorter throw than a stock stag one Link to comment https://www.sau.com.au/forums/topic/299056-are-short-shifters-available-for-series-2-rs4-s/#findComment-4973151 Share on other sites More sharing options...
mike40sydney Posted December 6, 2009 Share Posted December 6, 2009 my rs4s came with one in it and the prev owner said nothing about haveing a short shifteri'd be looking at ones for 33gtr's cos thats the gearbox thatsa in it apparently (not sure what the 260rs's run tho) maybe just get a stock one out of a gtr and see if its got a shorter throw than a stock stag one i used to shorten my sticks by cutting 50mm off and rethreading them when i had the 240k door i found that most nissan boxes had identical sticks .it made it hell of a lot better and cost fruck all regards mike Link to comment https://www.sau.com.au/forums/topic/299056-are-short-shifters-available-for-series-2-rs4-s/#findComment-4973316 Share on other sites More sharing options...
pipster11 Posted December 6, 2009 Share Posted December 6, 2009 i used to shorten my sticks by cutting 50mm off and rethreading them when i had the 240k door i found that most nissan boxes had identical sticks .it made it hell of a lot better and cost fruck allregards mike i know that if you put a 32 shifter into a 31 it shortens the throw cutting off some and rethreading it is a bad solution as it doesn't change the pivot points, only the height of the knob. a propper short shifter keeps the same height but the distane traveled is shortened Link to comment https://www.sau.com.au/forums/topic/299056-are-short-shifters-available-for-series-2-rs4-s/#findComment-4974066 Share on other sites More sharing options...
sturb25 Posted December 7, 2009 Author Share Posted December 7, 2009 i know that if you put a 32 shifter into a 31 it shortens the throwcutting off some and rethreading it is a bad solution as it doesn't change the pivot points, only the height of the knob. a propper short shifter keeps the same height but the distane traveled is shortened My point exactly!! If i wanted a shorter gearstick id shorten it. That wont change the throw distance. some people have no idea! Link to comment https://www.sau.com.au/forums/topic/299056-are-short-shifters-available-for-series-2-rs4-s/#findComment-4974915 Share on other sites More sharing options...
