I dont know what the probl;em is,
when its cold i cant run it at all
it sounds like its suking sooo much air its not funny,
i have ba boost cointroller set to 8psi and 14psi,
8 psi goes harder than the 14 cause when is on 14 it just pops and farts all over the place.
also i dont think a rb25det running 8psi sould get beatn by a n/a 2001 astra.
im really starting to get shitty cause its only 3 minths old and runs like a heap of shit.
mods done
3in HKS super dragar exhaust from turbo
Turbosmart 2 stage boost controller
Water injected onto standard cooler
Fuel cut defender
Pod air filter
BOV
was wondering if there is any one in the hills district that could come and have a look at it, its wurrying me and itys a pain when you get beating by a S**T box.
R33 GTST
Late series 1
Thanx Craig
0410 635 901
https://www.sau.com.au/forums/topic/29906-car-runs-like-a-dog-0-need-help/
yea serviced it about 3000 ago myself, i dont trust any1 else with a car like that.
Jay - yea its aftermarket, not sure what type just was sitting in my mate garage at home, how do u adjust it?
i could email you piks if you want
Like J said your BOV could be leaking air therefore making your AFM readings incorrect. Lots of people experience stalling issues because of this.
As for the Flat spots at high boost I'am with muffas in saying that your plugs could be F*cked or they may not be gapped for high boost (.8). Remember that the inlet cam changes it posi to increase the pull at 4500 rpm which will also be contributing to your flatties becuase the fuel fixture really get rich when this happens.
So i guess if i was you i would:
1) close after market bov, or borrow standard one?
2) Check & gap plugs
3) Wind the boost down to 12psi (R33 stock computer will perform ignition cut (what people call boost cut) any where from 11psi to 14psi depending on the particular car) I am not sure if you fuel cut defender will stop this?
4) Get SAFC to lean out A/F ratio at higher RPMS.
Hope this actually helps & iam not just full of Sh*T :-}
Good luck with it all
OK, before getting a (apexi Super AFC used for adjusting A/F ratio's about $700 bucks? not sure)
Try turning your boost down to about 12psi, In most cases the standard turbo on an r33 will not run efficiently at 14 psi and may even produce less power at 14 psi. Untill you get you car dynoed at the different boost levels you wont know for sure but i would run 12 psi for now to try and resolve your flat spotting.
Also see if you can get that stock BOV to try and solve your starting issues.
If turning the boost down does not solve your problem it could be that one of your coil packs are shagged :-{, once again getting one of a mate to do some tests would be your best bet as you dont want to waist money buying coil pack (about $125 sh)...
I say sell your car and buy an astra. :)
But seriously, how much research did you do before just upping the boost to 14psi on the stock cooler? Then you just chucked a BOV you had lying around on?
And now you're having problems? What did you expect?
What sewid means is:
The stock cooler is very un-efficient, therefore when your boost gauge says that you are at 14psi your turbo is probably (for args sake) pushing out say 16psi or maybe more!
I know a lot of people will tell you that you can run 14 psi of a stock r33 turbo and to my mind they are right, just make sure that you have a after market cooler that is reasonably efficient before doing so.
Remember: You might achieve more power by running a little less than 14psi with a stock turbo...
Right.
The stock cooler is not going to be able to cope with 14psi. The air is therefore going to be less dense and you will not be seeing the performance you should.
To compound this, is your pod filter in a enclosure or partitioned off from the engine bay? If not then again you will be sucking in enormously hot air from the engine bay.
All of this spells hot air in the engine, meaning crap all improvement over a stock car.
    • Yes...but look at the numbers. There is a tiny tiny fraction of the number of Joules available, compared to what is used/needed. Just because things are "possible" doesn't make them meaningful.
    • Thanks for taking the time to post that ! If anything changes or happens please do update us.
    • Somehow Vertimass/Oak Ridge National Labs has figured out a catalyst that can convert ethanol into C9-C10 hydrocarbons in basically a single step without ending up with a bunch of ethylene or similar waste products: https://patents.google.com/patent/WO2023224867A1/en I still don't think anything like this will keep us from needing to transition to EVs regardless along with all kinds of other electrification, but things like this will go a long way towards alleviating the problem of how to electrify things like planes. Renewable diesel is seemingly an easier problem as well, Chevron is already running refineries for the stuff and the primary feedstock is tallow and other waste fats from agriculture.
    • Ok so I have sorted everything with my uniclutch and  i can offer up a bit of feedback and some things that might help others.    I found problems with factory damper line. Weird shit and had trouble with peddle adjustment    I used this https://au.gktech.com/products/r33-gts-t-skyline-braided-clutch-line?_pos=2&_sid=22b01b9b9&_ss=r Also when adjusting peddle leave a bit of play. You can get into a over stroke condition easy.. Make sure you can push the slave forward after adjusting to confirm fluid can return to master then you will need to pump it up heaps…..not sure why but that’s how it is.    last thing the splined adapter is machined perfectly. If your input shaft is old like mine was I would put a bit of valve grinding paste on it and stroke it like a 15 year old. Just to give it a tad more clearance and to better match it to the spline.    reason is on a near flat shift I have had situation where the peddle returns a millisecond after you lift from the clutch. No slip or anything but I reckon this is due to tolerance on the spline being way tighter than stock clutch and binding for a sec. I think this will go away but also my spline was old. Box is old so I guess I should have checked better. It’s a super neat fit.    it feels light as and holds awesome without any noise
    • My Fuga Hybrid is JDM, 2014 model but very similar to the V37 from the looks of things..same platform just physically larger and very comfortab;e
