Any One Know If I Can Road Tow/flat Tow A Defected Car With Suspended Rego
yer looking at buying a car thinking of just road towing it to a RWC tester
Doubt it mate. Pretty sure flat towing is illegal these days even if it had rego.
my mate says this my mate says that hahahaha
if u resurch you can find stuff but not sure if i can do a defected
http://www.vicroads.vic.gov.au/Home/Regist...eredVehicle.htm
Tow behind a registered vehicle
You can tow the unregistered vehicle behind a registered vehicle. Road Rules Victoria 1999 (no. 295) apply when towing. They are:
you must safely control the towed vehicle (you can be on a probationary licence)
the brakes on the towed vehicle must be working when you are using rope, chain or wire
the maximum space between the vehicles is 4 metres (if either vehicle is a motor cycle, the maximum is 2.5 metres)
you must display a flag (minimum 30cm square) attached to the rope, chain or wire.
Edited by dreadr31
I just towed mine behind my old mans car to local noise tester when mine was epa'd for noise and I didn't clear it in time. Was it legal - I don't know.
Really just drove behind him with the rope there as you need the motor running to get brakes and power steering anyway.
Ring few small tow truck operators, should be able to get it done for about $50, a lot less hassle.
Also the fact it is defected means it is not allowed to be on the road beacause it is not roadworthy, i would assume that would negate the unreg rule.
I believe that if car rego is suspended then car is classed as unregistered. I would advise to contact Vic Roads and enquire with them. Possibly gettting the Unreg permit to transport car to RWC.
I am not sure about the flat towing I thought it was ok but it's hard to keep up with all the changes every month. I'm not out to hasle someone trying to do the right thing.
Last time I went to pull over a a car flat towing ended up being stolen car and apprehended 7 offenders for multiple theft of Cars. Put a stop to ALOT of stolen cars in my area. Long day as worked almost 20 hours straight dealing with it.
^ You can't get an unreg permit for a suspended car :ninja:
It's illegal, i tried that when i had a suspended rego due to EPA. The Engine # flags right off on the VicRoads system and they won't issue the permit.
Yep. Sure is. Towie Jack told me road towing - 100% illegal.
I never knew that which was interesting to know.
Tow truck or nothing.
Ash - it was illegal when I first started in the towing industry back in 1993. Looks like the laws have changed.....
I'd say a phone call to vicroads would be the best bet.
good luck with vicroads atm average wait time......20 mins(well for last 2 days anyway, but doubt it will get better before xmas now lol)....thats if they even tell you the right information. :)
id only i could invoice them for my time...
    • Curious to why you're not getting Jesse to do the exhaust, seeing that he has just done 2 GTRs with Aes valves.
    • What extra parts are you thinking you'll need to run e85 compared to e30?
    • I'm not aware of e30 in Australia, but I'm pretty sure e85 is still around. You really want a setup with an ethanol sensor so you can run any mix of ethanol depending on what you can access. Fuel Check NSW app shows 14 site in sydney metro with e85. What are you adding, will you put in bigger turbs too? Apparently the wastegates are pretty small and can't bypass enough as you run more boost.  I'm sticking to 1.3 bar with 98 on the standard turbos with my tune on advice from the tuner, and boost drops significantly in the top end; apparently larger turbos with larger wastegates are needed to get anywhere meaningful from there.
    • Amazing work Duncan! It is never easy to pick up someone elses project and work all the parts out that are missing
    • Hey Ppl,   I am about to tuned my Infiniti Q60 with E-85 and if you can tell me some location where I can top up my car that would be great.   But my other question, is E-30 available because this tuned requires less mods parts and any info you can offer would be greatly appreciated too!!
