Any One Know If I Can Road Tow/flat Tow A Defected Car With Suspended Rego
yer looking at buying a car thinking of just road towing it to a RWC tester
Doubt it mate. Pretty sure flat towing is illegal these days even if it had rego.
my mate says this my mate says that hahahaha
if u resurch you can find stuff but not sure if i can do a defected
http://www.vicroads.vic.gov.au/Home/Regist...eredVehicle.htm
Tow behind a registered vehicle
You can tow the unregistered vehicle behind a registered vehicle. Road Rules Victoria 1999 (no. 295) apply when towing. They are:
you must safely control the towed vehicle (you can be on a probationary licence)
the brakes on the towed vehicle must be working when you are using rope, chain or wire
the maximum space between the vehicles is 4 metres (if either vehicle is a motor cycle, the maximum is 2.5 metres)
you must display a flag (minimum 30cm square) attached to the rope, chain or wire.
Edited by dreadr31
I just towed mine behind my old mans car to local noise tester when mine was epa'd for noise and I didn't clear it in time. Was it legal - I don't know.
Really just drove behind him with the rope there as you need the motor running to get brakes and power steering anyway.
Ring few small tow truck operators, should be able to get it done for about $50, a lot less hassle.
Also the fact it is defected means it is not allowed to be on the road beacause it is not roadworthy, i would assume that would negate the unreg rule.
I believe that if car rego is suspended then car is classed as unregistered. I would advise to contact Vic Roads and enquire with them. Possibly gettting the Unreg permit to transport car to RWC.
I am not sure about the flat towing I thought it was ok but it's hard to keep up with all the changes every month. I'm not out to hasle someone trying to do the right thing.
Last time I went to pull over a a car flat towing ended up being stolen car and apprehended 7 offenders for multiple theft of Cars. Put a stop to ALOT of stolen cars in my area. Long day as worked almost 20 hours straight dealing with it.
^ You can't get an unreg permit for a suspended car :ninja:
It's illegal, i tried that when i had a suspended rego due to EPA. The Engine # flags right off on the VicRoads system and they won't issue the permit.
Yep. Sure is. Towie Jack told me road towing - 100% illegal.
I never knew that which was interesting to know.
Tow truck or nothing.
Ash - it was illegal when I first started in the towing industry back in 1993. Looks like the laws have changed.....
I'd say a phone call to vicroads would be the best bet.
good luck with vicroads atm average wait time......20 mins(well for last 2 days anyway, but doubt it will get better before xmas now lol)....thats if they even tell you the right information. :)
id only i could invoice them for my time...
    • I hope one day I can do it like you. Your engine looks great.
    • If there's nothing else I can do I'll probably do something like that Someone on the internet said that ca20s and ca18 engine blocks are the same and that you can use a ca20 engine block and put ca18det parts to make a ca20det Do you think this is possible or will it damage the engine?
    • Yeah, I did some research and found out that some things are different.
    • Makes sense, thanks! Consider me very impressed. And I very much appreciate the effort in documentating all of it. You'd be surprised, or maybe not, how many people this reaches who search for things online. Anyways, I shall continue to read all of it, understand maybe a quarter, and hope that some of it sticks if I ever end up in a situation where it's relevant
    • 'Did' work on them is more accurate ~ on the R31 Skyline forum, you can spot me as 'Solder'... I've written quite a bit about the 4R01 boxes there, and I ended up reverse-engineering the older TCU type operations, so we could fudge a custom TCU to pull off other tricks...and like all things, when you do it a lot, see the failure patterns, have to find parts etc etc, your head ends up filled with whys and wherefores... there was a reason Nissan went with these in more than 60models over 16+ years... all in all, the JR401E based design is an interesting study, as Nissan changed things over the years in a never ending battle against them lunching on themselves <grin>...by the time the RE4R01A rev.C came out (often referred to as RE4R01B), they'd more or less perfected the design...
