Hello
I have been searching and found nothing in relation to my question. Just a few key words here and there and other very useful info.
I just installed my M-300 plx wideband. I have the schematic to wire in the analog signal for closed loop operations.
to anyone who has done this... did you wire in the 20ohm resister and if so where did you tap into. I see nothing listed under the rb25's ecu pinout for o2 heater. I was thinking it could be for an RB26 setup.
I'm running Power FC standard with FC datalogit.
ps
could I also just insert the analog wire from my plx analog output into the FC datalogit analog input?
https://www.sau.com.au/forums/topic/299088-wiring-for-closed-loop/
not sure how those widebands need to be wired but for any wideband it should be a simple case of wiring it up to switched and fused power for the controller and the heater then using the analog ouput(s) for closed loop or for your datalogit. heater power doesnt have to come from the ecu
if it has 2 programable outputs, use 1 as a narrowband signal for the ecu (make sure its turned off while tuning) and use the other as a 0-5v into the datalogit for tuning
Edited by JonnoHR31
Roger that.. yea I remember reading to turn 02 feedback off while tuning lol... I forgot to do it the other day and the wideband froze up.
thanks that is pretty much what I thought, just wanted to clarify before I went and blew up my PFC.
ps
does NOVA stand for Northern Virginia?? if so im from Maryland and I use to hang out with the slideways crew while there. I think I seen your car on a U.S east coast forum before.
Edited by BigGameHit
    • I also just ordered some Frankenstein bolts and side mounts to fit a hard top Just in case I do find one, basically so it doesn't need to be fixed to the car with only the front latch.......and then gaffa tape to keep it in place for the RTN journey from wherever I get it
    • If your temps are fine now, you probably won't have any issues with where your vents are as they don't look right up at the windscreens high pressure area, so any differences when giving it the beans for extended happy laps would be minimal, but, they should vent heaps when stuck in traffic  Much like how that reverse cowl on my SS let "visible" heat out when stationary, but, because it was basically at the windscreen my coolant temps on the Hwy actually raised because air was being fed into it at speed (110kph), to only come back down to around 90° when I got off the Hwy And your 100% correct about the NC currently not needing vents, but, if I was to add a turbo, and a oil cooler and intercooler in front of the condenserand radiator, and then take it to the track???? It is apparently a recommend requirement if I don't want to worry about coolant or oil temp issues, but, any of the above are possible scenarios, over time As it sits now, with the triple pass radiator and stock air conditioning system, I have absolutely no issues with either temps or air conditioning efficiency, I've been basically daily driving thie car for the last month, both on the Hwy, and peak hour, bumper to bumper traffic, but, that's pretty much expected from basically a standard engine  Talking about no issues daily driving, it was 39° the other day and I was sitting in bumper to bumper traffic on the M5 and then M7, with the top down, and with the air conditioning blowing nice cold air on my feet, balls, and face, well, there was one issue, my head and arms got pretty sun burnt Note to self: leave a hat and sunscreen in the car for such days 🤣
    • I would agree, unless you need something specific to the HV motor/battery side repaired or investigated, any mechanic will be able to perform normal services, but if you prefer, maybe look for a mechanic who regularly services/repairs Nissans, the VQ engines are pretty common in the Nissan lineup.  Sorry, I can't make any suggestions, I don't live in Vic.
    • Some of them keep working fine. 9 out of 10 of them end up causing an absolute misery bleeding the system and get thrown on the workshop floor in a tantrum and never thought about again because they were never really needed and just added crap to the car that we could have done without. Same-same with HICAS, A-LSD, and various other stupidities that over eager 10x engineers thought we had to have.
    • Not required but appreciated. Super Coppermix Twin even the non-competition model feels like the pedal is noticeably heavier than stock which was pretty well judged IMO. I'll be swapping in the Nismo operating cylinder soon to see how that feels.  Personally I haven't felt anything that justifies replacing the damping loop, at least compared to more modern stuff where the clutch delay valve is actually quite noticeable.
