My dash top gets so hot it's a wonder that the instruments work atall does anyone know where I can get a dashmat for an R34GTt from dont mind paying to have one fabricated but I don't have a clue where to start looking.
Any leads or ideas anyone ?
Edited by BASHO
https://www.sau.com.au/forums/topic/299130-hot-dash-need-mat/
going on your other post if you get a dashmat your automatic lights wont work nless you get that piece of the dashmat open... if you park your car in the sun during the day id suggest to use one of those window visors... much better security wise aswell... and carpet on your dash doesn't look the best in my opinoin
Automatic lights?
The centre LCD lights on my climate control unit and in my head unit appear to be controled by a sensor during daytime running which dims them down to the point of being unreadable Space Goat has kindly advised me where this sensor is (left hand corner of the dash as you sit in the drivers seat) it looks like a small, about 10mm diameter, solar panel.
I am going to gleefully cover it up to see if it will undim the two LCD panels so I can actualy read them in the daytime.
the sensor does not seem to control anything else and I have no idea if there is any on off control for it though there may be something in the climate control unit if I could only figure it out. :)
Interesting - I've been reading the R34 Workshop manual and they talk about an 'automatic' setting for the lighting switch - but I'm buggered if I can find anything like that. Playing with the sensor on the dash seems to do nothing with interior or exterior lights - maybe mine's busted? I might have to run through the diagnostics in the manual - but without having this switch in the 'automatic' position, I'm not sure it's going to help me...
its climate control sensor, unless you have a aftermarket alarm or light sensor fitted
use the silver faced sun shade, the dash mat looks crap , even custom ones
At the risk of being labeled an ignoramous WTF does the climate control sensor actualy do ? I have on off temp variable aircon and ?
There is no auto switch (at least that I can find) to control the centre LCDs lights though they will brighten if you go into a dark area from daylight but during normal running daytime they're crap I can't see squat.
I use a sunsahade whenever it's parked in the open, farkit it's Qld, but driving around the dash top gets hotter than a burning witches tit and I don't give a rats if it looks crap , I tend to agree actualy , but it'll diffuse the heat and thats gotta be worth it.
:D
dash mat might look a bit crappy but it will mean that in 10 years time the dash won't look like crap. i have always used them in all my cars (except my 2 imports) because they also reduce a bit of glare off the dash and make it a touch easier to see out the windscreen at certain times of the day when the glare off the dash reflects up onto the windscreen.
as for where to get one made, go and talk to the people at your local autobarn, etc. they should have a supplier that will make custom mats and may be able to make one up for you.
Cheers, I'll givem a go :D
I got one for my R33 from these guys last year: Accessories Online
They dont list R34, but it would be worth asking. Where I was working meant I had to park in the sun all day and the mat helped alot... Yes it comes with the sun sensor cutout...
There is also a CF mat available I saw on Yahoo Auctions a while ago, but I cant find it anymore...
    • My take on gg2 48mm, 54mm, 58mm, and 62mm compressor map for same size compressor vs gg1 : All gg2 only outflow gg1 above 20 psi. As all g gen 2 surge line at lower left of comp map move to the right, all gg2 sacrifice spool vs same size gg1, surge line move to the right worst for 54mm gg2. So for same size compressor if you want best response, use gg1, if you want max hp at >20psi use gg2 but you will be laggier vs same size gg1. Max compressor efficiency drops to max 75% on all gg2 vs max 76%-80% of same size gg1. Iirc lower efficiency means hotter iat less dense air so lower hp at same operating point of comp map. Also curious why gg2 is mapped to lower max rpm vs same size gg1 (only 48mm size both gg1 gg2 mapped to same rpm) : 54mm gg1 165,000 rpm  vs  gg2 160,000 rpm. 58mm gg1 150,000 rpm vs gg2 140,000rpm. 62mm gg1 145,000 rpm vs gg2 140,000 rpm. If gg2 can safely spin to gg1 rpm then they can flow a bit more than as mapped. Good thing that all gg 2 interchange compressor and turbine housings with same size gg 1. So gg1 owners can buy gg2 chra only if planning to boost >20psi.
    • My stuff is all with Shannon's, granted, I don't really have imports I'm driving on the road, however, I've had multiple cars at the same time with them. Presently we have the Landcruiser on laid up cover, Sarah's Kluger on full cover, and the house insured. About 18 months ago Sarah wrote her Subaru Liberty GTB off, insured with Shannon's, and the payout, and buy back of the wreck was super quick. In 2020 we had the VF Commodore totalled in a major hailstorm. Storm was on the Saturday, I called on the Sunday and lodged it, vehicle was towed on Tuesday night, assessment team called on Wednesday to say it was a total loss and get payout details, money was in the bank on Thursday morning. Have had a few other claims both at fault, and not at fault, over the years, and never had an issue with them.   Funnily enough, they're also the cheapest insurer I find for things like Sarah's Kluger.   I will say I'm less impressed dealing with them lately around "the experience", as a lot of their staff that you deal with aren't car enthusiasts. Shannon's has a much more main stream feel ever since they decided to become "big corporate", laid a heap of staff off, and then hired a bunch of non enthusiasts. At the same time they've been making a push to be less "call us and we'll personally have someone who cares help" to "hey, this computer can do stuff for you" and are trying to get more square pegs to fit round holes. (That's just the vibe I get from them). Again, have had no issues with claims with them, but get a bit of a "less personal" feel from them.
    • A thing I wasn’t happy with with enthusiast was during the initial phone call they told me they’d insure it for 130k but needed photos.   I then sent them photos and they told me $80k as there were other cars either similar modifications available for around that price, I told them to send me the links to said cars so that I can buy them. i then sent the modification list with prices of the parts (no labor) and the price then came to 115k, which is still shy of the 130 that was agreed in the initial phone call
    • Ask me a bit later this week before payday
    • I agree that delayed payment probably isn't the most suitable solution. It seems a solid complete transaction would be best. As I wouldn't be using this sale as a line of credit that would typically earn interest, we can probably arrange a much cleaner single transaction deal. I can do $92.52 today. Would you prefer EFT, or Cash on Pickup?  😛
