hey everyone,
the car is blowing white smoke on heavy decel and if im just crusing around with out coming on too boost
and change gears it gets a very small puff of white smoke, i had a comp test on the w/e before we dynoed it
with interesting results
1. 165
2. 175
3. 180
4. 175
5. 175
6. 180
when we removed the plugs there was no sign of oil(or burning oil) on any plugs they were very clean and even burning
my tuner seems to think it s turbos??
is it possible to be valve stem seals??
it doesnt blow any smoke on start up or if its been sitting
i tried searching for the results but nothing that helped me out
russell
Edited by RUSSMUSS
https://www.sau.com.au/forums/topic/299132-r32-gtr-oil-smoke/
Possibly stem seals...... After a decent drive try pulling over and leaving car to idle for a couple minutes. Then while watching in the rear view give it a swift rev up to say 3000 rpm and off. Will it give a puff of white smoke on revs declining ?
hey everyone,
1. 165
2. 175
3. 180
4. 175
5. 175
6. 180
russell
How old or new are your turbos?
its going to be the rear seal on one of the turbos. oil is passing the seal when there is no back pressure in the rear oulsing. oil pressure is overcoming the pressure in the housing and then a bit of oil passes the seal and smokes in the hot turbine housing.
I had this happen with the last turbo I bought. I rebuilt it myself and no more smoke
cheers!
