Had an awsome time at mt panorama yesterday running in the supersprint with fellow sau members from canberra. Unfornatually we all had a few dramas with either problems with the cars or sliding of the track. was great to meet new faces and see the usual faces at these events. hope nothing went to bad up the 2day and hope michele and mark get the cars sorted out soon.
https://www.sau.com.au/forums/topic/299137-bathurst-speed-week/
Yep, usually is a good weeked, must say it was for me, 2 new records in R33 and second outright for the weekend, not a bad effort against a Lola, March, Pilbean, Cheetah, Trojan etc.
R33 Supersprint 43.54 1st Type SV R32 51.60 9th
R33 Mountain Straight Hillclimb 46.29 1st - Type SV R32 53.88 7th
Karen had a great weekend in the 32, after her having a rest for nearly 3 years, finishing 13th outright of 80 over the two days, with 20 or more in our class both days.
I had a go in the R32 in the supersprint last run - Mark was going to kick my ass - but I got a time of 46.66 I think thats faster than 49.98 LOL!
Watch out for vids next day or so.
yeah it was a good weekend. It was awsome to see your new car in the flesh now its sorted. The part i liked was siting waiting to go and watching you and karen running together and to realy spot how much quicker the r33 is to the r32. How close did you get to the wall in the hillclimb. sumone said that you took the witches hat out but missed the wall.
Must say was close and yes witches hat did go, check out Motorsport>club level motorsport>incar videos>bathurst Hillclimb and Supersprint
Karen hadnt driven the car for nearly 3 years and santa bought her new soft Yoki's, she had trouble getting off the line - but it was cheaper than smoking the dunlops like she used too!
With a good start until 3rd gear and braking area to be honest there is bugger all difference. Must say the Air Con is great in 32, beats electric windows in the 33.
Enjoy vid's
    • I'm with you here. It's either loom has an issue, OR, injectors are not functioning properly. It could even be they're just constantly dribbling, hence the wet, but not firing.
    • Depending on how long the car sat it is very possible for injectors to be stuck open or closed, I'd get them cleaned and flow tested. Other than that, obviously when the loom changes and the car doesn't start any more....the loom is suspect so some tracing / comparing may be required
    • Harness is for a s1 Rb25det, and it is engine and lower harness.  the old harness had broken off plugs and was in very rough condition/exposed wires and splices etc. it is not able to be put back on the car, I could visually inspect to see if they had rewired any pins on the ecu plug. The fuel pump definitly isn’t turning off it’s an external pump and very loud you can hear it. Will look at the other harness tonight, am also going to pull the fuel rail and watch the injectors spray, will update here with what I find. Pretty sure at this point it has to be something to do with injectors because car will fire up on starting fluid and cas is clicking the Injectors. Fuel pressure is steady 43psi
    • Check the injectors flow evenly, and are actually flowing what you and the ECU think they should be flowing. If it's starting up on starter fluid, you have a fuel issue. Is it possible under cranking your fuel pump is turning off?   The harness you replaced, is that the whole engine harness? Do yourself a test, and drop the old harness on and plug it into the Z32 ECU. It's possible they've wired things different. From memory S1 to S2 is different in RB25 and you may have a wrong loom
