Hi guys/girls,
I have for sale Most of the interior from my 1993 K's edition SR20DET S13 Silvia.
I am turning it into a Rally car thus have no use for most of the interior excluding the dash and front door linings.
So i have the rest of it for sale make an offer guys its just taking up space:
Ok I Have:
Sunroof complete with roof lining and switch was working fine when pulled out of car.
Front Seats.
Seatbelts.
Space saver spare wheel
And plenty of other plastic bits and peaces from boot and interior.
Im sure there is more but i cant think of them at the moment. :D
I can post photos of any item your chasing and i will put some up of the sunroof and seats but there is to much too list it all.
So if there is something your chasing just ask and i will see if i have it for you thanks guys.
No reasonable offers refused
Contact me here or via PM cheers.
Jas.
  • Replies 86
Posted Images
Totally forgot to mention also car had A/C that was working perfect before it was pulled out.
So i have:
A/C lines
A/C Pump
A/C Condensor etc
Offers welcome help me clear some space let me know if you would like pics of anything thanks guys.
do you have door trim? any pics?
Only have rear door trims and drivers side is supposibly being picked up on Sunday let me know if there is anyhthing else your chasing and ill put up some photos for you
cheers jas.
hey mate, interested in the sun rooof glass and mayb some interior trim. let me know how much. give us a ring or sms on 0418772525.
cheers
Message sent
Some pics of seats and sunroof.
Still heaps of other plastic bits and a/c parts available so if you would like photos of them let me know.
hey mate u still got the passenger side rear door lining? can sms me a price to 0433 998 250. thanks
Sure do
Sent you a sms thankyou
    • Update 2: Today I'm f**king pissed. Some of you probably saw my thread that I opened shortly after joining this forum, "urgently need expert/experienced opinion", in which I discussed the possibility of a porous RB26 engine block which I also found hard to believe. Currently both turbos are out since the shitty braided line that was installed by whoever fitted the GT28 turbos leaked oil onto the exhaust. Today while working on the cam covers to put new gaskets and half moons in, I cleaned the side of the engine block with brake cleaner. Some time later I saw that it was still glistening with oil or coolant so I dried that off. But it was wet again shortly after. Verdict: I'm royally screwed. What you can see here (hopefully, despite shit resolution), circled in red, is a crack above the turbo oil feed. Extent is a few cm long and basically goes from #3 cylinder wall to #4 cylinder wall. It slowly lets coolant through, even without any pressure behind it. I am absolutely dumbfounded as to how this crack even formed, especially since it isn't along the cylinder as it usually is but rather a horizontal crack. Probably a few cm in length. Not sure on how to deal with this issue right now. Most likely, the only true fix is a new engine block, and even a relatively well done temporary fix requires at least a full engine teardown. Neither of those really fit my timetable right now, the car has been in my buddy's garage long enough as it is. I'm open to suggestions, but I'll be looking into ordering a new 05U block soon so I have one ready for the coming year, or whenever the current block inevitably fails fully. (Most likely once the crack reaches one of the frost plugs) I think it'd be a waste of money and time to rebuild the engine with this block. Oh and I found a rust hole on the side pocket of the trunk, which someone covered up with sealant goop, a piece of number plate and bodywork filler. Fun times. So far for every issue we fix we just find a new one that is arguably worse.
    • I have not found this no. I put one back on a couple days ago with no drama. I agree they are tight, but no need to remove anything.
    • That is gates blue racing belt
    • Anyone found gates blue racing to be extremely tight/ almost impossible to install without moving the exhaust gear
    • Hello am apex am new here and also thanks for helping registering the forum
