gtrGhosTDoGG11 Posted December 16, 2003 Share Posted December 16, 2003 How do you check your gearbox fluid level in an R33? Is there a dipstick in the engine bay? If so where is it? Or is the only way to open up the filler hole and have a look inside. Cheers. :headspin: Link to comment https://www.sau.com.au/forums/topic/29918-gearbox-oil-level/ Share on other sites More sharing options...
blind_elk Posted December 16, 2003 Share Posted December 16, 2003 Only autos have a dipstick. In a manual 'box, the only way to check is to remove the filler plug. The oil should be just below the level of the filler hole. (Don't forget to make sure the car is level) Link to comment https://www.sau.com.au/forums/topic/29918-gearbox-oil-level/#findComment-608517 Share on other sites More sharing options...
Guest RedLineGTR Posted December 16, 2003 Share Posted December 16, 2003 if it hasent been changed since u got the car or it hasent been changed at all its a good time to change it and learn about your car. Doing your own maintenence also helps u know what stuff u are putting in your car and how much thier is supposed to be. blind_elk stated how to do it. Rob Link to comment https://www.sau.com.au/forums/topic/29918-gearbox-oil-level/#findComment-608828 Share on other sites More sharing options...
gtrGhosTDoGG11 Posted December 16, 2003 Author Share Posted December 16, 2003 Thanks for the info. I'll be doing it this saturday, ill take some pics and post them. Link to comment https://www.sau.com.au/forums/topic/29918-gearbox-oil-level/#findComment-608881 Share on other sites More sharing options...
Jetdat Posted December 21, 2003 Share Posted December 21, 2003 when i changed mine i put in well over 3 litres, but a few months later i was told on these forums that the capacity is 2.8 litres.... Link to comment https://www.sau.com.au/forums/topic/29918-gearbox-oil-level/#findComment-614674 Share on other sites More sharing options...
Greg Posted December 21, 2003 Share Posted December 21, 2003 2.8L for RB25DET 2.5L for RB25DE i added a tube of Nulon G70, it made it a LOT smoother Link to comment https://www.sau.com.au/forums/topic/29918-gearbox-oil-level/#findComment-614721 Share on other sites More sharing options...
