  • Replies 115
hahaha i know your guessing but from that pic how can you see the axels that go through the engine sump :) really up high there is no difference from gts4 to gtst
he can put an attessa switch in instant rwd without dropping a shaft
I said that because R32 GTS4's came standard with ABS, and it doesnt have ABS. Yes it could have been removed, but for example Dans R32-R which has been de-ABS'd still has reminants in the bay..
But youre absolutely right, I cant see the axles through the sump :(
Come on Tangles, confirm what it is!
edit: it has staggered rims too........
The R32 sedans were offered with four-cylinder and inline-six engines, of which the basic was the CA18i, a normally aspirated 1.8l 4-cylinder with 91hp at 5200rpm (GXi). Next was the RB20DE, a 2.0 l normally aspirated inline-6 with 155hp, for the Click for a larger imageGTS. Top of the bunch was the turbo-charged RB20DET, with 215hp/6400rpm and 263Nm/3200rpm of torque, which worked in the GTS-t and GTS4 models. Later, the GTS25 also got the RB25DE, a normally aspirated 2.5l inline-6 with 180hp at 6400rpm and 231Nm at 4800rpm. 4-speed automatic and 5-speed manual transmissions were available. The automatic even came with a so-called “power”-mode, in which the box holds the lower gears until about 5000rpm, instead of the usual 3000, before shifting up a gear. For the first time in a Skyline, power was fed either to the rear via a viscous limited-slip-differential, or to all four wheels (GTS4). On the passive side, ventilated disc brakes all around with 4-piston calipers up front and 2-piston calipers in the rear kept this power in check; ABS was available optionally.
Source
rebuilt Rb30 gearbox
that wont last long. start shopping for a 25 box.
i knew someone was gonna bring up the whole higher RON thingy...but who cares, LPG is still homo lol
~60-70 cpl, 115 octane, how is it homo?
I don't rate LPG... Yes its higher ron whatevz but imo its wack as f**k. Epic converters needed if you want to run decent power, another tank install makes for a very messy setup. I'd only consider it if I had big $$ for alot of custom parts to hide all the condensors otherwise makes your bay a mess, and if it was a Drag only car. Tubbed, caged, 4link etc.
Congrats on the buy man, its going to be a ball of fun. Having a RB30 gearbox you would think its RWD? lol
That gearbox won't last long. They sturggle with stock RB30ET power. If its the MX7 (genuine turbo box) It'll last yyou some time but dont expect a MF5 to hold up long after a couple powerskids lol.
P!ss them wack rims off asap too :)
Edited by Weezy
i dont know what your talking about :) lies all lies
comes with spare GTR gearbox, so all is good
rwd, petrol, six&ahalf G, done deal, on early flight tomorrow to melb, home tomorrow night.
* happy pants
:P
dent to fix. got a longer seat rail on order already :D
already have my previous decent new 17's rims, a new seat I didnt like in the Stag, etc.
bit's to do, but gonna be good fun.
all in lieu of the bike - which I have used for like 400kms only.
so yeh a good deal to keep me happy.
The new direct port gas injection is a good piece of gear. All the new holdens and fords have to use the new system because of their ECU. The new systems give you the same fuel control as multi point fuel injecton and can make some really good numbers.
Brett for Graham West got around the 340rwkw mark with their XR6T with just a slight boost increase and LPG.
thread fail, need advice on r32 gtr and you go and get yourself a gts tangles tangles tangles
sorry
:P all I can "afford" seeing its in lieu of having a bike
already got attessa in the stag - now have GTR rb26dett & gearbox
might find its way in - ? :D
    • @DraftySquash @Duncan he's not talking about the part that sits against the radiator support, he’s talking about the lip that sits towards the front outside of the car. anyway I had a look at other cooling panels and came across this one https://justjap.com/products/carbing-radiator-cooling-panel-plate-nissan-skyline-r34-gt-t?variant=37829684134087&currency=AUD&utm_source=google&utm_medium=organic&utm_campaign=Advanced feed&utm_content=Carbing Radiator Cooling Panel Plate fits Nissan Skyline R34 GT-T (Coupe)&srsltid=AfmBOoonzPDKqe9NgKi5U0AkFc2XvbXETGmNWvfNcyBT5DUZagMYHg9DZ70 if you take notice it’s the same shape.  well thankfully the justjap listing has a description and it says : - Nissan Skyline R34 GT-T Coupe (M/T -07/2000) this means it’s specifically for a s2. S2’s have different front bars to s1 so that lip with the 3 holes are *probably* mounting points for the s2 bar. im not 100% sure but im almost certain it will still fit a s1 bar
    • Everyone is too used to learning from places like HPA "how to tune" and what to expect at what point, rather than being able to see "The computer says I'm in cell with Row = 8, column =4, and I can see my fuel is lean, so lets add more" Everyone wants "real units", which helps for someone picking it up for the first time and seeing how bad the tune is if they're not used to touching it.   However, I think for most of us who want to play with it, you're 100% right, we're only needing to learn about it for OUR CAR. Which makes it great, and we don't need to care what the real values are, we just need to know which cell it is, that's causing the lean or rich point, or that we want more ignition timing or less. But again, everyone wants everything super you beaut and nearly self tuning, with VE maps, and a billion compensations...   Though then there's me over here when I'm doing reverse engineering work just reading data in hex format that most people couldn't work anything out from. Yet I can see what's going on.
