3rd pulls really good on mine too. A few little flat spots due to the ECU crapping itself though.. :D
I find that when giving other cars a run, and if it's a close call in 1st and 2nd, I'll get into 3rd and pull away from them.
I think it's cause the ratio from 2nd to 3rd is close. Eg. 2nd goes to around 100km/h (if you push it) and 3rd only get's you too 140km/h.
DriveBai - once you get a 3inch exhaust and up the boost you'll notice a big improvement :D
J
yeah i got a 3in exhaust from the turbo, hi-flow cat, blled valve.. running 11psi.. but on stock boost its still the same.. also i got an SAFC which may need a retune as i got it tuned before my dump pipe and hi-flow cat..
yeah i heard that 3rd gear is spose to be strong in Skylines but my 3rd gear seems a little lifeless almost like a continuation of 2nd gear like it doesnt pull any harder once i change to 3rd.
why would it pull harder in 3rd than 2nd???
i think when people say 3rd gear is strong for skylines its relative to other cars, not relative to second gear, i.e other cars start slowing in acceleration (non turbos) in 3rd compared to a turbo skyline
my car definitely accelerates harder in second than third.....
Have to agree with that, I find if it is neck and neck or I am tailing a bit, once it hits third it is all over Red Rover (most of the time anyway :) )
I would say that 2nd pulls harder than 3rd, but you have so much range in third compared to 2nd.
I think 3rd is the best gear if you ask me.. but i don't get to use it that often, because it pulls hard from 80km/hr to 140km/hr (/too fast).
You might need a S-AFC or ECU to get the most out of that range thugh.
I find that 4th is the best gear that if say a monaro or WRX or 180sx trys to give you a run i'll just pull car length in 4th but i've got a speed cut. As REDBACK says anything over 10.5 psi and the car gets a slight surge due to std ECU. 10.5psi is the magic number as i've done lots of testing if anyone has questions?(REDBACK)
    • I would paint match the whole thing to avoid unwanted attention  I had a similar bonnet, paint matched, on my old R33 GTST, but mine was a fibreglass jobbie made by Blitz in QLD, they work extremely well for radiator efficiency and under bonnet temps
    • Does anyone run this kit with factory plenum? Does the adapter and bosch tb fit under factory strut brace? I wanted to get this setup before going forward facing manifold. Thanks
    • small update time, after always wanting a "cool" looking bonnet for my car and always struggling to find one for the series 2 that i liked and wasn't an insane amount of money. Saw one i liked on RHDjapan from D-speed in Japan the price was very good for a carbon bonnet so good infact i was a little unsure how much i trusted it, decided to bite the bullet and with the help of jesse streeter in not long at all it was at my door. Once it was delivered i ran in from work and quickly unboxed it and to my surprise the quality was actually pretty good i quickly removed the old bonnet and placed on the new one to test it out and even the fitment wasnt too bad at all. Then decided to paint the little grille in the bonnet black to stop it sticking out so much.   I decided to not mess around with the hood latch and just install some aero catch hood pins, having never installed them before did some YouTube university classes and i was good to go. fair to say it is not a fun job at all from making brackets so the pins sit nicely and actually cutting through the bonnet but also being very scared of cutting the holes too big it took wayyyy longer than i would like to admit but finally got it there. Then it was time for a quick test drive to ensure the latches actually worked and thankfully the bonnet looked very stable. I still think paint matching the bonnet and leaving just the part that sticks up as carbon would help make it all look alot neater as im not sure how i feel about all that carbon on a very fridge white car but will leave it as is and see how i feel with time.
    • I think it's bound to happen, you finally get it all perfect, and bam, something will happen. I took a while to get a Commodore rear quarter repaired where a P Plater clipped it. Two days after getting it back, Sarah wiped it out on a concrete pillar in an underground car park... This is why I take forever to repair them, it stretches how long until it gets bent again... 😛
    • Nah, not really responsible for that little fiasco, but I'm still pissed at myself for writing off my 86, or when I reversed my VX into a pole just before selling it, but, meh, 5hit happens to stuff, all it takes is a slight distraction, and life is full of distractions, and "dooh" moments
