I'v only got boost set on 12 pounds, cooler, Apexi RSM and turbo back 3inch (gutted cat) and it pulls in third very quick and there is constant power all the way to 253kmh in fifth. i used to have flat spots even a splurt but got it all worked out on dyno and the less restrictive ur exausht the more flow. 1st and 2nd are a waste, tyres lighte up all the way and seriouse speed comes in third onwards. trust me, dyno is worth it.
Wish you were closer so we could have some roll ons to compare and see if the 1.5 pounds more does much, i have a very restricted 3 1/4inch system keeps the police off my back! Is 253kph red line or just wont pull anymore?
late second gear (over 4500rpm) all the way until say 1/2way through 4th is where i kill every car but i very rarely get to go into 4th (Its just to fast to be safe).
most cars pull away in first gear (even with a good launch) coz they are either V8's or 4wd Turbos or pocket rockets but once your 1/2 way through second you catch them very quickly, usually u catch them before the redline in 2nd, then 3rd you just pull away :D
i have never tried this with my new EBC, it will be interesting to see what its like :D
I have too much in third and start to wheelspin on coarse road surface at 100kmh. Wheelspin in the wet also at 180 in 4th too if I floor it. Modified stock turbo from Rigoli but mostly stock with 0.5mm OS pistons. Dump pipe and IC are stock for now but 3" zorst and hi flow cat. Power comes on like a sledgehammer at 4000 so maybe thats why it does what it does and only at 11psi. Bit laggy though under 4000 and have trouble staying with stockers through the roundabouts out here. The straight bits inbetween make up for it and the handling but slow out of tight corners.
I use an EBC @ 0.62bar (full boost @ 2900) and i found if i hit it hard in third, it gets a bit overwhelmed with fuel (or something?), so if i just ease it in (over 1sec) it responds alot better and seems to 'avoid' the flat spot.
weird stuff.....
-rb25
25
which controller do U have and what do they retail? I could use some of that!!!!
That seems consistant with 'lines that you have to feed the power as they go soft at pull pedal when running the std computer. Anyone else experience this?
    • I would paint match the whole thing to avoid unwanted attention  I had a similar bonnet, paint matched, on my old R33 GTST, but mine was a fibreglass jobbie made by Blitz in QLD, they work extremely well for radiator efficiency and under bonnet temps
    • Does anyone run this kit with factory plenum? Does the adapter and bosch tb fit under factory strut brace? I wanted to get this setup before going forward facing manifold. Thanks
    • small update time, after always wanting a "cool" looking bonnet for my car and always struggling to find one for the series 2 that i liked and wasn't an insane amount of money. Saw one i liked on RHDjapan from D-speed in Japan the price was very good for a carbon bonnet so good infact i was a little unsure how much i trusted it, decided to bite the bullet and with the help of jesse streeter in not long at all it was at my door. Once it was delivered i ran in from work and quickly unboxed it and to my surprise the quality was actually pretty good i quickly removed the old bonnet and placed on the new one to test it out and even the fitment wasnt too bad at all. Then decided to paint the little grille in the bonnet black to stop it sticking out so much.   I decided to not mess around with the hood latch and just install some aero catch hood pins, having never installed them before did some YouTube university classes and i was good to go. fair to say it is not a fun job at all from making brackets so the pins sit nicely and actually cutting through the bonnet but also being very scared of cutting the holes too big it took wayyyy longer than i would like to admit but finally got it there. Then it was time for a quick test drive to ensure the latches actually worked and thankfully the bonnet looked very stable. I still think paint matching the bonnet and leaving just the part that sticks up as carbon would help make it all look alot neater as im not sure how i feel about all that carbon on a very fridge white car but will leave it as is and see how i feel with time.
    • I think it's bound to happen, you finally get it all perfect, and bam, something will happen. I took a while to get a Commodore rear quarter repaired where a P Plater clipped it. Two days after getting it back, Sarah wiped it out on a concrete pillar in an underground car park... This is why I take forever to repair them, it stretches how long until it gets bent again... 😛
    • Nah, not really responsible for that little fiasco, but I'm still pissed at myself for writing off my 86, or when I reversed my VX into a pole just before selling it, but, meh, 5hit happens to stuff, all it takes is a slight distraction, and life is full of distractions, and "dooh" moments
