Hi guys,
I recently brought an R32 as a daily, it's stock, runs stock boost etc.
It pings it absolute face off above about 4500rpm.
I wound the timing back as far as it can go (yes I know it's clockwise on the CAS) and it was better but I can still hear a few pings and that is will like 20RWKW down low because the timing is so retarded.
This is with 98 octane fuel (BP Ultimate) I have tried different fuels with the same result.
It doesn't ping coming on to boost which is kinda wierd, only at about 4000rpm+ once it starts to do something. Stock turbo is fully spooled way before then.
Any idea's guys? The boost is around 5psi at the intake manifold, also confirmed with another gauge.
I have an RB30DET in an R33 as a daily driver and I remember when that had the stock RB25DET in it, I use to run 12psi on 18 degrease of timing and it never pinged on 98 octane fuel. :)
Stock coil packs, Also have a receipt from the previous owner where it has just had new plugs put in it at a work shop. Not sure what they are and haven't pulled one out to look but I assume they would just be stock gap.
Not sure how spark plug gap or brand can make it ping.
It doesn't miss at all so I assumed it wouldn't be a spark related issue.
:) why didn't I think of that before...
I will stick a fuel pressure reg on and see how much fuel pressure the stock pump is holding... kinda have to test that under load though...
I think I have a set of RB20DET injectors lying around some where I will try changing them over... I hate removing intake manifolds on RBs so much :)
Will also try replacing the pump if I can find one lying around. I have a Bosch 044 lying around so I could run that in-line and see if that helps.
It's wierd cuz this car has really no power, I guess around 100RWKW if it's lucky. I would have thought the stock fuel gear wouldn't have a problem with it unless an injector is all clogged up or the stock fuel pressure reg is dying.
Edited by Finny
I replaced the pump with a new pump, voltages are fine. I really don't think it is a fuel issue as the car doesn't hesitate or have any signs of fuel starvation.
It also doesn't ping for like the first 2 minutes of driving until the car gets hot, I thought it could just need a cooler upgrade but no other R32 that I have seen pinged with stock cooler, In fact a friend of mine had an R32 with more than stock timing, 12psi and stock cooler and that had no issues.
I changed the computer to one that had been tuned to 180RWKW with stock injectors and the car will not rev. It has classic retarded timing issues like very slow free rev and at about 4500rpm it just wouldn't free rev any higher. Another sign or retarded timing was the exhaust was pooping heaps of flames due to the exhaust valve opening while the fuel was still burning. I didn't pay much attention to this as this ecu has not been tried in an R32 since it was brought off ebay by a friend so it could just be a dud tune. Also I adjusted the timing with the cas and it didn't help.
check if the vacuum line to the factory FPR is connected and not damaged. Sounds like a fuelling problem, when the car is cold by default it will run more rich hence less/no ping.
I suspect a faulty FPR or fuel pump.
A friend just pointed out to me, it's probably got like bosch temp 5 plugs as it had new plugs put in at a work shop, they used bosch plugs and a temp 5 in a bosch plug is like a temp 3 in an NGK. I am going to put some NGK temp 8 plugs in it and see if that fixes the issue.
sounds like ur timing belt hasnt been installed properly, check that first, spark plugs dont make u ping !! >.<
Agreed, he really needs to check the belt and see where all the markings are.
A betting man would put money on this.
Of course it is - it's pinging!
Because the engine is cold, and the ECU is running the engine rich.
... it's probably got like bosch temp 5 plugs ...
Have you actually looked to see what plugs are installed?
You still haven't told us what fuel pressure the engine is running.
If the plug is running too hot, it can pre-ignite the mixture (works like a glowplug).
You changed the pump and injectors but not the fuel filter??
You can measure all the fuel pressure you like but you also need to check the system flow, thats just as important.
Use a timing light; that will tell you where the timing actually is and if there is a possibility of the cam timing being out.
and also:
Are you sure its actually pinging?
Some boost leaks sometimes sound like knocking. Just an idea.
    • My take on gg2 48mm, 54mm, 58mm, and 62mm compressor map for same size compressor vs gg1 : All gg2 only outflow gg1 above 20 psi. As all g gen 2 surge line at lower left of comp map move to the right, all gg2 sacrifice spool vs same size gg1, surge line move to the right worst for 54mm gg2. So for same size compressor if you want best response, use gg1, if you want max hp at >20psi use gg2 but you will be laggier vs same size gg1. Max compressor efficiency drops to max 75% on all gg2 vs max 76%-80% of same size gg1. Iirc lower efficiency means hotter iat less dense air so lower hp at same operating point of comp map. Also curious why gg2 is mapped to lower max rpm vs same size gg1 (only 48mm size both gg1 gg2 mapped to same rpm) : 54mm gg1 165,000 rpm  vs  gg2 160,000 rpm. 58mm gg1 150,000 rpm vs gg2 140,000rpm. 62mm gg1 145,000 rpm vs gg2 140,000 rpm. If gg2 can safely spin to gg1 rpm then they can flow a bit more than as mapped. Good thing that all gg 2 interchange compressor and turbine housings with same size gg 1. So gg1 owners can buy gg2 chra only if planning to boost >20psi.
    • My stuff is all with Shannon's, granted, I don't really have imports I'm driving on the road, however, I've had multiple cars at the same time with them. Presently we have the Landcruiser on laid up cover, Sarah's Kluger on full cover, and the house insured. About 18 months ago Sarah wrote her Subaru Liberty GTB off, insured with Shannon's, and the payout, and buy back of the wreck was super quick. In 2020 we had the VF Commodore totalled in a major hailstorm. Storm was on the Saturday, I called on the Sunday and lodged it, vehicle was towed on Tuesday night, assessment team called on Wednesday to say it was a total loss and get payout details, money was in the bank on Thursday morning. Have had a few other claims both at fault, and not at fault, over the years, and never had an issue with them.   Funnily enough, they're also the cheapest insurer I find for things like Sarah's Kluger.   I will say I'm less impressed dealing with them lately around "the experience", as a lot of their staff that you deal with aren't car enthusiasts. Shannon's has a much more main stream feel ever since they decided to become "big corporate", laid a heap of staff off, and then hired a bunch of non enthusiasts. At the same time they've been making a push to be less "call us and we'll personally have someone who cares help" to "hey, this computer can do stuff for you" and are trying to get more square pegs to fit round holes. (That's just the vibe I get from them). Again, have had no issues with claims with them, but get a bit of a "less personal" feel from them.
    • A thing I wasn’t happy with with enthusiast was during the initial phone call they told me they’d insure it for 130k but needed photos.   I then sent them photos and they told me $80k as there were other cars either similar modifications available for around that price, I told them to send me the links to said cars so that I can buy them. i then sent the modification list with prices of the parts (no labor) and the price then came to 115k, which is still shy of the 130 that was agreed in the initial phone call
    • Ask me a bit later this week before payday
    • I agree that delayed payment probably isn't the most suitable solution. It seems a solid complete transaction would be best. As I wouldn't be using this sale as a line of credit that would typically earn interest, we can probably arrange a much cleaner single transaction deal. I can do $92.52 today. Would you prefer EFT, or Cash on Pickup?  😛
