I'm picking up my SAFC 2 on wednesday night and getting it tuned by the trusty boys at Pro-tek on thursday. Currently the car makes around 161kw atw. What do you peeps think i'll get with the addition of the safc 2?
Oh, it's an r33 gts-t with front mount, 3 inch turbo back and 11 psi.
The person who guesses the closest figure will win a prize!
Disclaimer: Prizes will not be dispensed.
You're making only 161kw with fmic/exh/11psi?? Thats awefully low! It should be around 180kw. Mine made 175 with only 9psi.
Yeah, only made 161. At the same time though, I think the dyno at Pro-Tek reads a little lower though... Wouldn't surprise me if it makes a few kw more on other dynos. I shall confirm when I take the car to the RE Dyno night this friday night to see what the go is.
185RWKW
188rwkw :)
Your guesses have been entered into the drawer. Good luck! You will be informed of the outcome most likely on Friday. If you come to the RE Customs Dyno night, you might even see it up on the rollers. Look out for the white s2 33 with the astro boy sticker on the back window!
BTW, Do you guys really think a gain of 25+ kw atw is achievable? or are you just teasing? lol Because I think i'm only gonna get 170-170 max?
I've got a better game... lets guess how high the dyno figure will be inflated!
Because unless you are hitting R&R with 11psi now (sounds like you are not)... then there will be no 20-30rwkw gain, i'm going to have a nice chuckle if there is though.
The driveability & midrange will be better, economy will be better - those are the key things.
Top end though... not as big of a gain.
Before - dyno run. Tune. After - dyno run. That is where you will see the midrange improvements which will make the car feel a lot nicer.
I was going to say something similar.
I had my R33 tuned with an SAFC2. 3' turbo back, FMIC etc.
It peaked with 1rkwk more than before, but 4-500rpm lower, but the mid range increase was fantastic.
Economy was improved a far amount too.
Just remember, peak power doesnt mean alot as dynos vary too much. It just depends on how well it drives for a "170rwkw" or a "200rwkw" Skyline. ;)
Post up some before/after plots though. Would be nice to compare.
You will be hitting around 190kw with those mods with timing a little advanced.
I have a Tomei adjustable exhaust cam gear too, so perhaps that will help a little, as I don't think it has been 'dialed in' at this stage to suit the mods etc.
well my mates skyline has 3" exhaust cat back , Boost set at 11PSI with a SAFC2 and he made 212kw@11psi so yeah i say you should get around that .. also car was tuned at Hitman in penrith
not really important what it makes
what is important is the gain you achieve compared to your previous run on the same dyno
so if its on the same dyno then its useful to check against what you made last time
but if its a on different dyno the results arent that statistical for a accurate comparison
but yeah should be around 180 to 190rwkw
the afr's will probably lean out with stock pump tho
why waste time + money on an SAFC?? get a proper stand alone ecu, not that shit signal bender crap... by the time you've paid for the SAFC + dyno time you'd have been better off spending some more money and getting a R32 ECU w/Nistune + a Buddy Club VTC Controller.... cheap cheap cheap power....
I get sick of hearing that. Clearly an aftermarket standalone is better. But for a quick tidy up a piggy back is ideal.
SAFC2, picked mine up for $250, and an hours dyno hire @ $100.
Give me a standalone, tuned for $350 and ill take it all back.
Any respectable tuner should be able to fully dyno tune a SAFC in under an hour. They are very basic.
Dont forget not everyone has alot of money to spend on a standalone, that costs alot more outright, not to mention the tune costing near as much as the ecu itself. That and also not everyone intends on going the whole hog and actually require anything more.
Personally, i dont think $2000+ for bit of midrange is what id call bang for buck.
Edited by gotRICE?
Couldn't have said it better myself gotRICE.
    • Got started on the modification to make these splash plates fit over the long weekend. First the surprisingly time consuming task of swapping all the cam camp bolts to Tomei cam cap studs. I did the method of removing one bolt at a time, applying loctite to the stud, double nutting to torque as the manual described. Then carefully unlocking the nuts without disrupting the torque of the stud (and going back to re-torque a few times when it slipped). Finally applying the nut and torquing to spec. Repeat x28 Next up I went about removing the stock cam cover baffle so I could ensure it was fully clean after drilling for stud clearance.  As the blind rivets holding the baffle on were domed I used a punch to mark the center then used 4mm drill bit to carefully drill out the rivet without going too far part the baffle. As seen in other thread here is what is inside the stock baffles I decided on M4x6mm bolts to bolt the baffle plate back on with. I used a 3.3mm drill bit with some tape to mark the depth at ~8mm. Next was to tap the threads using a cheap bunnings kit M4x0.7. With the baffle removed I also drilled out the spot welds holding in the baffle plate oil returns. Unsure whether this was the best option or if I should have cut holes in the Hypertune splash plates to allow the oil drains to still function... time will tell. I then removed the the Hypertune splash plates so I could rest the cam cover on top and use a dab of grease to mark where the studs impacted the oem cam cover baffle. The most obvious spot was on the hump from the stock mesh is held. Using this hole as an anchor I bolted the oem baffle plate back into the cam cover and lined up the Hypertune splash plate. Marked the rest of the holes for the studs and drill those out too. Total 32 holes drilled and 12 threads tapped on the passenger side cam cover alone for this bolt on part that totally clears all OEM cam covers.. Drivers side next as well as some E85 safe fuel foam to fill the space behind the behind cam cover baffle plates. oh and some lock nuts for the splash plates of course.
    • I had the same previously, and it really shits me. They just run off red book averages or whatever as the maximum insured, there are never good quality cars available to buy for anywhere near those prices. I don't even understand why they do it. Sure having a customer overinsure then false claim is a risk, but how often does that really happen in the world, 1%? 0.1%? On the other hand, all 10-20% above redbook listed prices and charge 10-20% higher premium, surely that is more profitable for those cockroaches
    • My take on gg2 48mm, 54mm, 58mm, and 62mm compressor map for same size compressor vs gg1 : All gg2 only outflow gg1 above 20 psi. As all g gen 2 surge line at lower left of comp map move to the right, all gg2 sacrifice spool vs same size gg1, surge line move to the right worst for 54mm gg2. So for same size compressor if you want best response, use gg1, if you want max hp at >20psi use gg2 but you will be laggier vs same size gg1. Max compressor efficiency drops to max 75% on all gg2 vs max 76%-80% of same size gg1. Iirc lower efficiency means hotter iat less dense air so lower hp at same operating point of comp map. Also curious why gg2 is mapped to lower max rpm vs same size gg1 (only 48mm size both gg1 gg2 mapped to same rpm) : 54mm gg1 165,000 rpm  vs  gg2 160,000 rpm. 58mm gg1 150,000 rpm vs gg2 140,000rpm. 62mm gg1 145,000 rpm vs gg2 140,000 rpm. If gg2 can safely spin to gg1 rpm then they can flow a bit more than as mapped. Good thing that all gg 2 interchange compressor and turbine housings with same size gg 1. So gg1 owners can buy gg2 chra only if planning to boost >20psi.
    • My stuff is all with Shannon's, granted, I don't really have imports I'm driving on the road, however, I've had multiple cars at the same time with them. Presently we have the Landcruiser on laid up cover, Sarah's Kluger on full cover, and the house insured. About 18 months ago Sarah wrote her Subaru Liberty GTB off, insured with Shannon's, and the payout, and buy back of the wreck was super quick. In 2020 we had the VF Commodore totalled in a major hailstorm. Storm was on the Saturday, I called on the Sunday and lodged it, vehicle was towed on Tuesday night, assessment team called on Wednesday to say it was a total loss and get payout details, money was in the bank on Thursday morning. Have had a few other claims both at fault, and not at fault, over the years, and never had an issue with them.   Funnily enough, they're also the cheapest insurer I find for things like Sarah's Kluger.   I will say I'm less impressed dealing with them lately around "the experience", as a lot of their staff that you deal with aren't car enthusiasts. Shannon's has a much more main stream feel ever since they decided to become "big corporate", laid a heap of staff off, and then hired a bunch of non enthusiasts. At the same time they've been making a push to be less "call us and we'll personally have someone who cares help" to "hey, this computer can do stuff for you" and are trying to get more square pegs to fit round holes. (That's just the vibe I get from them). Again, have had no issues with claims with them, but get a bit of a "less personal" feel from them.
    • A thing I wasn’t happy with with enthusiast was during the initial phone call they told me they’d insure it for 130k but needed photos.   I then sent them photos and they told me $80k as there were other cars either similar modifications available for around that price, I told them to send me the links to said cars so that I can buy them. i then sent the modification list with prices of the parts (no labor) and the price then came to 115k, which is still shy of the 130 that was agreed in the initial phone call
