I'm picking up my SAFC 2 on wednesday night and getting it tuned by the trusty boys at Pro-tek on thursday. Currently the car makes around 161kw atw. What do you peeps think i'll get with the addition of the safc 2?
Oh, it's an r33 gts-t with front mount, 3 inch turbo back and 11 psi.
The person who guesses the closest figure will win a prize!
Disclaimer: Prizes will not be dispensed.
You're making only 161kw with fmic/exh/11psi?? Thats awefully low! It should be around 180kw. Mine made 175 with only 9psi.
Yeah, only made 161. At the same time though, I think the dyno at Pro-Tek reads a little lower though... Wouldn't surprise me if it makes a few kw more on other dynos. I shall confirm when I take the car to the RE Dyno night this friday night to see what the go is.
185RWKW
188rwkw :)
Your guesses have been entered into the drawer. Good luck! You will be informed of the outcome most likely on Friday. If you come to the RE Customs Dyno night, you might even see it up on the rollers. Look out for the white s2 33 with the astro boy sticker on the back window!
BTW, Do you guys really think a gain of 25+ kw atw is achievable? or are you just teasing? lol Because I think i'm only gonna get 170-170 max?
I've got a better game... lets guess how high the dyno figure will be inflated!
Because unless you are hitting R&R with 11psi now (sounds like you are not)... then there will be no 20-30rwkw gain, i'm going to have a nice chuckle if there is though.
The driveability & midrange will be better, economy will be better - those are the key things.
Top end though... not as big of a gain.
Before - dyno run. Tune. After - dyno run. That is where you will see the midrange improvements which will make the car feel a lot nicer.
I was going to say something similar.
I had my R33 tuned with an SAFC2. 3' turbo back, FMIC etc.
It peaked with 1rkwk more than before, but 4-500rpm lower, but the mid range increase was fantastic.
Economy was improved a far amount too.
Just remember, peak power doesnt mean alot as dynos vary too much. It just depends on how well it drives for a "170rwkw" or a "200rwkw" Skyline. ;)
Post up some before/after plots though. Would be nice to compare.
You will be hitting around 190kw with those mods with timing a little advanced.
I have a Tomei adjustable exhaust cam gear too, so perhaps that will help a little, as I don't think it has been 'dialed in' at this stage to suit the mods etc.
well my mates skyline has 3" exhaust cat back , Boost set at 11PSI with a SAFC2 and he made 212kw@11psi so yeah i say you should get around that .. also car was tuned at Hitman in penrith
not really important what it makes
what is important is the gain you achieve compared to your previous run on the same dyno
so if its on the same dyno then its useful to check against what you made last time
but if its a on different dyno the results arent that statistical for a accurate comparison
but yeah should be around 180 to 190rwkw
the afr's will probably lean out with stock pump tho
why waste time + money on an SAFC?? get a proper stand alone ecu, not that shit signal bender crap... by the time you've paid for the SAFC + dyno time you'd have been better off spending some more money and getting a R32 ECU w/Nistune + a Buddy Club VTC Controller.... cheap cheap cheap power....
I get sick of hearing that. Clearly an aftermarket standalone is better. But for a quick tidy up a piggy back is ideal.
SAFC2, picked mine up for $250, and an hours dyno hire @ $100.
Give me a standalone, tuned for $350 and ill take it all back.
Any respectable tuner should be able to fully dyno tune a SAFC in under an hour. They are very basic.
Dont forget not everyone has alot of money to spend on a standalone, that costs alot more outright, not to mention the tune costing near as much as the ecu itself. That and also not everyone intends on going the whole hog and actually require anything more.
Personally, i dont think $2000+ for bit of midrange is what id call bang for buck.
Edited by gotRICE?
Couldn't have said it better myself gotRICE.
    • Yep, so far most have said that it looks like corrosion on the wall from piston not moving. Which then has probably damaged the oil rings and caused those vertical marks. The longest the engine was still after the rebuild, was the winter of 2018 - 2019, plus the boat trip to Japan. When I shipped the car, it had normal gas in the tank but before that winter pause, it had E85 in tank.  In any case, even if either one of those was the cause, it happened close to 6 years ago and the car has been driven something like 30 000kms after the fact. Again, apart from the plugs and the dip stick, there is nothing in the way the car runs that would indicate what has been going on in the engine. I am going to consult a shop and ask their opinion, what would be the best approach. I do have some access to a garage I could use to diagnose further myself, but time is very restrictive. Might end up buying another engine that could be used while this one is being remedied. Without pulling the head, it will be impossible to find out if it needs another bore, but here's to hoping a hone would suffice.  Goddamnit, I would really have preferred this not happening.
    • Boot is going to be replaced eventually. I just wire brushed what I could and rust converted. Then painted in rust kill primer. the spoiler also got repainted and plugs replaced on the ends. The under side of the bonnet is going to be black also, currently white. But red on the top side, same colour code as the silo to begin.
    • Hi guys, has anyone either purchased or built themselves a rotisserie for their car before? I can only just justify the need for one hence why I should just make one but at the same time, if I make one I can kiss another 4 weeks of potentially productive car working time goodbye because I'm building a bloody rotisserie....  I mainly want it for the application of the body deadener.  Cleaning the old stuff off, priming and then colour over the deadener doesn't worry me, it's just the application using the Schutz Gun that I feel would achieve a significantly better finish painting it side on and keeping the Schutz Gun upright.  I don't think they would work well on the side let alone almost upside down for some areas.  If the product I use (Terosun, etc) could work through a HVLP ok then it might be ok to apply without the rotisserie.   I can get one of these style ones for about $1200 which is pretty good value-     I reckon if I made one it would cost around $500 but it's more the time that it would take is more of a killer than the cost.  They look to hold their value pretty well second hand so I could always sell it after using it and realistically only lose $200-$300 at worst.  Or keep it and buy another project when this one finally sees the light of day... Anyone selling one...? Cheers!
    • While it is a very nice idea to put card style AFMs into the charge pipe (post intercooler, obviously), the position of the AFM and the recirc valve relative to each other starts to become something that you really have to consider. The situation: The stock AFM is located upstream the turbo, and the recirc valve return is located between the AFM and the turbo inlet, aimed at the turbo inlet, so that it flows away from and not through the AFM. Thus, once metered air is not metered again, neither flowing forwards, or backwards, when vented out of the charge pipe. When you put the AFM between the turbo outlet and the TB, there is a volume of pressurised charge pipe upstream of the AFM and there is a volume of pressurised pipe downstream of the AFM. When the recirc valve opens and vents the charge pipe, air is going to flow from both ends of the charge pipe towards the recirc valve. If the recirc valve is in the stock location, then the section between it and the TB doesn't really matter here - you're not going to try to put the AFM in that piece of pipe. But the AFM will likely be somewhere between the intercooler and the recirc valve, So the entire charge pipe volume from that position (upstream of the AFM, back through the intercooler, to the turbo outlet) is going to flow through the AFM, get registered as combustion air, cause the ECU to fuel for it, but get dumped out of the recirc valve and you will end up with a typical BOV related rich spike. So ideally you want to put the AFM as close to the TB as possible (so, just upstream of the crossover pipe, assuming that the stock crossover is still in use, or, just before the TB if an FFP is being used) and locate the recirc valve at the turbo outlet. Recirc valve at the turbo outlet is the new normal for things like EFRs anyway. In the even of a recirc valve opening dumping all the air in the charge pipe, pretty much all of it is going to go backwards, from the TB to the recirc valve near the turbo outlet. But only a small portion of it (that between the TB and the AFM) will pass through the AFM, and it will pass through going backwards. The card style AFMs are somewhat more immune to reading flow that passes through them in reverse than older AFMs are, so you should absolutely minimise the rich pulse behaviour associated with the unavoidable outcome of having both a recirc valve and an AFM in the charge pipe.
    • Yep, in my case as soon as I started hearing weird noises I backed off the tension until it sounded normal again. Delicate balance between enough tension to avoid that cold start slip and too much damaging things.
