well the average difference between SAFC and a standalone with THOSE specific mods are around 15rwkw. anything above 200-210kw and you just cant do anything with the safc.
thing is, when you've randomly $500 you want to throw it at your car and get power the QUICKEST way possible then things like safc's and emanage look really attractive and are pretty much the ONLY option. i also did it your way, i started with an safc, then went to a chipped ecu, then went an emanage, then finally got a vipec, ive spend around $5000 just on ecu's and tunes whereas if i bought a standalone to begin with it would've been less than half that.
but this is the cycle we all go through! if someone told you to just shut up and buy a standalone for $1600 instead of going for a $200 safc, would you have listened? or would you have weighed out the $$ you have vs. the time it would take to get the $$ for the standalone and just said, "fuckit" like most do.
Edited by SECURITY
depends on the dyno you should make an extra 30hp
with exhaust cooler and 11psi on std ecu i made 170kw (230hp) then i installed the safcII and made 193kw (260hp)
before i got it tuned i asked the guy how much it should make and he said 30hp coz he tuned a gtst the other day and it made that, so my guess is 30hp!!
just raise the boost as high as u can without hitting boost cut which i can almost guarentee wont be any more then 12psi
mine was tuned to 11psi and didnt hit boost cut on the dyno but when i drove the car on a cold night or when the engine was still cold it would sometimes hit boost cut
oh yeh and i had NO increase in fuel economy, i was kinda expecting a differnence, still get 400km to 50L
good luck with it dont blow ya car up :)
