Was a great day, met a few new faces.
Vince, that car of yours is f**king hot.
A certain R32 and R33 truly showed that 400 is the new 300...
Congratulations all. Will definately go next year.
  • Replies 95
yeah as dion said some awesome cars on display.....i was a bit :blink: when my 33 only made 203 rwkw.....shaun said it has boost issues....the leak may be a factor.....time to get things sorted out before track day
The imports have taken the title for a second year with a sizable number;
Domestic Total : 2034.9 rwkw
Import total : 2919.1 wkw
Individual cars;
Import Adrian 432.0 R33
Import Andrew 421.7 R32
Domestic Dave 395.4 VZ
Import Vince 360.9 R33
Domestic Phil 339.7 XB
Import Luke 311.3 R31
Domestic Paul 310.3 VE
Domestic Brad 257.0 WK
Domestic Brendon 219.8 VX
Import Chris 203.6 R33
Domestic Shaun 194.2 VZ
Import Nick 191.0 R33
Import Todd 188.1 Aristo
Domestic Lee 184.5 XW
Import Kaits 174.2 R34
Import Mark 145.4 Chaser
Import Daniel 143.4 180SX
Domestic Travis 134.0 EB
Import Ryan 120.7 Colt
Import Kevin 119.8 Stagia
Import Rob 107.0 R31
The skylines really boosting those import numbers.
Thanks everyone for a good day and I look forward to see you all next year!
Note: Gary, I do not have a score for you. Can you please email me. :blink:
Thanks guys for letting me just show up and run, was glad you moved the date, was away and couldnt make the original date!
was awesome to crack 400, bit of fun trying to keep it on the dyno, nothing a few people in the boot couldnt fix!
nice and lean, couple more psi and a larger catcack has released a few more pony's me thinks.
Bloody good work from Adrians beast - what a number from a stock motor!! Happy with my number especially on pump fuel and can't wait to convert to E85 and crank some more boost into it!
LOL, how much leaner do you want to get Adrian.....that corn syrup must be good gear to allow you to run those AFR's
awesome power.....and did I hear right, still running the stock pistons & rods? :)
I know, I know, I did wind bit too much boost in it, normally run it around .85 lambda which sorta works out around 12.5 in petrol afr's
yeah its still all nissan except for a acl metal head gasket.
A huge thanks to all the skyline guys that entered. Huge numbers, really impressive stuff.
We'll be back next year with a slightly improved format; later start on the day and a car show on sunday!
See you in a year! :)
    • Update: I got the magnet out. I bought 3 different flexible magnetic reach tools, but none of them worked. The magnet on the tip was all less than 2lbs of force, so i had to buy a special cylindrical magnet that had a pull force of 9lbs.  The magnet finally came in the mail yesterday, so i got under the car to get to work. The super strong magnet isn't that long, so i only have about 1 finger pinch lengths to hold it. I was so scared when i was going in the hole, that the 9lb magnet would just fly away inside the oil pan never to be seen again, but i had my butt cheeks clenched and finger gripped on that thing so tight, i managed to get it to suck the other magnet out.  It was a victory for me last night.
    • Yep, pretty much what you said is a good summary. The aftermarket thing just attached to the rim, then has two lines out to valve stems, one to inner wheel, one to outer wheel. Some of the systems even start to air up as you head towards highway speed. IE, you're in the logging tracks, then as speeds increase it knows you're on tarmac and airs up so the driver doesn't even have to remember. I bet the ones that need driver intervention to air up end up seeing a lot more tyre wear from "forest pressures" in use on the highway!
    • Yes, but you need to do these type certifications for tuning parts. That is the absurd part here. Meaning tuning parts are very costly (generally speaking) as well as the technical test documentation for say a turbo swap with more power. It just makes modifying everything crazy expensive and complicated. That bracket has been lost in translation many years ago I assume, it was not there.
    • Hahaha, yeah.... not what you'd call a tamper-proof design.... but yes, with the truck setup, the lines are always connected, but typically they sit just inside the plane of the rear metal mudguards, so if you clear the guards you clear the lines as well. Not rogue 4WD tracks with tree branches and bushes everywhere, ready to hook-up an air hose. You can do it externally like a mod, but dedicated setups air-pressurize the undriven hubs, and on driven axles you can do the same thing, or pressurize the axles (lots of designs out there for this idea)... https://www.trtaustralia.com.au/traction-air-cti-system/  for example.... ..the trouble I've got here... wrt the bimmer ad... is the last bit...they don't want to show it spinning, do they.... give all the illusion that things are moving...but no...and what the hell tyre profile is that?...25??? ...far kernel, rims would be dead inside 10klms on most roads around here.... 😃
    • You're just describing how type certification works. Personally I would be shocked to discover that catalytic converter is not in the stock mounting position. Is there a bracket on the transfer case holding the catalytic converter and front pipe together? If so, it should be in stock position.
