Central Coast & Newcastle People - Meetup To Go To Show N Shine
OMG.. andrews alive!!!!!!!!!! Will wait for a text from u.. that or ill be banging on the front gate at 6am!! haha
:P haha hey man. banging on the gate..... or throwing rocks at our bedroom window ...... its all good!! lol i'll sort it out man.
So WTF is going on? Im confused.
Is the meeting point at the F3 servo or opposite the RTA truck inspection station or both?
Can someone post the FINAL details please. Including meet time and departure times from whatever meet point.
i think there should have 2 meeting points for the coast because comming from the south end of the coast is a bit much to come up to the twin servos
Hence why I was thinking about only having 1 meet point which will be at the foot of Mooney hill just before the hawksbury bridge. :)
Keeps the northerners and southerners happy. :D
Hence why I was thinking about only having 1 meet point which will be at the foot of Mooney hill just before the hawksbury bridge. :down:
Keeps the northerners and southerners happy. :)
You mean where the exit to the old pac is heading towards sydney but on the actual old pac rd cause no much room in off ramp bit?
drew, on the off ramp there is plenty of room ( depending on trucks..) if not yes go around the corner and park on the old pac. will just have to turn around
thats what i was sayin last night. old pac side before the freeway entry. the freeway side will be packed with cars that oldies own, comming home from theyre weekend away, bladders and bowels failing on them why they que and clog up the public toilet haha :blink: 7:00 - 7:15 meet leave around 7:30 gives us a nice hour and a half to get us all there on time. whatchoo think fella's?
    • From the pictures I have when doing the job the flywheel is the same diameter, I don't think they're playing weird tricks like putting weights at the outer diameter to increase flywheel inertia or anything like that. The OEM flywheel is definitely heavier, but it's not a huge difference. Quoted weight savings of the clutch is 2 kg so I can't imagine the flywheel being lighter than ~7 kg. Kind of regret not weighing it before the clutch went into the car but as far as driveability goes I have no complaints.
    • HKS trigger kit should be very easy to integrate with a Link. It's a 36-2 crank trigger. Hard part is finding the motivation to take off the timing belt and everything on the front of the engine to install it. You also need to cut out a hole in the oil pump housing so the sensor can read the trigger wheel. Changing out the cam sensor for a 24 tooth setup is probably good enough but as others have mentioned depending on what underlying assumptions are changed it becomes more of a problem. Reading the crank state off of the cam is an abstraction that works in the general case, but if you have an edge case it makes less and less sense. There is a GTX2860 gen 2 that can take a compact 5 bolt housing so it's direct bolt on but I'm not 100% sure of what's involved. Peak compressor efficiency drops off a bit on these turbos vs -5s, 77% vs 73% but you get way, way wider region of operation. The -5s have a really strange surge line in their compressor map that is all over the place. If you think the hot side on the -5s aren't open enough you can try the Tomei T550B turbos which a local tuner seems to be happy with:
    • i need a complete tail light for my R33 GTR if you have please let me know.
    • I need a great maintenance workshop around Idaho, if you know one please let me know..
    • Hello friends, i have a good friend in Canada that looking for a good condition 1993 GTR around him please if one or know someone around you that is willing to let it go please let me know so that i can inform him.....Thanks
