hey guys
have been tossing up this idea for a few weeks now and have made up my mind to sell the skyline as i have my eyes for something else now.
so details are:
Model: R34 GTT
Colour: Nissan WHite (QM1)
Bodykit:Factory kit
Engine Type:RB25DET
Engine Mods:
GCG high flow turbo running 1.1bar daily
FMIC
450cc injectors
HKS cam gears
Apexi power FC
Z32 AFM
Power:the car had 500CC injectors which i sold so for now has 450cc injectors so changed mapping to run it at a safe level so power atm is 238rwkw. but the sale will come with a set of denso 670cc injectors either installed and tuned or seperate but with the sale which will bump the power to 280rwkw
Exhaust:custom 3" stainless steel bell mouth dump pipe, 3.5" highflow metal cat, 3" custom stainless cat back exhaust.
Gearbox:standered 5sp with exedy 3puk button clutch
Diff: stock nissan LSD
Brakes:stock
Suspension:Racing logic coilovers
Wheels/Tyres:18X8 +30 350Z track wheels bridgestone SP sport rubbers for street. 17X8 fronts and 17X8.5 rears +35 offset AVS model 6 wheels for track (you get both wheels with the care)
price im after is $24000 thats incuding RWC and rego till may 09 OR WILL TRADE FOR EVO 8 WITH CASH ADJUSTMENT YOUR WAY the car is very clean and straight and is always service every 5000kms with only motul fluids.
any inspections or tests welcome. no tyre kickers. serious enquires only.
ta
Ash
https://www.sau.com.au/forums/topic/299320-1999-r34-gtt-5sp-manual/
I'm fairly certain that someone is putting a deposit down on this today. Just FYI.
And he forgot to add in his initial post that the subs/amp is not included.
over the next few weeks car will be going through a minor make over and changes :D
new Blitz return flow intercooler (nice and legal)
new front bar freshly painted along with resprayed guards and bonnets.
guards are being resprayed as im getting the guards rolled. to prevent paint cracking and longer lasting id rather get the guards resprayed. the bonnet will be done also giving it a new front end :D
also some engine bits will be powder coated as well along witht he new cooler still giving the stealth look. then to finish it off a final tune just to make sure its all running 100%.
yes i know i should stop spending money on it but this way whoever buys the car will now it was well looked after and pampered :P
  • 1 month later...
  • 1 month later...
    • GTSBoy on your suggestion on another thread I had a look at those injectors and ended up getting them because of the quality.  Got the expensive ones.
    • Hey guys been looking everywhere to try and find the correct gtr hood latch support part number but only found the first half and when I search with that number it sends me to an r34. The first part I found was 62515. If anyone could help me with the rest then I’d really appreciate it. Or if there’s some alternative hood latch support that would work even better cause I can’t find any for sale. (Searched on upgarage, partsouq,buyee,rhdjapan)
    • If you've only done the upper control arms on the rear, AND you have changed their length (by more than about 1mm) to set the camber you want, then you will definitely need/want to install traction arms also. Adjusting the camber arms on their own WILL introduce bump steer and make the car unpleasant to drive. Most owners have no idea that their car could behave infinitely better than what they put up with. I'm not entirely sure what the Stageas need, but I am thinking that unless you have massive front spring rates and pretty soft rear springs, you have waaaay too much rear bar. Oversteer city, in my estimation. Combined with possible excessive bump steer from maladjusted arms, that could be a recipe for nastiness. ATR43SS2 is not a highflow. It is an outright replacement turbo. It's a little bit bigger than the largest highflow profile that Tao does. Probably a solid 300rwkW turbo where the bigger highflows will be about 30-40rwkW less. Nevertheless, we're only talking about ~300 rwkW, which is well within the abilities of the stock ECu to run with a Nistune on board. I would do so without hesitation - and I will be doing so when I get my finger out and actually get the injectors and AFM installed. But, if you would prefer to drop a whole lot more money on the ECU side, then I suspect you're looking at Haltech. The Haltech fanbois here will all spout on about all the available engine protection you can have, that you can't have with the Nistune option. And they're right. But it doesn't really come for free either. You will spend more money on extra sensors and the like, plus the work to install them. If the engine was built and therefore represented a big investment to protect, then I'd say definitely do it. If you view the current (and forever into the future) shortage of replacement engines as something to prompt similar protection, then also, do it. If you see a destroyed RB25 as an opportunity to put in a Mercedes or other V12 (like I kinda do)... then your perception of the risk/reward might differ. These are good injectors. You can also get a "better" set of the same with more flow matching, for more $$. 1000cc is where you will want to be. You will need an R35 AFM and adapter tube if you want to stay with Nistuned stock ECU. Otherwise, if going Haltech, you can ignore. As for intercooler. Just about anything will do. You're only talking about ~300rwkW. Just put a big core in there. Be aware that return flows do add significant pressure drop and will cost power and will make the turbo work harder to achieve the same goals. If you can manage a proper crossflow, do it. I'm keeping my very good return flow because I'm only expecting to be in the ~250rwkW range, and will live with whatever outcome I get.
    • I have a heap that i have collected if you want some authentic ones still. Pm me if your interested!
