hey guys
got some stuff to clear out need cash for a new rig
2 x R32 front guards, both great condition custom blue in colour
$100 each
2 x R32 sideskirts one is in perfect condition, the other has a crack can be repaired no worries
$70 for the good one (white), $20 for the cracked one (silver)
1 x GTS-T bonnet, perfect nick still original paint so not the best condition ie stonechips and whatnot, still has original skyline badge
$80 (silver)
1 x damaged GTR bonnet will get pics up later tonight damage above both headlights still light as maybe good for a drift car
$100
nardi signature wheel with boss kit to suit R32, fairly worn still looks great no horn button
$180
1 x R32 GTR front bar with N1 vents, original plastic bar with lip, bit of cosmetic damage repairable, getting so hard to find these in todays market i searched forever to find one
$500
thats all for now got plenty more will post later, pics later tonight
contact via pm or [email protected]
cheers
Kyle
Edited by RBLUV
https://www.sau.com.au/forums/topic/299348-parts-clearout/
If the nardi is genuine i will take it pickup with the boss kit.
will also check out the side skirts while im there.
where are you located?
Could i get a picture of the wheel?
would the side skirts fir on a 32 gtr?
Edited by Antstar
https://www.sau.com.au/forums/topic/299348-parts-clearout/#findComment-4977051
  • 4 weeks later...
    • Hey lads, reviving an old thread.  As an update, since the last time replied to this thread, ive done mostly suspension. Havent touched the motor except for maintenance. Though upon changing spark plugs, found out i had splitfires pre-installed! Updates: - Got me some stock airbox top cover and snorkel to fit onto the original intake. Should be free of defects - Bought a set of R34 GT-T brakes (not installed yet, going to rebuild + respray in champion blue + white 'Nissan' text) - Bought the last set of bilsteins from @Sydneykid and had them installed. Has been making some sounds on the rear but hopefully should be sorted out after this New Year break. - Regreased front caster rod bushings (poly bushes..) - Rear upper camber arms - Whiteline sway bars (BNF27Z 22mm + BNR11XXZ 24mm).  The rear sway bars are a bit short (ive read 50mm else where) but was still able to get them in.  Anyhows, I reckon suspension is sorted now. Maybe replace bushes (do have a set of front upper control arms from SK not installed yet) but should be okay for now. From now, I'm wanting to start working on the motor, drivetrain etc etc. Still debating on the order to go on and what to buy etc but: - ECU ( Haltech or Link ( Link states that it dont support A/T or AWD functions... Can anyone attest to this? ) - Highflow turbo ( ATR43ss2 ) - Intercooler ( Not decided yet, but cant find many good afoordable ones. Toshi says to opt for crossflow Japanese. Bit difficult this one, unless I get a returnflow Blitz from JJ? ) - Injectors ( Any recommendations ? I do have a nismo FPR ( Thanks SK ) ) - Seats - Tune by either Toshi or DVS To be fair, I did consider just keeping the stock turbo and nistuning it. Sat in a mates stock N, that had something like 200kw, and I reckon that felt more than enough. Maybe I should just go this route ahhaha. Too many choices.... Planning a trip down south, so wanting to just clean things up and make sure it gets to and from in one piece. Anything else specifically I should do before ? Cheers lads
    • Must be for the car’s lucky charm 🤷🏽‍♂️ She runs fine, but it just seems to take about 1L less. Maybe I’ll have the oil sump dropped at some point to check if there is anything
    • Hmmm interesting. Mine is the exact same and clearly the right one.  The mystery of the engine oil being full after 3.5-4L continues
    • Yes I as well would like to find out where I could get some of the seat material with the red or blue small squares in it
