R34gtt 1998 motor.
Forged Aries pistons 30tho
main and conrod king bearings
crank ground balanced
pistons rods balanced
Gates performance timing belt
crank fitted with r33 harmonica ballancer as other was damaged
block was checked and acid bathed
new valve stem seals in head, cleaned and re surfaced.
hks 2mm stopper type headgasket but head removed from motor for inspection
Cams not included.
Motor has been run for aprox 100km. Not yet run in
Built by superbalance. over $3000 spent on rebuild
open to reasonable offers $1000 and above only!
Garrett gt3582 t3 turbo New never used. $ open to reasonable offers
Turbo smart Ultragate38 2 bolt External waste gate. Never used .New
Engine does not include auto trans wiring harness and computer.
Picks upon request
Also have 33gtr complete plenum with homemade adapter plates and aftermarket injecters to fit up to neo or rb25det engine. $ open to reasonable offers
Email [email protected]
Ph 0431423291
https://www.sau.com.au/forums/topic/299367-fs-r34gtt-forged-engine-and-parts/
R34gtt 1998 motor.
Cams not included.
Picks upon request
Ph 0431423291
located Cobram Vic 3644
    • Everything I found online said never use it because it'll dramatically reduce belt lifespan.  No, but I have seen excessive v-belt tension cause the audible bearing noise from excessive radial load in things like alternators. So don't overdo it. Ideally you set it to manufacturer spec using a proper belt tension guage. I tried the "clicker" type gauges but those cheap things are trash. They read way too low even when you're careful.
    • This is kind of where I've ended up for the most part. It's easier for me, easier for shops that don't have to deal with my weird criteria/picky standards, etc.
    • Will do. Suprised if it's not the starter motor considering it's 30 years old. Will get a volt meter though. Battery is close to new.   Cheers for your help, always appreciated.
    • This almost never happens these days. No. Clean your battery terminals and make sure they are tight. Use sandpaper on a dowel if you have to, to get oxidation off the inside of the terminals, particularly on the -ve. Check the earth cable from battery post to chassis ground and engine ground. Make sure the contact surfaces are clean - including the threads on the bolts that anchor them - because that's where a lot of the contact occurs. Wire wheel on a drill is a good thing for this. Make sure the crimps on those cables are all sound. Assuming none of that causes an improvement: Check the battery voltage after it has been resting for a while. If it's at the lower end of the range, put it on charge for a while, then see if it will crank better.
    • I just checked my belt, it wasn't super loose but I could bend it past 90 degrees a small amount so I tightened it up and for the first time ever my car didn't crank first time, had to crank it again lol. Don't know if that was because I tightened the belt or if it's my starter motor going out (been having slow starts for some time). Coulda also been when I was recording I didn't crank the key properly and it didn't save the recording lol.   Is that a thing if you overtighten a belt it struggles to start?
