Drift Gearknob - Used it for about 2 months before going back to the stock S15 gearknob because the leather doesn't tuck into this one. Comes with I believe 4 different thread sizes so it will fit any car. Paid $60 for it, you can have it for $40.
Stock S15 tail lights - Been tinted and look great. One has a chip at the bottom that can't be seen when it's on the car, a bit of the tint has pealed off but that's mainly on the black section anyway so it can't be seen. No leaks and things like that, all work fine. I'm after $70.
Under car Neon's - There are 2 normal ones are are 72cm long each, and there are 2 LED ones that come with a controller. The LED ones come with a controller that can be programmed for up to 11 different patterns and are 140CM each (perfect for down the side of the car). Give me an offer for either or all.
Blackberry 8310 - Literally in brand new condition. Only used it once till my iPhone screen was replaced. It comes with charger/leather case/hands free and still has plastic on the screen and not a scratch at all! Throw me an offer
Pics can be seen below, sorry about the quality was taken from my phone:
http://s9.photobucket.com/albums/a65/STAWK...ent=2lights.jpg
http://s9.photobucket.com/albums/a65/STAWK...rent=2neons.jpg
http://s9.photobucket.com/albums/a65/STAWK...urrent=All4.jpg
http://s9.photobucket.com/albums/a65/STAWK...=blackberry.jpg
http://s9.photobucket.com/albums/a65/STAWK...=controller.jpg
http://s9.photobucket.com/albums/a65/STAWK...urrent=knob.jpg
PM me or reply to this, cheers
LMAO. They're brand new, I got em from a mate ages ago who was gonna put em on his show-car RX7 but sold it before he got to do it.
Under car neons and leds....
Are you for f**king real?
Throw me an offer. I'm just willing to sell it because I need the money. Like I said, it's in perfect condition with no scratches at all and still the plastic on the screen.
Throw me an offer, it can't hurt either of us
    • I agree that delayed payment probably isn't the most suitable solution. It seems a solid complete transaction would be best. As I wouldn't be using this sale as a line of credit that would typically earn interest, we can probably arrange a much cleaner single transaction deal. I can do $92.52 today. Would you prefer EFT, or Cash on Pickup?  😛
    • Oh man what a deal.... Funny enough (well not really) I sold a car to some old dude (buying for his Daughter) on a Saturday, He asked if she could take the car now and pay me the money on Monday as the bank wasn't open. Needless to say I told them to come back with the cash or get f**ked! Luckily the money seemed to magically appear in his pocket a few minutes later, so it all ended well (for me).
    • Gucci bags tend to hold their value well, so someone’s definitely going to get a nice find here.
    • @Ozdavroz Not going to get a better deal than that. Cash up front and ongoing payments. 🤑
    • I wouldn't even move it like gTSBoy is saying. I'd seriously do what Duncan is saying. Unplug the injectors, and unplug the fuel pump.  Pull the spark plugs out. Have a look in quickly with a bore scope if you want. At most, you can't spray a bit of oil into the bores so there is lubricant in there while you crank it. (Don't fill it, as it's only going to enter the exhaust, or spit at you out the spark plugs holes. Before cranking the engine on the starter, after a 5 year sit I'd probably prime the oil system manually. Easiest way to do so is to look at buying an oil filter relocation block, fit it to the engine. The pressure line going into the engine on this block you can then shove into some sort of oil pump, or put it into a bottle, with that hose going to the bottom. Fill bottle up with oil. Now seal the bottle and add a compressed air line to the top of the bottle. Feed compressed air in, about 20psi will be PLENTY. This will pump oil through the motor. Be aware, it also means it will drain back to the sump, so make sure you don't end up over filling the motor Now bolt the old oil setup back on (or fully install the remote filter system).   This way you've at least pushed fresh oil everywhere, then you're letting the motor crank to then do its own oiling. Then I'd tap the key to make sure it can start to crank, if the motor free bumps, then I'd just hit the key and let it crank. After letting it crank and seeing you can get real engine oil pressure, put new spark plugs in, reconnect the fuel system electrics, and send it.   Additionally, you can look to remove the fuel feed line to the rail, and divert it to a tank so you can get the bottom of the tank shit out, and just incase there's some crud sitting anywhere that gets passed the fuel filter (or is already ahead of it).   If fuel injection at the injectors ends up appearing to be a problem, you can dump the injectors into an ultrasonic cleaner for a quick flush clean out. Note this isn't as good as new injectors, or getting them pro cleaned and flowed
