Hey guys hows it going looking to sell my 1993 r32 gts-t ""I believe 1993 is the last of the series"
Im looking for 12,500 will be advertised on carsales for that but would take 12k cash in hand
Car got defected 2nd day i had it and cost me 4 grand to get is off , is sitting on stock springs and supension all round ,, all brand new stuff underneath the car includign control arms and hicas,, comes with nice lowering spring assemblies.
Exterior... darkish grey 2door coupe , gtr spoiler , standard front bar , gtr side pods , clear front indicators ;n1 headlights, r34 GTT rims 80%tread fronts atleast 65 - 70% rears , Red rear "Skyline centre garment"
Interior , matching Red skyline mats , nardi torino steering wheel , all gauges and cool stuff removed , but comes with , boost gauge in bottom mount cup , turbo timer and electronic boost controller ''Gizmo '' All uninstalled,,kenwood colour face deck with remote , has wiring for really good setup but was removed before i got it , so just rears fronts and tweeters,,,
Engine ,, rb20det 146,500 genuine kz has had 100k service, reconditioned head at some point has red rocker covers i think that is "gem remanufactured" as r32's have the black top rb20dets usually
*Fmic brand name intercooler , really nice alloy piping and setup , legally mounted passed regency ,, usually they fail due to cutting into supports and other things
*Big K&N pod filter , with Z32 AFM and professional wiring , not a twist and masking tape job
*Hypergear cored rb25 turbo , steel and upsized rear wheel , honed and bored housing , new freespinning centre bearing and new steel front wheel not sure of spec of front wheel,, have been told 18 - 20psi is safe but have never tried
*X-Force full exhaust , 3inch the whole way , highflow cat , highflow muffler , 5inch cannon , 3.5inch dump pipe ,, legal db was 90.6 at 4000
*stock bov with welded insides so flutters through compressor wheel
*550cc injectors unsure of brand i think bosch , bosch 044 intank upgrade fuel pump , new fuel filter ect
*Tomei adjustable cam gears , have been dyno tuned in not sure of advance and retardement....
*Remapped computer by jeff from speed lab
*Nismo short shifter setup
*Superspark coilpacks
*Irridium plugs
*New bleeder set up Turbosmart , was set at 14 , then went up to 15.5 on octance booster with the new coilpacks
*Exceeddy hd clutch
*Probably forgetting some other stuff!!!!
Recent tune , new oil plugs , coilpacks , new water pump , new radiatior , new thermo ++all the things taht failed at regency have print out of all thigns i have had fixed and signed off at regency....
Power figures ,,, on the earlier tune which was leaning out made 203rwkw on 14.5psi with stock coilpacks
have been told the tune im runnign now , 15.5psi and octane booster with coilpacks over 215rwkw more like 220rwkw
This car flies , eats 255 hsvs like nothing , uses the fuel of a 2l up to 3,300rpm then pulls you back in your seat all the way till 7,600 ,, programmed redline woudl make more power if the redline was brought higher,,,,,
Boost turned down to +7mmhg on the stock gauge which i estimate to be 8-9psi atm on request on test drive it could be tuned back up,,
great driver never overheats or stalls , clutch is a little bit short on pull in causes first to slightly grind if your not gentle into first , but when driving no worries shyncros are all good ,,
Would be keen on a swap for vx ss or wh statesman , need a big car ,, or a ute ,, this car is great fun but is a shame to put tools and drive to work,, any inquiries call or text me on 0404067684
https://www.sau.com.au/forums/topic/299409-fs-sa-1993-r32-gts-t/
    • Not R7R. Meant to type R&R, obviously enough.
    • Bugger "making it look stock". I put one conventional internally fused Hella relay behind each globe. I just pulled the plugs off the back of the globes and built new loom segments with male and female plug parts to match up to the original loom and the globe, and used the original power wires to each globe coming from the switch through the original loom plug to trigger the relays. Ran a big fat (also separately fused) power wire across the front of the car to feed all the relays. It's as ugly as f**k, but it is wedged down between the headlight and battery on the RHS and the airbox and headlight on the LHS, and no-one ever looks in my engine bay, and on the odd occasion that they do I simply give no f**ks for what they think. Fully reversible - not that you'd ever want to. For f**k's sake. It's a Skyline. They made million of the bloody things. We've been crashing them into roadside furniture for 30 years now. There is a negative side effect to putting relays on the headlights. The coil current is too little to properly clean the contacts in the switches and they get blacked up and you have to open them up every couple of years and clean them manually. I have 25 years of experience on this point.
    • I was poking through the R34 wiring diagrams vs R33 and noticed that the R34 has proper headlight relays while the R33 is like the R32 and sends full headlight power through the headlight switch. I'm not afraid of wiring but I really would like to do this in a way that looks OEM (clipping into open positions on the OEM relay box) and also unlike the factory wiring which interlocks the high beam and low beam on the halogen series 1 GTR headlights I want to make it such that turning on the high beams keeps the low beams on as well. Any advice on how to locate the specific connectors + crimp terminals + relays I need? I was thinking one NO relay for low beams and another for combined high + low running off the factory high beam headlight connector. I don't really want to splice into a crusty old probably discontinued factory harness so fully reversible is my goal here.
    • Pretty sure they run the same engine as the Q50 hybrid which specifies 95 RON.  I ran 98 in mine for a while, but it made no difference in performance or economy, so I have been using 95 for the last few years.  I have never hit 6.0L/100km, but have returned mid to high 6 on the highway.  Being a hybrid, fuel economy is a lot more dependant on how you drive it.  At 110km/h, mine never goes into EV mode on the highway, so returns closer to 7.5L/100. urban driving can return low 8s if you are careful or over 10 if you are a bit more enthusiastic on the throttle.
    • About a quarter of what you want to do. It's only R7R, not R&dismantle&replaceparts&reassemble&R. ? It is stock. I already told you, you will NOT have broken those. It's f**king 4th gear for Christ's sake. You just chipped the teeth off.
