Took it to the track today on Federal 595 SS. I am going to a sprint meeting in Stanthorpe on the weekend, and with rain forcast I want to know what they are likely to do.... They squirm and load in a really scary way in the corners and under brakes. However the are good for straight line grip and drifting on.
  • Replies 119
Posted Images
I really can't complain, there a 235/45/17 which we get cheep for drifting on. bang for buck there a good thing.
Playing with intercoolers today, the old 1 had a fair bit of damage on it from the last 7 years of use and lots of abuse. Tested it on the dyno, 310rwhp on 1Bar. Not bad for a streeter.
Went to Stanthorpe for the Short Circuit Supersprints this weekend. 2nd in class (Improved Production) and 3rd outright. Pretty happy with that, only beaten by an FC RX7 Sportsedan and a 510rwhp commodore Improved Production car. Not bad for number plates.
Edited by Noddy
starting to look at the race car shell, looking and thinking about engine placement, "V"mounting the intercooler/radiator, steering/geometry and so on..... which to tackle first? I'm thinking engine first the fit all i around that. Or cross member?
  • 1 month later...
I'm sad to say, the motor is out and in lots of pieces. Not for any bad reason like a spun bearing or anything like that. In a nut shell, the rings have been a concern of mine pretty much from the start.
When I built it at Christmas, the Oil control rings just wouldn't sit properly, they would bind up to the point that they really didn't fit. I ended up using the old spring, 1 new scraper on the bottom and an old scraper on top. Not ideal but it got it all back together. This has played on my mind since the beginning. I have decided after an airlock overheating event, to replace the rings and head gasket (which was reused as well), and give everything a good look over. Every thing looks pretty good, excellent even, that is other than the rings, they definitely look 2nd hand. The bore is spot on, thank God. Te exhaust manifold has cracked in the same place, again, so I'm getting Mercury to make a new 1 for me, Just couldn't be bothered making it this time.
What I have found is that ACL had ROSS in the US. make the pistons with an odd ring size, so you had to order through ACL to get new rings. Turns out that some one decided that was a dumb idea and changed the specs to a regular commonly available size of ring, ACL they no longer stock the odd size rings. Luckily ROSS do stock them.... I think, I've ordered a set in the hope they are correct for my pistons. The most confusing thing here is, there is only 1 part number on the pistons, even though there are 2 different ring specifications.
Waiting for the postman takes soooooo long.
Edited by Noddy
  • 3 weeks later...
  • 3 weeks later...
Got the car to a meeting this weekend, last round of the Preston Peaks, Qld v NSW SuperSprint series at Carnell in Stanthorpe. Came 1st in class and 2nd outright. I got beaten by a WRX sportsedan, this is his run at bathurst hillclimb
He set a new standing start super sprint 4 lap reccord, 2min, 19.57 sec. I got close.... 2min, 21.48sec. Not bad for a car that is my daily with a full interior.
So with the series now over, I have won Imp prod over 3L and the series outright. :worship::):D
    • If it's magnetic what is stopping you from using a magnet on a thin wire from fishing it out?
    • Those 2 solenoids in that assembly I mention, are the PWM solenoids for torque converter lock-up clutch & EPC (line pressure control) ~ when most folks hear of 'solenoid failure', the tendency is to think electrical failure...but fact of the matter is, especially wrt the EPC solenoid (which is moving/running all the time), you can have an electrically 'good' solenoid, that's absolutely broken/worn out mechanically inside...ie; valve plunger return spring rubbing against spring retainer plate, lowering preload pressure.. ...and the solenoid armature extension limit spring wafer with bad wear/broken off petals... ...and if there's ever been any metal flying about, damage to the valve plunger end itself... ...the stuff one never really sees, unless you go the whole 10yards trying to answer the question "why is my line pressure screwy, but TCU isn't flagging any EPC solenoid fault?"...and carefully dissect the solenoid. Worst (and most probable) scenario is when the plate spring petals break off, they get held by the magnetic flux, get mashed up by the armature into little bits, which end up in the space between the armature & shading core bore, and things get stuck or randomly jam up, and your line pressure goes flat and doesn't change...and the TCU never sees it, as it doesn't actively monitor LP... ..then it gets into insidious land, if you end up with lower than expected line pressure...lets say high clutch..and the lower pressure causes it to slip ~ when I say 'slip', think say 2000rpm on the drive plates, and 1800rpm on the driven plates, because the slip is making them under-rotate by 200rpm ; you get all the usual nasties like heat and band/clutch wear, but even if it's only 20rpm slip the same thing happens...and... you'll hardly ever pick this up driving the thing with the torque converter active as it effectively masks these sorts of slippages that are line pressure related ...(the newer TCUs can detect clutch slip rate)...just  FYI as it were...
    • There's nothing that some paddle pop sticks and extra cable ties can't fix.
    • Hey guys, so Golebys has good prices on Bosch injectors, and also sell an adaptor to go from 1/2 length injector to standard with the Nissan 10.5mm top seal.  Does anyone know if that adaptor is to suit the 14mm or 11mm injector tops?  And re. The bottom seal, to suit my standard RB20 intake, would I be right in saying I can just slip the 14mm square section O ring over the bottom of the new injector and done? Thanks in advance guy, Cheers, Rowdy
    • F my life. I was changing the oil on my R32 GTR today as usual and ran into a bit of a snag. I drained the oil out and was getting ready to finish the job by tightening the drain plug, however The stupid magnetic oil drain plug snapped in half, right at the magnet part. After about an hour of trying to remove it, I used a drill bit, which unfortunately pushed the magnet all the way into the pan, and just leaving the hollow threaded part of the bolt remaining. I was able to remove the hollow portion of the bolt from the oil pan with some pliers but the magnet is still in there.  So, the question is, should I drop the oil pan to get the magnet piece out, or is it okay to leave it in there? I really dont want to drop the pan, i'm about to go nuts.  PSA: Do NOT buy a BLOX magnetic drain plug. This is the one i had.    https://bloxracing.com/products/magnetic-oil-drain-plug-m12x1-25mm?variant=37131252859052&country=US&currency=USD&utm_medium=product_sync&utm_source=google&utm_content=sag_organic&utm_campaign=sag_organic&gad_source=1&gclid=CjwKCAjw47i_BhBTEiwAaJfPpgti1D2JwO7TDuMpXuqeQPCuIQSAfwxpWQH5rF9MD7sm5SCZDWLR_RoC_YoQAvD_BwE
