Took it to the track today on Federal 595 SS. I am going to a sprint meeting in Stanthorpe on the weekend, and with rain forcast I want to know what they are likely to do.... They squirm and load in a really scary way in the corners and under brakes. However the are good for straight line grip and drifting on.
  • Replies 119
Posted Images
I really can't complain, there a 235/45/17 which we get cheep for drifting on. bang for buck there a good thing.
Playing with intercoolers today, the old 1 had a fair bit of damage on it from the last 7 years of use and lots of abuse. Tested it on the dyno, 310rwhp on 1Bar. Not bad for a streeter.
Went to Stanthorpe for the Short Circuit Supersprints this weekend. 2nd in class (Improved Production) and 3rd outright. Pretty happy with that, only beaten by an FC RX7 Sportsedan and a 510rwhp commodore Improved Production car. Not bad for number plates.
Edited by Noddy
starting to look at the race car shell, looking and thinking about engine placement, "V"mounting the intercooler/radiator, steering/geometry and so on..... which to tackle first? I'm thinking engine first the fit all i around that. Or cross member?
  • 1 month later...
I'm sad to say, the motor is out and in lots of pieces. Not for any bad reason like a spun bearing or anything like that. In a nut shell, the rings have been a concern of mine pretty much from the start.
When I built it at Christmas, the Oil control rings just wouldn't sit properly, they would bind up to the point that they really didn't fit. I ended up using the old spring, 1 new scraper on the bottom and an old scraper on top. Not ideal but it got it all back together. This has played on my mind since the beginning. I have decided after an airlock overheating event, to replace the rings and head gasket (which was reused as well), and give everything a good look over. Every thing looks pretty good, excellent even, that is other than the rings, they definitely look 2nd hand. The bore is spot on, thank God. Te exhaust manifold has cracked in the same place, again, so I'm getting Mercury to make a new 1 for me, Just couldn't be bothered making it this time.
What I have found is that ACL had ROSS in the US. make the pistons with an odd ring size, so you had to order through ACL to get new rings. Turns out that some one decided that was a dumb idea and changed the specs to a regular commonly available size of ring, ACL they no longer stock the odd size rings. Luckily ROSS do stock them.... I think, I've ordered a set in the hope they are correct for my pistons. The most confusing thing here is, there is only 1 part number on the pistons, even though there are 2 different ring specifications.
Waiting for the postman takes soooooo long.
Edited by Noddy
  • 3 weeks later...
  • 3 weeks later...
Got the car to a meeting this weekend, last round of the Preston Peaks, Qld v NSW SuperSprint series at Carnell in Stanthorpe. Came 1st in class and 2nd outright. I got beaten by a WRX sportsedan, this is his run at bathurst hillclimb
He set a new standing start super sprint 4 lap reccord, 2min, 19.57 sec. I got close.... 2min, 21.48sec. Not bad for a car that is my daily with a full interior.
So with the series now over, I have won Imp prod over 3L and the series outright. :worship::):D
    • Back in January, I noticed my car felt noticeably weak. I had the injectors cleaned, which seemed to solve the problem -- until now. Recently, the car suddenly lost power again while driving. Suspecting the injectors, I brought it to the mechanic. He recommended replacing them entirely, saying the current ones were getting unreliable and fiddly to work with. I could not find a direct replacement for my current injectors. The closest match I found were 440cc injectors. This led me to look into the possibility of upgrading -- and of course, that would mean remapping the ECU. From my research I found: The OEM Part numbers are 16600-72L20 and 16600-72L21 Both the RB20DE and RB20DET use the same 270cc injectors. There are much better options out there over the old OEM injectors. Nistune could be a viable tuning option. While the RB20DE isn’t explicitly listed on their site, the ECU is essentially the same as the GTS-T version - just with a different map. The ECU code on mine is listed as supported. One concern is finding a tuner who works with Nistune. Aftermarket ECU like Haltech and Link, but this would be the most expensive choice (and possibly overkill for a mostly stock RB20DE) I admit that I am very new to the tuning scene and would appreciate any insight or recommendations regarding this.   These are some SAU links where I got some of my information from for reference: https://www.sau.com.au/forums/topic/380324-rb20de-injectors/ https://www.sau.com.au/forums/topic/477396-factory-270cc-injectors/
    • The inspectors are not forensic by any means but if you forge your documents and/or badgings on vehicle parts and are found out, the consequences are just far bigger than if you just run illegal parts. And their job quite literally is to cross reference what parts you got installed and what your papers say you got. Something as silly as your suspension being 1mm too low will fail you. Nonetheless I asked if someone knew the damn pipe and I certainly did not ask for smartassery or underhanded comments, no idea why you need to be told this. Great way to waste both our time.
    • As useful as you explaining what forgery is... But then again, I wasn't aware your inspectors were also forensic experts and inspect nameplates on each component to confirm everything is original. They must inspect roughly 3 cars a year at that rate. You're right though, my comment doesn't help you in anyway, so I'll go talk to my wall now. Cheers.
    • Say that to the guy that is going to fail your inspection or tow your car for illegal exhaust modifications. If you have anything else useful to say, please go tell your wall.
    • You must be fun at parties.
