I was under the influence that SWM are just that, last time I saw some for a 1600 they were just torana radius rods machined down.
'machined down' meaning that they have more thread cut into them, not changing the overall diameter.
But hey what would I know, Ive just been running the same style machined radius rods on different cars for the last few years, no breakages to date. :cool:
Edited by works 510
sweet.
Any pics?
Should be plenty easy in the bluebird when I think about it, already has CA18 and s13 coilys,knuckles etc
I'll see what I can do about getting some pics :ninja:
if u runnin a s13 crossmember, im also assuming u could use a laurel member as well to run a rb ?
No bump steer issues thus far, but as far as I can see there should really be any, as it's pretty much transfering the complete S13 setup from one car to the other with minimal geometry changes. I dont see why you couldnt use a laurel cross member as all mounting points are identical between the S13 an laurel.
If all the bushes up front were new (nolothane orsuch) wouldnt it be alot better?
Look for the various bracings and reinforcements that can be done.
If George Fury & Glen Seaton could smash around the tracks with so much success in the 80's there aint too much reson to change is there?
I guess as Nissan engineered newer cars, the steering designs got better. Newer is normally better hey!
Steerign box rebuild alone costs around the $400 mark, so i guess that cost wont need to be repeated with the s13 spec conversion
yea no wat ya sayin, bak in the 80s the drs were new !
less moving parts has be be better, youd be able to get more lok wit s13 rack + all the aftermarket goddies to go wit it
Engineer wouldnt like my castor rod mods unless they were re-heat treated etc, but I dont see why the s13 front end bits would be a major hassle assuming its a all bolt in affair using standard nissan parts that havent been modified in any way?
Changing the crossmember?
Unless the mount holes are identical to the 1600 or R30 & the rails need to be redrilled to suit, the engineer or Vic Roads is going to want to know about it.
Using the R31 crossmember, I know the mount holes are different spacings, cutting & welding the rack mounts onto an R30 crossmember requires engineers approval. Depending on how picky your authorities are and in Vic they are pretty leaniant unless the car is being sold, the S13 bits might create a problem then.
Don't know, but in NSW it's a bit tough, due probably to people like me when back in the 60's we were putting V8's in Morris Minors and 105E Anglias and 1800/2000cc MGB motors in A30's & A40 Farinas without a care in the world. I know 1 guy that put an 4.2 Jag motor into an FE Holden and the torque twisted the chassis/sub frame so that only 3 wheels touched the ground at any one time.
Cheers, D
    • Got the motor out and torn down. I'll be dropping off the block Monday. Luckily the scoring on Cyl6 is much less pronounced then the pictures made it out to seem. It can barely be felt. If you pass your finger over it 10x you'll barely notice it. Hopefully by some chance it will only require a honing. I'm not in the mood to buy one size larger pistons or another block. Oddly enough my 6th cylinder with the scoring has extremely clean intake valves compared to my other 5 cylinders. I'm worried the scoring was caused by too much fuel or Water/Methanol washing the cylinder. I'll review some old logs to confirm.  This was also the first time I pull an engine with the transmission still attached. It went much better then expected. I was worried my CD009 wouldn't make it easy due to its sheer size but it was much easier this way.
    • From the pictures I have when doing the job the flywheel is the same diameter, I don't think they're playing weird tricks like putting weights at the outer diameter to increase flywheel inertia or anything like that. The OEM flywheel is definitely heavier, but it's not a huge difference. Quoted weight savings of the clutch is 2 kg so I can't imagine the flywheel being lighter than ~7 kg. Kind of regret not weighing it before the clutch went into the car but as far as driveability goes I have no complaints.
    • HKS trigger kit should be very easy to integrate with a Link. It's a 36-2 crank trigger. Hard part is finding the motivation to take off the timing belt and everything on the front of the engine to install it. You also need to cut out a hole in the oil pump housing so the sensor can read the trigger wheel. Changing out the cam sensor for a 24 tooth setup is probably good enough but as others have mentioned depending on what underlying assumptions are changed it becomes more of a problem. Reading the crank state off of the cam is an abstraction that works in the general case, but if you have an edge case it makes less and less sense. There is a GTX2860 gen 2 that can take a compact 5 bolt housing so it's direct bolt on but I'm not 100% sure of what's involved. Peak compressor efficiency drops off a bit on these turbos vs -5s, 77% vs 73% but you get way, way wider region of operation. The -5s have a really strange surge line in their compressor map that is all over the place. If you think the hot side on the -5s aren't open enough you can try the Tomei T550B turbos which a local tuner seems to be happy with:
    • i need a complete tail light for my R33 GTR if you have please let me know.
    • I need a great maintenance workshop around Idaho, if you know one please let me know..
