rofl thanks, i may take you up on that offer!
hey craig, while my car is in pieces, might be a good opportunity to swap something over for a week or so :bunny:
been waiting....my cars less than 2 km's away....I'm away from this Thursday till next Monday though ;)
Alright, so I will be selling my spacer kit for Vic owners which will include install if you are willing to make the trip to my place
Kit includes;
1x 19mm thick Phenolic Spacer (can paint sides to blend in with engine - although I am still testing this for paint durability)
1x Nissan Gasket
1x Extended Bolt Set
1x Bracket set
Those that are interested or have further questions, feel free to ask!
EDIT: I only have 5 of these spacers available.
Edited by iamhe77
  • 2 months later...
Kit includes;
1x Nissan Gasket
1x Bracket set
Hi iamhe77.. where are you located and what is the price installed?
Cheers.
  • 3 months later...
  • 3 months later...
hi Guys,
i was cleaning out the garage and i found the Spacer Kit i bought from Craig. I had it on my stagea but took the kit off late last year when i was selling the car.
All the parts are there + the plenum gasket.
so if anyone is interested let me know.
i live in sydney but i can organise postage if i have to.
Thanks
Stefan
Any for VQ25DD?
PM me your VIN and I will see what yours is compatible with (VQ25det is the same as VQ23de only :/ ).
I am sure I could make one up for you if I had a gasket.
Have you put a plenum spacer to increase the volume of your plenum (should possibly be the same as VQ35de)?
    • Well some mostly good news and some slight bad news.  Good news is cylinder 6 did in fact only require a honing and I'm good to run my 86.5mm pistons again. I should also get the block back by end of week. Bad news, had a few surprises pop up. First, main and rod bearings were trashed. No sign of any heat damage. I knew right away what caused this... I had not packed my oil pump originally and spent a lot more time than I would have liked cranking the motor to get oil pressure. It sounded fine once started so I chucked it up to luck and forgot about it. Luckily rod and crank are fine and just need new bearings. Engine builder agreed that this was the cause.    Another surprise that carbon covered up very well that I didn't catch, something got sucked up and went through cylinder 1, 2 and 3. Luckily this was no cause for concern, just needed a bit of cleaning up. Valves look fine but he will vacuum test the head this week to confirm. I'm presuming this was something left over from welding my intercooler piping, but we'll never know. I'm going to thoroughly reclean everything.    So all in all, happy the motor is fine, and I'll get it back much sooner than expected. I'll also be taking the time to convert my WMI system over to direct port. I'll snap some pictures of that when the parts come in.
    • I understand, thanks. Yeah I wouldn't want the car to tip over, I'll try and use the sills, I don't want to risk smashing the chassis rails. I ordered some rubber pucks that have a hopefully big enough slotting. If the front right gives me trouble I can always just make a wood block. I'll measure and inspect the sills closer once I actually take the car up. I hope so, but the rubber blocks I had in hand so far were pretty damn firm, if they are that hard they won't give much way. I'll let you know what happens. Angle grinding rubber isn't one of my favorite tasks. I'll probably start a build thread soon, for my own documentation and "log" as well as sharing what's going on with the car.
    • Kinda something I have been thinking about.  To be honest, we bought it already driving like that.  So there's no telling how long it actually has been driving like this.  Hopefully damage is too bad when we drop the pan.   I am having a hard time finding a site that sells the solenoid for the 5 speed auto, do you have any suggestions?
    • That'll be most likely down the road...  LOL
    • a stock / option or aftermarket?
