PM me your VIN and I will see what yours is compatible with (VQ25det is the same as VQ23de only :/ ).
I am sure I could make one up for you if I had a gasket.
Have you put a plenum spacer to increase the volume of your plenum (should possibly be the same as VQ35de)?
Nah haven't tried a plenum spacer, where can I find those?
I am pretty sure that your plenum is the same as a V35/G35, but I'll check tonight just to make sure.
If it is the same, you can get one from the US (eBay is easy) OR my mate has an aluminium one he made for his V35. I will talk to him tonight and see if wants to let it go.
Isn't it better to have one that doesn't trransfer too much heat to your intake plenum?
Yes... with a runner spacer it definitely is.
With a V35 plenum spacer it makes no difference as the spacer is installed between the top and bottom sections of the standard cast alloy plenum.
lol... thanks mate... although the torque increase is there I have yet to dyno it.
Would be tricky to get an accurate comparison though as the engine needs to be cold to install the spacer kit.
Ryan, as per the first post... the original was 17mm as that was the size aluminium we had access to. It was modelled of the 20mm aluminium TEPS unit. When I switched to Bakelite, I wanted to go with a taller spacer to see if there was a noticeable performance increase (unknown) and also so it could soak up a bit more heat from the engine due to the larger area.
So does that mean if a 30mm spacer would fit under the bonnet you'd do it?
I'm thinking if the engine cover fits back over the engine with the spacer installed, I should be able to fit a spacer and a strut brace no problems. Hopefully we'll find out tonight :thumbsup:
i dont care what cam tells you.
the cover DOES NOT fit back on with the spacer.. it touches the bonnet
Aaron, go talk to Nick "nickcorr" about that.
His has been installed a lot longer than yours.
I'd certainly try it out.
Could do it too - the PM35 bonnet has a lot more clearance than the NM35 bonnet.
im actualy going to make you do it next time you come around.. i dont beleive you until i see it.
Are you physically unable to close the bonnet or is it that you think/know/hear its touching once it does eventually close?
well last time me and scott tried my fron bar was off.
i could clearly see it touching. and it hack up the foam on the bonnet.
  • 3 months later...
    • Starting with issues 1 - 5, we have already run into a problem...!  Issue #4 contained 2x front brake calipers, instead of 1 caliper and 1x steering knuckle. Will have to call DeAgostini on Monday to sort it out. Anyway here's some photos.  Issue #1 is the front bumper, headlights and number plate. Issue #2 is the front wheel (with "We produced with spartan air." text on the centre cap!) and tyre, the front lip spoiler and cylinder head cover with ignition coils under the centre cover... which will never be seen again. Issue #3 is the bonnet and cylinder head. Issue #4 is the front strut, brake disc (with laser etched metal discs) and brake caliper. I stopped here because of the issue with the missing steering knuckle.  Next update will be #5 - #10 in a few weeks.
    • DeAgostini is one of a few companies that release quite large (the largest commonly available size actually) 1/8 scale models in a series of weekly issues over 100 - 110 instalments.  They release different models for different markets and DeAgostini Japan have release the BNR32 Skyline GT-R Nismo last month. I've made two of these 1/8 scale sized cars (one an R35 GT-R from 2012 - 2014, the other I'm just about halfway through, a BNR34 Skyline GT-R from the 2Fast 2Furious movie) so when this R32 was announced there was no way I could ignore it as it's my favourite out of all Nissans.  Each issue costs around $20 so it costs about $2.2K when completed. I suppose it is very expensive for what it is, but the quality and details are really very good, and there are many "gimmicks" like fully functioning exterior and interior lights operated with a remote control, working steering, all doors/bonnet/boot/fuel lid open and close, the side mirrors fold in and it even has a speaker for the engine revving sounds when you turn the lights on.  Each issue comes with a magazine that tells the story of the BNR32 Skyline GT-R Nismo from the first design stages of the BNR32 to Group A homologation and the various racing version that were run in the Japanese Group A and JGTC, and Australian Group A.  So I plan to update the build in this thread 5 issues at a time.  https://deagostini.jp/r32/?srsltid=AfmBOooKjxDc4EUK2rmXqMBPgyHfFJ24s4oEPJBNpnF-lFlsRoW0PE6P
    • As per title.. has anyone used so far? Keen to hear results, comparisons. In the market for a new mani for my new turbo. Any issues cracking?
    • Re read everything that has been written about this in this thread.. Let us know if you're still confused.
    • This would be a new pump with new gears. I'm just unclear on whether it's a good idea to run more oil pump flow if you don't actually need said flow. Oil level is set a minute or so after shutting off a warm engine so wouldn't the high RPM oil level in the sump end up lower all things equal? Plan is OEM clearances, main concern in my mind is whether the OEM pump can keep up with the flow requirements of any additional oil coolers.
