If thats LEDA suspension and Brendale, the guy is a legend! He has done most of the work on my dad's clubman. Really knows his stuff, build lots of purpose built race cars, like sports sedans, all his knowledge is from experience not a how to hand book. Very good, and reasonable, realistic prices. He has worked on my mini and was very happy, haven't taken the line there yet as I moved to the Southside and it a bit of an effort to get there.
Hows about Gold Coast Suspensions. (07)55914488
They specialise in Drag and Race/Rally units and are Import and Electronic suspension specialists.
Do very good work apparantly (haven't been there myself, but have heard good things)
Fulcrum parts are good (car has all their bushes installed) , but they over charge like you would not believe for labour. I got a quote to change by struts and springs, come in at $400 so a mate and I did it in my driveway in under an hour. The longest part was compressing the springs with they would have done using a rattle gun.
Buy there stuff and have installed elsewhere.
Agreed, I got my shocks and whiteline gear through them, but when I asked how much to install, I nearly fell over. So I went home and did it myself in two hours and got a wheel alignment afterwards. They are good just their labour is hell expensive.
thanks for the suggestions.
however, I have decided to just get the settings I need from the last place that set it up (in sydney) and will just get the local bob jane to tweak it as required.
out of curiosity, which suburb is Leda in?
Leda is in Strathpine/Brendale, probably a bit of a drive for you. I went there this morning to get a new threaded spring seat machined for my coilovers. They are very good. I always like walking into a workshop with rollcages and race prepared shells lying around. I usually deal with Ron, the other guy in there is Bruce.
Last time I used Bob Jane they did a pretty average job, the cambers were out by 1/2deg on each side. They said it was worn bushes which was shyte as I had them replaced just before.
I'd suggest using Tyre Tech in Albion for general setup etc. The guys there are brilliant and most of them race. When they set up the car it was 1.37, 1.38 from left to right. In other words "Spot On".
do these places deal with just 'normal' skylines ?
i need to get the camber on my rear tyres looked at badly
Whats normal? I have taken the mini and the gemini to Leda many times. Great guys. He had a nice 180B in the mix this morning too!
I am sure if its possible to reco the coil-overs it wouldn't be a problem, have never asked them to do that, a spring is a spring so springs shouldn't be a problem either, you tell them the spring rates you want and I am sure they could organise something, I highly doubt they would get Jap brands though. They do heaps of custom suspension work with clubmans, hot rods and building full race chassis, I am sure any problem with a road car could be solved.
i am thinking of fitting my coilovers at accurate suspension. anyone had any experience? is leda better? does anyone know the advantages of weighing each corner? should this be done with driver in the car? do most suspension places have the C-wrenches to adjust the height. mine are ohlins coilovers, are they different from say, tein or gab?
    • @soviet_merlin Thanks mate!  Nothing too major but will hold me up for a while. I've got lymphomas to get taken off the back of my neck and the middle of my spine which always conjures scary thoughts!  It sounds worse than it is. Yeah great, conjuring more rabbit hole deepening , just what I need! 🤣
    • I'd argue the F50 kit I got is very good value. For ~2k I got the calipers (refurbed condition), adapters, pads, brake lines, rotors, and top hats. I think you'd be pretty hard to get Evo/GTR/350z brembos + the additional hardware for similar money. Used market for a pair of front calipers alone I've seen tend to run anywhere from $1500-2000 depending on condition.    That said, something like a GTR or 350z brembo is a lot easier to adapt to the Silvia.
    • Is there a significant price difference between the Evo/gtr/350z brembos vs the F50? Looks amazing.
    • I was actually being a tightarse at the time LOL... My OCD is tickling me into running a 2nd 8AN Teflon hose all the way down and removing the 2x OEM hardlines. My other side of my brain is telling me to run 2x hardlines front to back (also acts as a fuel cooler, so win win).
    • As I mentioned in an earlier post, I had some trouble with the Silvia's brakes dragging back in 2023. I managed to sort it out then, but the same problem came back to bite me late last year. Just take a look at the picture – I had a feeling the handbrake was acting up again, and I was right. Anyway, I'd been wanting to upgrade to bigger brakes for a while. Not that the Silvia's brakes were bad, but it was more of a "want" than a "need", you know? It was funny, though – at the time, I couldn't find any Evo Brembos, 350Z Brembos, or GTR Brembos for a decent price (of course, tons of them popped up online after I already bought my kit!). I ended up going with an F50 Brembo kit, which came with adapters, brake lines, 330mm rotors, and top hats. The F50 Brembo caliper was used in a few other cars too, like the FPV. I also decided this was the perfect opportunity to ditch the Silvia's ridiculous rear brakes and that awful handbrake (some of you were definitely right about that!). I picked up some R33 calipers and all the necessary bits – rear drums, backing plates, and new hardware to refurbish the calipers. Of course, it wouldn't be a project without a few hiccups. Turns out the brake master cylinder was playing up and basically (to put it simply) keeping the brakes engaged. I had it overhauled, and after some adjustments, everything was working again. The whole process took a while, as you can imagine. To top it off, the front right wheel bearings were shot and needed replacing too. This is a rare occasion where I'm posting an update while it's all still fresh! These pictures were taken just this afternoon.
