Hi all,
I have managed to get my hands on a TD06 19C turbo with what looks to be a Trust '3 bolt' 8cm exhaust housing.
Can someone in the know please give me some information as to what this turbo would bolt to and/ or was it a particular upgrade to a type of vehicle?
It's a different configuration to what my Subaru would use and a little on the large side for what I use the car for - so will likely have it balanced and then sell it.
Thanks in advance for your assistance - as I know very little about these types of turbos. :blink:
Cheers.
Daz.
https://www.sau.com.au/forums/topic/299553-what-engine-will-this-turbo-suit/
if by setup you mean ease of installation;
you'll need an external wastegate, so you'll need to get some kind of spacer to be able to mount one, get a new manifold with a mount for it on OR get a flange for one welded onto your standard manifold. also new oil and maybe a water feed and return made up.
you'll need a new intake pipe, a hot-pipe to the intercooler made up as well as a new dump pipe.
you will also need a decent ECU, injectors and coil packs at the very least to be able to run it properly.
it will pretty much need all the work it would take any other sized turbo to mount but anyone buying it would already know this.
Hey Darren, it's not a bolt on affair due to the flange type of the Trust turbo's, but no different than fitting up a HKS 3037 etc in that it will require a new Ex. gate manifold with a flange to suit the Trust type, as well as obviously the ex. gate itself, dump, lines etc.
They are marginally more difficult to fit as there are not heaps of manifolds that can be bought off the shelf from China to suit, so it takes away a lot of the crowd not willing to spend the cash. Ideally someone would get a custom steam pipe manifold, or one available off the shelf from 6Boost/Powertune etc and the flange can be added at the time of construction.
This manifold is like 300 bucks. Seem to be of great quality since all the manifold they make for our vehicles are on ebay...lol.
here is the link: http://cgi.ebay.com/ebaymotors/OBX-Turbo-M...sQ5fAccessories
Thanks a million for the replies, fellas!
I don't know the configuration of a Skyline turbo and by the sounds of things, this turbo is the same!
I will proceed in having it tested and balanced and will put it up for sale on here in the next couple of weeks.
Am I right in assuming these sorts of turbos sell used for around $750 - $1000?
Hey Darren, it's not the same as a Skyline Turbo flange. Trust flanges are exclusive to Trust, but it will suit some Nissan 2lt engines, but is not a straight bolt on affair (new manifold requires, as well as auxillaries).
As for price, I've not seena 19c for sale for a while, but that seems quite reasonable.
    • I buy my wheel cleaner in 4 litre bottles now. Euro brakes are brutal
    • Sounds like it may all just be some baseless outrage stoked by the carexplore guy? As in the linked social media outrage on facebook just goes back to carexplore as a source again. Further shown by the council response that nothing actually has changed: "The Private Land Use Permit has been part of the Casey Community Local Law for a number of years. It's important to clarify that this permit is not new, and no changes have been made to the permit or the Local Law in relation to the permit." The full council response in Prank's link sounds reasonable to me. Saying that as someone who neither lives there nor has a front yard to call their own
    • Clutch hydraulics are also all good, looks like a brand new slave cylinder and everything bled up well. No idea what the actual clutch is, and I don't intend to pull the box off on the floor to find out, so unless we have trouble on the dyno or at shakedown that will remain a mystery for the new owner
    • Front brakes are G4 8 pot calipers over 330mm discs with braided lines. Everything looks good, pretty sure these are off my old 350. Pads are brand new and judging from gold colour are Winmax which is what I also run on my race car, Neil and I both sourced brake stuff from Matty at Racebrakes Sydney who really knows his stuff Everything has bled up nicely with all new Motul RBF600 fluid, there were 2 loose hard line connections and the calipers were new on the car so I ended up doing it 3 times but it is perfect now
    • So, starting with the rear brakes. They look like standard R33 GTST, and will need new pads shortly (less than 5mm material, probably only 1 day left). The slotted discs (probably DBA) are near new at 18.01mm and the lines are braided
