R32 Gts4 AWD with full GTR Conversion 1990
Custom purple
RB26DETT fresh Re built With Eagle rods
2x Brand new Dash 7 N1 Turbos
Exceedy Twinplate clutch
Aftermarket coil overs
HKS Intercooler
Upgraded brakes and calipers
Slotted routers
GTR steering wheel
GTR front bar
Injectors
Fuel pump
In car TV
Blitz duel stage boost controller
Apexi Power FC
+ lots & lots more
Needs:
A tune
The boost controller to be properly installed
Has a minor scrape on the front guard
Oil leak from underside of the car
Asking for a quick sale
Car is currently not making boost because I didn’t have time to fit the boost controller and get it tuned before I went overseas.
Car is currently in storage
Looking for $13,000 if you are interested pm me for more detales No rego or RWC
Good for 250-300RWK
https://www.sau.com.au/forums/topic/299572-r32-gtr-godzilla/
y do you always advertise this as a gtr.
its a gts-4 with gtr running gear.
its false advertising.
also has it been engineered and registered with the running gear and brake upgrades??
Yes I belive it has been engineered as a RB26DETT
I will work on some photos its kind of hard because I am living over seas and am selling the car so I will see what I can do about photos.
Edited by Rps13
    • I’m doing some side developments on SR20det S13 engines, its one my hobby cars used it to compare flow capacity of some smaller size wheels. SR20det is one of another JDM legendary engines I'm sure there are plenty of SR enthusiasts on this forum, I will share results some common turbo configurations here. a quick run down of what the car is: Wide body 180sx Type X with black top engine (blue). It has: Stock bottom end Haltech 1500 ECU 5-0 motorsports trigger kit Kelford SR20DET Beehive Spring with Titanium Retainers Kelford Cams SR20DET S13 188-B 268/272 Cams G25-660 Turbocharger in T2 .64 rear housing internally gated ARP Head studs MLS head gasket 1000CC ID injectors Walbro 450L Fuel pump Front mount cooler kit JJR’s 3 inches turbo back exhaust (its too short for the 180sx it had to be extended) Pump 98 fuel Hub Dyno tune So far made 270rwkws at 22psi full boost by 4500RPM. Engine is very knock limited hence a pretty bad looking top end. From previous experiences it seems like SR20dets are happier with bigger size turbine, some thing like a GT30 would make way better top end, but on same time response is lost. It won't be a problem with S15 VCT engines. I'll be testing alternative turbine housing, turbine wheel and possibly dump pipe options for extra flow to resolve the problem and of course E85 would resolve all the issues.
    • Awesome writeup and details. Thanks for sharing the story so far. I can relate to parts of it with my previous car and some of the issues I had to deal with.
    • Wow the colour matched hard top completely transforms the car. Are there any nice front lip options for the car or is that off the table?
    • Generally yes but for some reason I've been ruthless this time around!  I might even need to do another tip run after the way I've finally been able to hit the delete button on shit I've stepped over, stepped around and tripped over for the past 10 years!
    • I just quote the Rolling Stones. Paint it black.
