Whereabouts is the Resistor Pack located in the R32 harness. I am seeing what looks to be one but it is running back directly to the Fuse box, no where close to the injectors. Does anyone have a pic of it connected to the right harness. I am tihnking it may be missing from my harness.
https://www.sau.com.au/forums/topic/299594-resistor-pack-location/
The resistor pack plug is not on the engine harness. The injector wires leave the engine harness through the plug near the factory airbox. They need to be removed from that plug. I just put the resistor pack under my airbox.
The wires for the resistor pack go completely around the engine bay. The resistor pack on the GTR is on the driver side strut tower. The wires go into the chassis harness that takes the wires underneath the radiator support to the passenger side and connects to the plugs that sits on the passenger side strut tower. Then the wires continue back to the firewall and go over to the injector side of the engine. One complete loop. I guess Nissan wanted more resistance in the line, so they added about 3 meters of wire.
    • Hey everyone!!  I've noticed that whenever I do my oil changes, after putting 4L in, the oil level sits at the top mark in the dipstick. This is after letting the old oil drain for a very long time too! I've checked the oil level daily for the past few mornings. It happens every time and it's confusing because all the threads say that it should take about 4.7L (With some just adding the full 5L) My next thought is to figure out if the dipstick I have is correct so could someone please tell me the length of the RB25DET engine oil dipstick?  I've checked images of some of the genuine dipsticks, but none of them have the length in it. https://justjap.com/products/genuine-nissan-engine-oil-level-dipstick-fits-nissan-r34-skyline-c34-stagea-c35-laurel-y34-cedric-gloria-rb25de-t-neo?currency=AUD&srsltid=AfmBOortQXofgmiHVRKuIaiKuygL4k0Ewp68c3isGZk0vvKOJ7Yqf3iB However.... the engraving on the genuine ones say 05002 while mine says AA000. This makes me believe that maybe I have a wrong dipstick? I just want to confirm before I buy a new one. The car is a fresh import from Japan so I don't have details of the previous owner to ask him. Thanks in advance 🙏🏾
    • Sport. I didn’t rebleed it cause I just removed the slave and left connected.    I will change line and slave and see how it goes.
    • Oh and how is the rattle when foot is on the clutch ?
    • Did you get the sport or track ? From what the documentation says the uniclutch has a small amount of movement to disengage.  So your story of tricky pedal setup seems common.    Hopefully you got it bled up too, as the bite point moving around is usually either plates wearing in or air in the line.
    • There's always "MIG it up and grind it back".
