I have a near stock 32 GTR (only performance mods are cat back exhaust, pods and boost restriction valve removed) and was wondering what gearbox oil people would recommend?
I have heard Redline Lightweight Shockproof is one of the best. Has anyone had any experience with this oil? I believe it will be about $250 just to purchase enough oil for the gearbox, but if its as good as I have heard then I don't care.
The second review on this website is from the owner of a 32 GTR:
http://www.redlineoil.com.au/testimonials.asp?CategoryID=3
Any advice greatly appreciated.
https://www.sau.com.au/forums/topic/299697-r32-gtr-gearbox-oil/
i have used redline in my gtr for 2.5 years and cant fault it. I had a crunchy 3rd gear with motul, but now its smooth as with the redline.
some people say redline should be used in a synchro box, but until someone can give me a good reason why not, i'll keep using it, as it has transformed my gearbox.
Cheers. I assume when you refer to redline you are talking about the "shockproof" oil the sell?
I've used Redline lightweight shockproof in my gearbox and transfer case in 2 cars for 2 years.
I also use the heavyweight stuff in the diffs.
never had an issue, makes shifts feel a bit more firm and responsive.
worth the money in my opinion.
Mr Niggles
A couple of Canadian owners are using GM Syncromesh tranny fluid, same results as Redline. However, IMO Royal Purple is best and I will be putting some Royal Purple Syncromax to use.
Edited by Beacher1B0
    • Thanks Murray, appreciate the advice, a few things to think about now 😀
    • After my million questions, I'll throw in my 2c now.  If I was in your shoes, I would buy the best/most modern ECU available. A Nexus S3 would fit the bill. It is highly likely that this ECU will last the life of the car, regardless of whatever ECU manufacturers develop in the future. Modern ECU's are amazing and will still be amazing in 10 or 20 years time. If you can get e85 relatively close to where you live, I would buy a flex sensor and size the injectors to run e85. I'd go a Walbro 525 fuel pump with relay wiring kit.  Turbo wise, I'd hit up HyperGear and get a pair of the biggest bolt on turbos.  Now for the safety side of things, I'd have the tuner setup the tune to be very soft/safe on 98. Then on the flex tune, a lot of the timing can be put back in on the top end (I'd run full boost on both tunes, but manipulate the power with the timing). This also has the benefit of hopefully delaying the, "bored now, need more boost" that comes with owning a modified turbo car. If you spend most of your time on the 98 tune, the few times your on e85 will hopefully stay special/fun.  The bad news. As your paying for labour and tuning, I don't think this will happen with $10,000. This might be the motivation to learn to do it yourself though, that way instead you'll have the built car and change from the $10,000
    • Cheers Duncan, on club reg and very much a weekender, don't drive it all that hard and don't intend to go overboard at any point in the future too. In my 40's and quite mature driver, just want that little bit more from it 😉 Sounds like, after ensuring everything is in good condition, ECU, Injectors, Fuel Pump and a set of turbos is likely to be my path forward.
    • 15 years is not too long to hold onto something like that, right?
    • Hey man,   By any chance you still have sunroof for sale ?   Thanks
